For ytcr disconnecting on weak WiFi, there’s not much that can be done because it has to comply when it receives the ‘disconnect’ command from the Google server (which acts as some sort intermediary between Volumio and the YouTube app). On the other hand, it might be possible work around this by using a TV code linking method which supposedly doesn’t require the YouTube app to be on the same network as the receiver. I’m not sure if this will improve connection stability and it also needs to be implemented and tested, so you would have to wait (no ETA, sorry…)
I get
Sep 22 09:53:34 volumio systemd[1]: [/opt/mpd-0.21.16_20191227/lib/systemd/system/mpd.service:24] Unknown lvalue 'ProtectKernelTunables'
Sep 22 09:53:34 volumio systemd[1]: [/opt/mpd-0.21.16_20191227/lib/systemd/system/mpd.service:25] Unknown lvalue 'ProtectControlGroups'
Sep 22 09:53:34 volumio systemd[1]: [/opt/mpd-0.21.16_20191227/lib/systemd/system/mpd.service:26] Unknown lvalue 'ProtectKernelModules'
Sep 22 09:53:34 volumio systemd[1]: [/opt/mpd-0.21.16_20191227/lib/systemd/system/mpd.service:29] Unknown lvalue 'RestrictNamespaces' in
Sep 22 11:33:24 volumio systemd[1]: mpd.service: main process exited, code=killed, status=11/SEGV
Sep 22 11:33:24 volumio systemd[1]: Unit mpd.service entered failed state.
with Volumio 2.909.
Output of systemctl status mpd?
Also systemctl --version?
I did a apt update && apt upgrade, apt purge mpd, apt install mpd and the systemd-switch-mpd.sh script again and now it seems to work so far …
This is the first thing I did by hand apart the setting of the IP since I set up a new Volumio … ~ two months ago.
Always update never UPGRADE @smoneck this will break volumio…
I’m facing an interesting issue on my odroid c1+
You can read more here
basically with the official mpd the scan is awfully slow
With this newer one the scan is blazing fast but at the end it reaches 100% cpu utilization and out of memory making volumio crash.
Volumio-ytcr works great with seeking as well though so i guess something shall be changed to be compatible with odroids?
I’ve never actually tried scanning a large library with this MPD version, since I use a separate device running Jellyfin media server that handles around 10,000 tracks, along with the Jellyfin plugin.
I’m not an expert, but the errors look like they are generated by the kernel. The aml_i2c_xfer messages relate to the i2c bus and have nothing to do with the current issue. If I understand correctly, the _hcd_isoc_complete:Uknown urb status -2 messages mean there’s something unusual with fetching / writing data through the USB bus. This is possibly what caused MPD to crash during the scanning stage.
That’s one of the things with using this MPD version on an old distro. The software was compiled with newer libraries, and some of the libraries are meant to work with newer kernels (AFAIK, the Odroid kernel is old… even older than the x86 version that Volumio uses). So it is possible that during the scanning stage, a library fetches data from the USB bus with the old kernel that happens to have a memory leak bug, and that eventually leads to MPD crashing.
@patrickkfkan
I’m only scanning NAS devices over samba.
Mediaserver is working great though.
Does Volumio have a way to cheat on media cache? e.g. copying it over from another device?
About kernel facts you are totally right, as soon as Pi4 will drop in price ill go for it.
It’s a shame we can’t run it on a docker though
I’ve noticed the following in /var/log/mpd.log though
Oct 06 14:25 : client: [1] opened from 127.0.0.1:39433
ALSA lib conf.c:3650:(snd_config_hooks_call) Cannot open shared library libasound_module_conf_pulse.so (/opt/mpd-0.21.16_20191227/lib/alsa-lib/libasound_module_conf_pulse.so: libasound_module_conf_pulse.so: cannot open shared object file: No such file or directory)
ALSA lib control.c:1375:(snd_ctl_open_noupdate) Invalid CTL default
Oct 06 14:25 : exception: Failed to read mixer for 'alsa': failed to attach to default: No such file or directory
is this normal?
volumio@volumio:~$ sudo find / -name libasound_module_conf_pulse.so
[sudo] password for volumio:
/usr/lib/arm-linux-gnueabihf/alsa-lib/libasound_module_conf_pulse.so
/static/usr/lib/arm-linux-gnueabihf/alsa-lib/libasound_module_conf_pulse.so
I have version 2.916 running on the Dell Wyse Cx0. (32Bit)
I installed the Youtube2 plugin according to the instructions. It can also be activated, but it doesn’t find anything, the page remains empty.
The instructions say something about an outdated MPD version. That’s why it says a build MPD v0.21.16 for Volumio. However, this is also from December 2019, but my Volumio is already from October 2021.
Which MPD version does Volumio 2.916 have?
Can I get Youtube2 to run if I install the latest MPD version? If so, can I get a current MPD version?
V2.916 has been out of support for a long time and won’t be supported anymore.
YouTube2 is also no longer supported on V2 and V3.
Please upgrade to Volumio V4 Beta release as this is supported by Youtube2
I cannot update this machine because it has a 32Bit CPU. It is really annoying that there are no more updates, although Debian officially supports 32Bit. Currently until 2028! I still have a 32Bit laptop with Debian Bookworm, it works.
I’ve been playing with the Wyse3040 + Volumio 3 for a while, but it causes clicks on play, pause and skip. And the much needed Equalizer Fusion DSP stutters like crazy. Impossible. That’s why I went back to the Cx0, at least it works. Even the parametric equalizer. SoundCloud is obviously also played at 24 bit, great.
Volumio supporting 32 bits on a x86 platform was a long time ago.
I am surprised that the Wyse3040 is giving issues as I had 2 of them running for test evaluation. They worked fine even with FusionDSP.
You might want to post the issues with the Wyse3040 here.
Please read the opening post and provide the requested data.
