Mixer Type keeps resetting
Just to join here the choir: I’d really appreciate if the Volume Mixer Type would stay on “None”, also when the DAC is switched off and on in-between. Using a Marantz SA-12 SE SACD-Player as DAC and the Volumio Rivo via USB.
I will also ask for this via the help center as Rivo owner.
So 3 years later, this is not fixed.
Adding my request to have the option to stay on “None”.
Having to change this every time I turn on my DAC is annoying
And no, I it’s not related to turning the RP off the wrong way as mentioned in other threads, my RP is on all the time.
Hello all.
As a paid user, I’m adding my request too.
I have two Volumio setups, both built on top of RPi4 boards, both are using external DACs via USB connection, both stays on 24/7, and for both I’m only turning off/on the amplifiers.
First one is using Audiolab 7000A, second one is using Topping MX3s.
With first one I do not have problem, Mixer type stays to None, while second one keeps moving Mixer type to Hardware everytime I turn MX3s on.
It is very annoying thing that keeps breaking my user experience.
Everytime my volume goes down, which I overcome by setting default volume to 100, but my phone keeps controlling the volume, Wich I do not want to.
Please fix it.
Since you are a paid subscriber, you have premium support.
Then the best thing is to create a support ticket so that your issue is registered and don’t get lost on the community forum.
Create Support Ticket
