# Mixcloud Plugin
**URL:** <https://community.volumio.com/t/mixcloud-plugin/3671>\
**Category:** Suggest a feature\
**Created:** [February 23, 2016, 6:56pm UTC](https://community.volumio.com/t/mixcloud-plugin/3671 "2016-02-23T18:56:33Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Inkraft666](https://community.volumio.com/letter_avatar_proxy/v4/letter/i/f17d59/32.png) [@Inkraft666](https://community.volumio.com/u/Inkraft666)\
**Post date:** [February 23, 2016, 6:56pm UTC](https://community.volumio.com/t/mixcloud-plugin/3671/1 "2016-02-23T18:56:33Z")
</div>
It’s possible to develop a plugin for play MixCloud Stream on VolumIO ?
Thanks,
Inkraft
**Author:** ![Brickwo](https://community.volumio.com/letter_avatar_proxy/v4/letter/b/ad7895/32.png) [@Brickwo](https://community.volumio.com/u/Brickwo)\
**Post date:** [December 22, 2017, 11:23am UTC](https://community.volumio.com/t/mixcloud-plugin/3671/2 "2017-12-22T11:23:01Z")
</div>
I just found this related topic for you: [volumio.github.io/docs/User\_Man … to\_volumio](https://volumio.github.io/docs/User_Manual/Stream_audio_to_volumio)
or you can download the mixes then stream them to volumio. As for downloading methods, you can check this tutorial: [videoconverterfactory.com/ti … o-mp3.html](http://www.videoconverterfactory.com/tips/mixcloud-to-mp3.html)
Hope this can be helpful.
**Author:** ![idff](https://community.volumio.com/letter_avatar_proxy/v4/letter/i/bb73d2/32.png) [@idff](https://community.volumio.com/u/idff)\
**Post date:** [September 19, 2019, 5:52pm UTC](https://community.volumio.com/t/mixcloud-plugin/3671/3 "2019-09-19T17:52:47Z")
</div>
I also think it would be great to have a plugin for Volumio, I believe there is one for OSMC so it must be possible. Mixcloud API documentation says they do not let you stream tracks so not sure how OSMC are doing it. Any ideas anyone, there’s some great radio shows on Mixcloud that you can’t find anywhere else. Yes, I could download them but that’s a pain and not good for Mixcloud, I would rather they get the ‘plays’!
**Author:** ![Darmur](https://community.volumio.com/user_avatar/community.volumio.com/darmur/32/23571_2.png) [@Darmur](https://community.volumio.com/u/Darmur)\
**Post date:** [May 14, 2020, 4:45pm UTC](https://community.volumio.com/t/mixcloud-plugin/3671/4 "2020-05-14T16:45:03Z")
</div>
One of the web radios I usually listen uploads to their Mixcloud account several of their programs.
I’d really like to have Mixclod support included in Volumio
