I don’t know how to setup this Display .
I can only see a part on the right display side .
Does anyone know what to do ?
Thank’s
Please post a picture of the display showing the issue.
Also please post the output of
cat /boot/config.txt
and
cat /boot/userconfig.txt
If I add “dpi_group=2
dpi_mode=87
hdmi_cvt=480 128 60 3 0 0 0” ,
I get a corrupt Display with small stripes .
I’ve also tested r-audio1 and the Display looks like the 2.picture
without adding anything to the config.txt .
If I add the lines it also shows only small stripes.
Please post the output of
and
config.txt :
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
include userconfig.txt
dtoverlay=hifiberry-digi-pro
userconfig.txt : # Add your custom config.txt options to this file, which will be preserved during updates
So userconfig.txt is empty
Please post a picture of the display with these settings.
Do you use the TFP401 decoder with the display?
After installing the touch-display plugin it looks like this .
The display has a native HDMI-Input , so I don’t use an additioal decoder.
Try adding the following lines to “/boot/userconfig.txt”:
hdmi_cvt=480 128 60
hdmi_group=2
hdmi_mode=87
max_framebuffer_width=480
max_framebuffer_height=128
Please head over to the Touch Display plugin configuration page and try a scale factor of e.g. 50.
No Chance , I’ll give it up for today .
Please post the results of
tvservice -m DMT
tvservice -m CEA
and
tvservice -s
Group DMT has 1 modes:
(prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
Group CEA has 2 modes:
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
tvservice -s
state 0xa [HDMI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
Please check if adding
hdmi_ignore_edid=0xa5000080
in front of “hdmi_cvt” has an effect.
I’ve got some working settings now . Still need to play with “Overscan-Settings”
hdmi_group=2
hdmi_mode=87
hdmi_timings=640 0 30 10 30 480 0 10 3 10 0 0 0 60 0 25000000 6
overscan_left=0
overscan_right=155
overscan_top=0
overscan_bottom=32
framebuffer_width=640
framebuffer_height=480
Great!
