I’m just got a Metrum Onyx DAC and hooked it to Volumio through USB. I was using an RME Adi-2 before and just hooked the cable to the Onyx. Forgot to change the output device on Volumio, but the Metrum Onyx was working fine anyway. I was switching the USB between the Adi-2 and the Onyx several times without restarting Volumio and it was fine.
Then I got to the playback settings of Volumio and found that the inner sound card of the mini pc that is running Volumio was selected. I changed it to the “hiface two uac2”, which is the Metrum Onyx. After that switch I no longer can make it work. The Onyx is showing error. I tried the Onyx with it’s drivers on Windows and it’s working.
Can you help please? Any suggestions?
Also, it’s possible to buy an USB to SPDIF converter soon - probably Matrix Audio - X-SPDIF 2 or Gustard U16. Will this work?
