Lost sound from Volumio running on Raspberry Pi 4
About two weeks ago, I could not get any sound from my Volumio on the Raspberry Pi. I can select the song and play it but I do not get any audio from my Azur 340R via the Cambridge Audio DAC Magic 100.
I am using the free version and have checked and changed the settings.
All the other settings were left unchanged when I installed it.
Have I missed something obvious?
Below are the settings of my configuration.
I only amended the Network Drive and the Wireless settings.
Sources
Network Drives: music \192.168.1.191\music
Functionalities control: UPNP Render - On
Shairport-Sync: On
DNLA Browser: On
General Playback Options
Output Device: Cambridge Audio DAC100 USB1
DSD Playback Mode: DSD Direct
DSD Auto Volume Level: On
Volume Normalisation: On
Audi Buffer Size: 2MB
Persistent Queue: On
Playback Mode: Continuous
Volume Options
Mixer Type: Software
Default Startup Volume: 15
Max Volume Level: 100
One Click Volume Steps: 10
MPD Clients Volume Control: On
Audio Resampling: On
Target Bit Depth: Native
Target Sampling Rate: Native
Resampling Algorithm Quality: High
Network Status
Wireless: VirginMedia
IP Address: 192.168.nn.nnn
Speed 72.2Mb/s
Wireless Networking: On
Automatic IP: On
System Settings
Player Name: Volumio
Installed Plugins: Spotify
Can someone please advise?
TRY:
Audio Buffer Size: 2MB - 12
DSD Auto Volume Level: On OFF
Volume Options
Mixer Type: Software NONE or Program
Change to OFF
Hi Grzegorz,
I have changed the settings as per your email and there is still no sound output.
Do you see your DAC on the list?
Is it connected via USB?
Yes, the DAC is on the device list and is connected by USB C.
I borrowed a USB DAC from a friend. So set up, it sounds very nicely. I don’t know what’s going on with you? Maybe change the USB cable …
HAd the same thing going on with the Allo-digione.
All seems to work, but no sound output.
Even after removing the overlay from the config.xt, Volumio still was under the impression that the allo was configured.
Finally I did a reinstall and it worked.
Changing the cable did not work.
Reinstall
Check this first, from the manual:
If your DacMagic 100 was manufactured prior to 2014, you will require an update to enable USB Audio 2.0 compatibility.
You can tell when your DacMagic was manufactured via the serial number. The numbers in bold below indicate the year followed by the month. In this example, the unit would have been made in August 2013.
XX C10501 1308 0001
Yes, that is the next step.
Thank you. Will do that before the reinstall.
From your screen shots I see it seems to say “Cambridge Audio DAC100 USB1”.
So when your DAC was produced after 2014, you still need to tell it to use USB Class 2.
Refer to the manual: https://techsupport.cambridgeaudio.com/hc/en-us/articles/4421557642641-How-do-I-use-my-DacMagic-100-in-USB-Audio-Class-2-0-mode-
If that does not work, well then I’m out of ideas. Cambridge DACs are a bit special with linux as they will not officially support it, but in the end they always do the basic work, which is producing good sound.
Thank you. Lots of leads for me to check out.
Nothing wrong with the Cambridge DacMagic 100 as it works perfectly.
I just rebuild Volumio. The music sounds great.
And I made a BACKUP copy of Volumio.
Thank you everyone for all the tips and advice.
I rebuilt Volumio and made a backup copy
