Losing music libary when i restart
Volumio 3 Issues?
i installed volumio 3.378, system is raspi 3, with nanomesher dac2 and oled 1,5 display. My qnap 251 has been recognized, on a new installation, the music libary has been created by volumio. I use cifs and all is fine.
After that i installed the nanosound plugin manually using putty. This is the explanation link. NanoSound Volumio 3 support | Nanomesher
All works and i am satisfied. But when i switch off my raspi i think i am loosing the cifs connection to my qnap. Rebooting the system results in a loss of my music libary, updating and rescaning results in nothing nor error message simply nothing. There are 0 artist 0 tracks. Switching to nfs won´t work either. Network connection is wired and i haven´t installed a wireless connection.
Any suggestions?
Do you have anything in the ‘Options’ field in the Network Drive settings? Sometimes this option can help with older NAS protocols.
vers=1.0
thanks, for the reply. Yes i can set the smb protocol in my qnap, but changing it at 1.0 doesn´t change anything. On volumio i tried this already. My NAS is able to use version 3.0, and it was configured in the right manner.
