Logitec Media Server plugin for Volumio
After two steps forward in the last post, here’s the one step back. Whenever I play a track on squeezelite, there’s a noticeable pop in the first few seconds, which is disruptive to the listening experience. I’ve tried a wide range of parameters and both the ALSA and I2S output devices.
There is no pop if I play the track either using volumio’s upnp player or use the digital out from my Squeezebox touch, so it does appear to be related to the SqueezeLite plugin :frowning:
Has anyone run into this? Did you find a solution?
Thanks,
Mike
I am new to Volumio and downloaded the LMS player through the plug-in page but I can’t open it and get the attached error.
I am not a Linux expert which is why I am looking at using Volumio.
Can you access your rPi ip over port 9000?
You have just jumped up to a new language for me. I have no idea how to do that.
I was hoping the plug in would have worked.
Which version of LMS did you install?
yeah topic and first post raises some contradiction.
To run LMS you need two parts:
  • LMS server
  • LMS player
Your topic suggest you installed the server plugin, your first comment is regarding the player.
This is what I installed.
You could try the Docker edition by first enabling the Plugins Test Mode in http://<your volumio address>/dev
Then uninstall the LMS plugin you installed, restart Volumio, then install the LMS - Docker version.
Thanks that has worked but now I also need to load a player. Edit - found the plug-in.
First impression is that Volumio is better
Kind regards,
Peter
Hi everyone, both normal and “dockerised” version of LMS plugin doesn’t work on my volumio 3.324 installation, even after a fresh system reset. Can’t access it over port 9000. It was working a couple of months before
Please help since it’s the best piece of software for my primo
Thank you by advance
here is my log trying to turnaroud
Starting Live Log...
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Error : CoreCommandRouter::executeOnPlugin: No method [getMultiroom] in plugin multiroom
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
info: [lmsde] Executing Docker command: docker inspect -f '{{ json . }}' logitechmediaserver
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/docker inspect -f {{ json . }} logitechmediaserver
info: Received Get System Version
info: [lmsde] Executing script: /opt/lmsde/lms.sh stop
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/opt/lmsde/lms.sh stop
info: [lmsde] Executed /opt/lmsde/lms.sh stop
info: Disabling plugin lmsde
info: Done.
info: Enabling plugin lmsde
info: Loading plugin "lmsde"...
info: PLUGIN START: lmsde
info: [lmsde] Executing script: /opt/lmsde/lms.sh start
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/opt/lmsde/lms.sh start
EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
time="2022-09-17T17:57:38.429048599Z" level=info msg="loading plugin \"io.containerd.event.v1.publisher\"..." runtime=io.containerd.runc.v2 type=io.containerd.event.v1
time="2022-09-17T17:57:38.429384599Z" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
time="2022-09-17T17:57:38.429451974Z" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
time="2022-09-17T17:57:38.430021890Z" level=info msg="starting signal loop" namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/2d874044810dc56f4f99c0d3106669e52ebf76e33b9c0fcfadef2f51bb32047f pid=2214 runtime=io.containerd.runc.v2
time="2022-09-17T17:57:38.697858224Z" level=error msg="add cg to OOM monitor" error="cgroups: memory cgroup not supported on this system"
info: [lmsde] Executed /opt/lmsde/lms.sh start
info: Done.
time="2022-09-17T17:57:42.368865017Z" level=info msg="shim disconnected" id=2d874044810dc56f4f99c0d3106669e52ebf76e33b9c0fcfadef2f51bb32047f
time="2022-09-17T17:57:42.368944642Z" level=info msg="ignoring event" container=2d874044810dc56f4f99c0d3106669e52ebf76e33b9c0fcfadef2f51bb32047f module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
time="2022-09-17T17:57:42.370700184Z" level=warning msg="cleaning up after shim disconnected" id=2d874044810dc56f4f99c0d3106669e52ebf76e33b9c0fcfadef2f51bb32047f namespace=moby
time="2022-09-17T17:57:42.370976392Z" level=info msg="cleaning up dead shim"
time="2022-09-17T17:57:42.391780392Z" level=warning msg="cleanup warnings time=\"2022-09-17T17:57:42Z\" level=info msg=\"starting signal loop\" namespace=moby pid=2276 runtime=io.containerd.runc.v2\n"
var-lib-docker-containers-2d874044810dc56f4f99c0d3106669e52ebf76e33b9c0fcfadef2f51bb32047f-mounts-shm.mount: Succeeded.
var-lib-docker-devicemapper-mnt-21706d1e5bb9af29a9fdd0a7053416f89e2a06132b7f73ba2e1642ebc373b3d6.mount: Succeeded.
pam_unix(sudo:session): session closed for user root`Preformatted text`
I get message “Server is not running - this si not normal when the plugin is enabled”
This log is for last beta 3.357 that i tried to install to see if it helped
I uninstalled docker version and reinstall sayiato version
info: CoreCommandRouter::executeOnPlugin: appearance , getConfigParam
info: Loaded the previous config.
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop logitechmediaserver
info: logitechmediaserver stopped
info: Done.
info: Loading plugin "lms"...
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart logitechmediaserver
Starting Logitech Media Server Daemon...
------------------------------------ BT MESSAGE: BT STATUS: running
Started Logitech Media Server Daemon.
logitechmediaserver.service: Failed to execute command: No such file or directory
logitechmediaserver.service: Failed at step EXEC spawning /usr/sbin/squeezeboxserver: No such file or directory
logitechmediaserver.service: Main process exited, code=exited, status=203/EXEC
logitechmediaserver.service: Failed with result 'exit-code'.
info: logitechmediaserver started
info: Done.
51.158.147.92 local addr 192.168.1.117 ->
91.224.149.41 local addr 192.168.1.117 ->
Starting Cleanup of Temporary Directories...
systemd-tmpfiles-clean.service: Succeeded.
Started Cleanup of Temporary Directories.
here it looks like LMS is even not installed :frowning:
It’s a shame, i came to LMS plugin because I was not convinced by certain strange behaviour and bug of spotify plugin + spotify connect within volumio
Alternatively, I tested the UMS boot method to try a “come back to 2.9 version” without any success (maybe not the right cable or board problem)
Things are really complicated and I’m a good level nerd, i’m really fed up
For Docker version, see if LMS logs capture any error. The log file path should be:
/var/lib/docker/volumes/logitechmediaserver-config/_data/logs/server.log
In SSH, you would have to sudo to see it:
sudo cat /var/lib/docker/volumes/logitechmediaserver-config/_data/logs/server.log
Would someone please explain what Docker version is?
Docker is a piece of software that allow to install mostly any other software in any environment by providing the full execution environment a.k.a container including tiny OS (often alpine linux) and all needed dependencies. the purpose is slightly different from running it in a virtual machine or in a particular OS since if you update the container, all the dependencies are also updated. It’s top notch, - easy to deploy configure and maintain - virtualization technology, perfect for headless server and productive environment
Thank you for the explanation. That is helpful.
Is there any requirement to update Docker when Linux updates? Or hopefully it updates at the same time.
it depends but generally you don’t need
It all seems to be getting a bit tedious trying to get LMS running properly on Volumio 3. My use case for Volumio is as a Spotify connect endpoint and LMS to be able to use the BBC Sounds plug-in. My desktop streaming DAC/pre-amp does not support either of these. It is a Roon endpoint and I use this for access to my local music library.
I think I’ll be dropping Volumio and giving something like piCorePlayer as this seems to do everything that I need.
I also have problem with logitech media server like chourmovs_vs
Everything was ok with Sayato LMS, but I wanted to try Docker LMS.
Now, I can’t access it over port 9000 with both version of LMS.
At least it make me feel less alone, thank you for having share
