Log location for the UI
I’m running a script to convert podcasts to playlists (as detailed here: playlist-loading-trouble-with-podcast2playlist-t8208.html) and for some reason they are not being loaded in the UI.
Can someone provide some info as where I might find logs for the UI (if it is indeed a UI issue) to help troubleshoot this problem??
The log file /var/log/volumio.log doesn’t provide any indication as what the issue is.
Have a look at the systemd system logs: ‘sudo journalctl -f’ for realtime logging to the console, or ‘sudo journalctl -b’ for logs since last boot.
from the last log i’m getting Nov 16 00:20:56 volumio kernel: Under-voltage detected! (0x00050005)
I’m using the allo 5v 3a power plug but the old cheapo 5v 3a now gives the same behavior no usb seagate drive recognized on reboot. I got the same behavior using a battery booster pace before I upgraded
Nov 15 02:07:39 volumio systemd[1]: Starting LSB: set CPUFreq kernel parameters.
Nov 15 02:07:39 volumio systemd[1]: Starting Hold until boot process finishes up
Nov 15 02:07:40 volumio systemd[1]: Starting Terminate Plymouth Boot Screen…
Nov 15 02:07:40 volumio systemd[1]: Received SIGRTMIN+21 from PID 228 (plymouthd
Nov 15 02:07:40 volumio systemd[1]: Started Hold until boot process finishes up.
Nov 15 02:07:40 volumio systemd[1]: Started Terminate Plymouth Boot Screen.
Nov 15 02:07:40 volumio dbus[719]: [system] Successfully activated service 'org.
Nov 15 02:07:40 volumio systemd[1]: Started Disk Manager (legacy version).
Nov 15 02:07:40 volumio systemd[1]: Starting Wireless Services…
Nov 15 02:07:40 volumio systemd[1]: Starting Getty on tty1…
Nov 15 02:07:40 volumio systemd[1]: Started Getty on tty1.
Nov 15 02:07:40 volumio systemd[1]: Starting Login Prompts.
Nov 15 02:07:40 volumio systemd[1]: Reached target Login Prompts.
Nov 15 02:07:40 volumio sudo[811]: root : TTY=unknown ; PWD=/ ; USER=root ; COMM
Nov 15 02:07:40 volumio sudo[811]: pam_unix(sudo:session): session opened for us
Nov 15 02:07:40 volumio cpufrequtils[795]: CPUFreq Utilities: Setting performanc
Nov 15 02:07:40 volumio sudo[811]: pam_unix(sudo:session): session closed for us
Nov 15 02:07:40 volumio cpufrequtils[795]: CPU0…CPU1…CPU2…CPU3…done.
Nov 15 02:07:40 volumio systemd[1]: Started LSB: set CPUFreq kernel parameters.
Nov 15 02:07:40 volumio dbus[719]: [system] Activating via systemd: service name
Nov 15 02:07:40 volumio systemd[1]: Starting Authenticate and Authorize Users to
Nov 15 02:07:40 volumio polkitd[830]: started daemon version 0.105 using authori
Nov 15 02:07:40 volumio avahi-daemon[712]: Server startup complete. Host name is
Nov 15 02:07:40 volumio systemd[1]: Started Authenticate and Authorize Users to
Nov 15 02:07:40 volumio udisks-glue[675]: Device file /dev/sda inserted
Nov 15 02:07:40 volumio volumio-remote-updater[677]: Error: No active session
Nov 15 02:07:40 volumio volumio-remote-updater[677]: [2018-11-15 02:07:40] [info
Nov 15 02:07:40 volumio volumio-remote-updater[677]: [2018-11-15 02:07:40] [erro
Nov 15 02:07:40 volumio udisks-glue[675]: Device file /dev/mmcblk0p3 inserted
Nov 15 02:07:40 volumio udisks-glue[675]: Device file /dev/sda1 inserted
Nov 15 02:07:40 volumio udisks-glue[675]: Trying to automount /dev/sda1…
Nov 15 02:07:40 volumio kernel: FAT-fs (sda1): Volume was not properly unmounted
Nov 15 02:07:40 volumio udisks-glue[675]: Successfully automounted /dev/sda1 at
Nov 15 02:07:41 volumio udisks-glue[675]: Device file /dev/mmcblk0 inserted
Nov 15 02:07:41 volumio udisks-glue[675]: Device file /dev/sdb inserted
Nov 15 02:07:41 volumio udisks-glue[675]: Device file /dev/sdb1 inserted
Nov 15 02:07:41 volumio volumio[676]: Could not open config: /tmp/upmpdcli.conf
Nov 15 02:07:41 volumio udisks-glue[675]: Device file /dev/sdb2 inserted
Nov 15 02:07:41 volumio udisks-glue[675]: Trying to automount /dev/sdb2…
Nov 15 02:07:41 volumio systemd[1]: upmpdcli.service: main process exited, code=
Nov 15 02:07:41 volumio systemd[1]: Unit upmpdcli.service entered failed state.
Nov 15 02:07:41 volumio avahi-daemon[712]: Service “Volumio” (/services/volumio.
Nov 15 02:07:41 volumio haveged[673]: haveged: ver: 1.9.1; arch: generic; vend:
Nov 15 02:07:41 volumio haveged[673]: haveged: cpu: (VC); data: 16K (D); inst: 1
Nov 15 02:07:41 volumio haveged[673]: haveged: tot tests(BA8): A:1/1 B:1/1 conti
Nov 15 02:07:41 volumio haveged[673]: haveged: fills: 0, generated: 0
Nov 15 02:07:42 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:07:44 volumio wireless.js[826]: WIRELESS DAEMON: start
Nov 15 02:07:44 volumio wireless.js[826]: WIRELESS: Loaded configuration
Nov 15 02:07:44 volumio wireless.js[826]: Cleaning previous…
Nov 15 02:07:44 volumio systemd[1]: Stopped hotspot.service.
Nov 15 02:07:44 volumio sudo[855]: root : TTY=unknown ; PWD=/ ; USER=root ; COMM
Nov 15 02:07:44 volumio sudo[855]: pam_unix(sudo:session): session opened for us
Nov 15 02:07:44 volumio sudo[855]: pam_unix(sudo:session): session closed for us
Nov 15 02:07:45 volumio sudo[863]: root : TTY=unknown ; PWD=/ ; USER=root ; COMM
Nov 15 02:07:45 volumio sudo[863]: pam_unix(sudo:session): session opened for us
Nov 15 02:07:45 volumio sudo[863]: pam_unix(sudo:session): session closed for us
Nov 15 02:07:45 volumio volumio-remote-updater[677]: [2018-11-15 02:07:45] [info
Nov 15 02:07:45 volumio volumio-remote-updater[677]: [2018-11-15 02:07:45] [erro
Nov 15 02:07:45 volumio wireless.js[826]: Stopped aP
Nov 15 02:07:45 volumio systemd[1]: Stopped hotspot.service.
Nov 15 02:07:45 volumio ntfs-3g[886]: Version 2014.2.15AR.2 integrated FUSE 28
Nov 15 02:07:45 volumio ntfs-3g[886]: Mounted /dev/sdb2 (Read-Write, label "Seag
Nov 15 02:07:45 volumio ntfs-3g[886]: Cmdline options: rw,nodev,nosuid,noatime,u
Nov 15 02:07:45 volumio ntfs-3g[886]: Mount options: rw,nodev,nosuid,uhelper=udi
Nov 15 02:07:45 volumio ntfs-3g[886]: Global ownership and permissions enforced,
Nov 15 02:07:45 volumio systemd[1]: Started LSB: start Samba daemons for the AD
Nov 15 02:07:45 volumio sudo[884]: root : TTY=unknown ; PWD=/ ; USER=root ; COMM
Nov 15 02:07:45 volumio udisks-glue[675]: Successfully automounted /dev/sdb2 at
Nov 15 02:07:46 volumio udisks-glue[675]: Device file /dev/sda1 mounted at /medi
Nov 15 02:07:46 volumio sudo[884]: pam_unix(sudo:session): session opened for us
Nov 15 02:07:46 volumio udisks-glue[675]: Device file /dev/sdb2 mounted at /medi
Nov 15 02:07:46 volumio sudo[884]: pam_unix(sudo:session): session closed for us
Nov 15 02:07:46 volumio sudo[902]: root : TTY=unknown ; PWD=/ ; USER=root ; COMM
Nov 15 02:07:46 volumio sudo[902]: pam_unix(sudo:session): session opened for us
Nov 15 02:07:46 volumio sudo[902]: pam_unix(sudo:session): session closed for us
Nov 15 02:07:46 volumio avahi-daemon[712]: Joining mDNS multicast group on inter
Nov 15 02:07:46 volumio avahi-daemon[712]: New relevant interface wlan0.IPv4 for
Nov 15 02:07:46 volumio avahi-daemon[712]: Registering new address record for 19
Nov 15 02:07:46 volumio kernel: brcmfmac: power management disabled
Nov 15 02:07:46 volumio systemd[1]: Starting hotspot.service…
Nov 15 02:07:46 volumio systemd[1]: Started hotspot.service.
Nov 15 02:07:46 volumio systemd[1]: Starting dhcpd.service…
Nov 15 02:07:46 volumio systemd[1]: Starting dnsmasq.service…
Nov 15 02:07:46 volumio systemd[1]: Started Wireless Services.
Nov 15 02:07:46 volumio systemd[1]: Started LSB: Brings up/down network automati
Nov 15 02:07:46 volumio netplugd[923]: /etc/netplug/netplug eth0 in -> pid 923
Nov 15 02:07:46 volumio systemd[1]: Starting Volumio Backend Module…
Nov 15 02:07:46 volumio netplugd[922]: eth0: state INNING pid 923 exited status
Nov 15 02:07:46 volumio systemd[1]: Started Volumio Backend Module.
Nov 15 02:07:46 volumio winbind[686]: Starting the Winbind daemon: winbindmkdir
Nov 15 02:07:46 volumio winbind[686]: Failed to create /var/log/samba/cores for
Nov 15 02:07:46 volumio winbind[686]: Unable to setup corepath for winbindd: No
Nov 15 02:07:46 volumio winbind[686]: mkdir failed on directory /var/log/samba/c
Nov 15 02:07:46 volumio winbind[686]: [2018/11/15 02:07:46, 0] …/lib/util/debu
Nov 15 02:08:04 volumio winbind[686]: Unable to open new log file '/var/log/samb
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:07:46, 0] …/lib/util/debu
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:07:46, 0] …/source3/winbi
Nov 15 02:08:04 volumio winbind[686]: winbindd version 4.2.14-Debian started.
Nov 15 02:08:04 volumio winbind[686]: Copyright Andrew Tridgell and the Samba Te
Nov 15 02:08:04 volumio systemd[1]: Time has been changed
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:07:46, 0] …/lib/util/util
Nov 15 02:08:04 volumio winbind[686]: mkdir failed on directory /var/log/samba/c
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:07:46, 0] …/source3/lib/d
Nov 15 02:08:04 volumio winbind[686]: Failed to create /var/log/samba/cores for
Nov 15 02:08:04 volumio winbind[686]: Unable to setup corepath for winbindd: No
Nov 15 02:08:04 volumio winbindd[898]: [2018/11/15 02:08:04.726135, 0] …/lib/u
Nov 15 02:08:04 volumio winbindd[898]: Unable to open new log file '/var/log/sam
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:08:04.726135, 0] …/lib/ut
Nov 15 02:08:04 volumio winbindd[898]: [2018/11/15 02:08:04.736785, 0] …/lib/u
Nov 15 02:08:04 volumio winbind[686]: [2018/11/15 02:08:04.736785, 0] …/lib/ut
Nov 15 02:08:04 volumio nmbd[689]: Starting NetBIOS name server: nmbdmkdir faile
Nov 15 02:08:04 volumio nmbd[689]: Failed to create /var/log/samba/cores for use
Nov 15 02:08:04 volumio nmbd[689]: Unable to setup corepath for nmbd: No such fi
Nov 15 02:08:04 volumio nmbd[919]: [2018/11/15 02:08:04.751278, 0] …/lib/util/
Nov 15 02:08:04 volumio nmbd[919]: Unable to open new log file '/var/log/samba/l
Nov 15 02:08:04 volumio nmbd[919]: [2018/11/15 02:08:04.754138, 0] …/lib/util/
Nov 15 02:08:04 volumio dnsmasq[931]: started, version 2.72 cachesize 150
Nov 15 02:08:04 volumio dnsmasq[931]: compile time options: IPv6 GNU-getopt DBus
Nov 15 02:08:04 volumio dnsmasq[931]: reading /etc/resolv.conf
Nov 15 02:08:04 volumio dnsmasq[931]: using nameserver 75.75.75.75#53
Nov 15 02:08:04 volumio dnsmasq[931]: using nameserver 75.75.76.76#53
Nov 15 02:08:04 volumio dnsmasq[931]: using nameserver 208.67.222.222#53
Nov 15 02:08:04 volumio dnsmasq[931]: using nameserver 208.67.220.220#53
Nov 15 02:08:04 volumio dnsmasq[931]: read /etc/hosts - 1 addresses
Nov 15 02:08:04 volumio nmbd[932]: [2018/11/15 02:08:04.764086, 0] …/source3/n
Nov 15 02:08:04 volumio nmbd[932]: started asyncdns process 933
Nov 15 02:08:04 volumio systemd[1]: Started LSB: start Samba NetBIOS nameserver
Nov 15 02:08:04 volumio systemd[1]: Started dnsmasq.service.
Nov 15 02:08:04 volumio systemd[1]: Starting Host and Network Name Lookups.
Nov 15 02:08:04 volumio systemd[1]: Reached target Host and Network Name Lookups
Nov 15 02:08:04 volumio systemd[1]: Starting LSB: start Samba SMB/CIFS daemon (s
Nov 15 02:08:04 volumio nmbd[689]: [2018/11/15 02:08:04, 0] …/lib/util/debug.c
Nov 15 02:08:04 volumio nmbd[689]: Unable to open new log file '/var/log/samba/l
Nov 15 02:08:04 volumio nmbd[689]: [2018/11/15 02:08:04, 0] …/source3/nmbd/nmb
Nov 15 02:08:04 volumio nmbd[689]: nmbd version 4.2.14-Debian started.
Nov 15 02:08:04 volumio nmbd[689]: Copyright Andrew Tridgell and the Samba Team
Nov 15 02:08:04 volumio nmbd[689]: [2018/11/15 02:08:04.751278, 0] …/lib/util/
Nov 15 02:08:04 volumio nmbd[689]: [2018/11/15 02:08:04.754138, 0] …/lib/util/
Nov 15 02:08:04 volumio dhcpd[916]: Internet Systems Consortium DHCP Server 4.3.
Nov 15 02:08:04 volumio dhcpd[916]: Copyright 2004-2014 Internet Systems Consort
Nov 15 02:08:04 volumio nmbd[932]: [2018/11/15 02:08:04.807423, 0] …/lib/util/
Nov 15 02:08:04 volumio dhcpd[916]: All rights reserved.
Nov 15 02:08:04 volumio nmbd[932]: STATUS=daemon ‘nmbd’ finished starting up and
Nov 15 02:08:04 volumio dhcpd[916]: For info, please visit isc.org/s
Nov 15 02:08:04 volumio dhcpd[916]: Config file: /etc/dhcp/dhcpd.conf
Nov 15 02:08:04 volumio dhcpd[916]: Database file: /var/lib/dhcp/dhcpd.leases
Nov 15 02:08:04 volumio dhcpd[916]: PID file: /var/run/dhcpd.pid
Nov 15 02:08:04 volumio hotspot[916]: Internet Systems Consortium DHCP Server 4.
Nov 15 02:08:04 volumio hotspot[916]: Copyright 2004-2014 Internet Systems Conso
Nov 15 02:08:04 volumio hotspot[916]: All rights reserved.
Nov 15 02:08:04 volumio hotspot[916]: For info, please visit isc.org
Nov 15 02:08:04 volumio hotspot[916]: Config file: /etc/dhcp/dhcpd.conf
Nov 15 02:08:04 volumio hotspot[916]: Database file: /var/lib/dhcp/dhcpd.leases
Nov 15 02:08:04 volumio hotspot[916]: PID file: /var/run/dhcpd.pid
Nov 15 02:08:04 volumio nmbd[689]: .
Nov 15 02:08:04 volumio winbindd[941]: [2018/11/15 02:08:04.858880, 0] …/sourc
Nov 15 02:08:04 volumio winbindd[941]: initialize_winbindd_cache: clearing cache
Nov 15 02:08:04 volumio systemd[1]: Started LSB: start Winbind daemon.
Nov 15 02:08:04 volumio winbind[686]: .
Nov 15 02:08:04 volumio dhcpd[916]: Wrote 0 leases to leases file.
Nov 15 02:08:04 volumio hotspot[916]: Wrote 0 leases to leases file.
Nov 15 02:08:04 volumio winbindd[941]: [2018/11/15 02:08:04.932292, 0] …/lib/u
Nov 15 02:08:04 volumio winbindd[941]: STATUS=daemon ‘winbindd’ finished startin
Nov 15 02:08:04 volumio winbindd[942]: [2018/11/15 02:08:04.941753, 0] …/lib/u
Nov 15 02:08:04 volumio winbindd[942]: Unable to open new log file '/var/log/sam
Nov 15 02:08:04 volumio dhcpd[916]: Listening on LPF/wlan0/b8:27:eb:74:16:ca/192
Nov 15 02:08:04 volumio dhcpd[916]: Sending on LPF/wlan0/b8:27:eb:74:16:ca/192
Nov 15 02:08:04 volumio dhcpd[916]: No subnet declaration for eth0 (192.168.0.13
Nov 15 02:08:04 volumio dhcpd[916]: ** Ignoring requests on eth0. If this is no
Nov 15 02:08:04 volumio dhcpd[916]: you want, please write a subnet declaration
Nov 15 02:08:04 volumio dhcpd[916]: in your dhcpd.conf file for the network segm
Nov 15 02:08:04 volumio dhcpd[916]: to which interface eth0 is attached. **
Nov 15 02:08:04 volumio dhcpd[916]: Sending on Socket/fallback/fallback-net
Nov 15 02:08:05 volumio dhcpd[943]: Server starting service.
Nov 15 02:08:05 volumio systemd[1]: Started dhcpd.service.
Nov 15 02:08:05 volumio hotspot[916]: Listening on LPF/wlan0/b8:27:eb:74:16:ca/1
Nov 15 02:08:05 volumio hotspot[916]: Sending on LPF/wlan0/b8:27:eb:74:16:ca/1
Nov 15 02:08:05 volumio hotspot[916]: No subnet declaration for eth0 (192.168.0.
Nov 15 02:08:05 volumio hotspot[916]: ** Ignoring requests on eth0. If this is
Nov 15 02:08:05 volumio hotspot[916]: you want, please write a subnet declaratio
Nov 15 02:08:05 volumio hotspot[916]: in your dhcpd.conf file for the network se
Nov 15 02:08:05 volumio hotspot[916]: to which interface eth0 is attached. **
Nov 15 02:08:05 volumio hotspot[916]: Sending on Socket/fallback/fallback-net
Nov 15 02:08:05 volumio ntpd[776]: Listen normally on 4 wlan0 192.168.211.1 UDP
Nov 15 02:08:05 volumio ntpd[776]: peers refreshed
Nov 15 02:08:06 volumio smbd[934]: Starting SMB/CIFS daemon: smbd[2018/11/15 02:
Nov 15 02:08:06 volumio smbd[934]: Unable to open new log file '/var/log/samba/l
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06, 0] …/lib/util/util.c:
Nov 15 02:08:06 volumio smbd[934]: mkdir failed on directory /var/log/samba/core
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06, 0] …/source3/lib/dump
Nov 15 02:08:06 volumio smbd[934]: Failed to create /var/log/samba/cores for use
Nov 15 02:08:06 volumio smbd[934]: Unable to setup corepath for smbd: No such fi
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06, 0] …/lib/util/debug.c
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06, 0] …/source3/smbd/ser
Nov 15 02:08:06 volumio smbd[934]: smbd version 4.2.14-Debian started.
Nov 15 02:08:06 volumio smbd[934]: Copyright Andrew Tridgell and the Samba Team
Nov 15 02:08:06 volumio smbd[947]: [2018/11/15 02:08:06.550695, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[947]: Unable to open new log file '/var/log/samba/l
Nov 15 02:08:06 volumio smbd[947]: [2018/11/15 02:08:06.553305, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[947]: [2018/11/15 02:08:06.553609, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06.550695, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06.553305, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[934]: [2018/11/15 02:08:06.553609, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[934]: .
Nov 15 02:08:06 volumio systemd[1]: Started LSB: start Samba SMB/CIFS daemon (sm
Nov 15 02:08:06 volumio winbindd[951]: [2018/11/15 02:08:06.662929, 0] …/lib/u
Nov 15 02:08:06 volumio winbindd[951]: Unable to open new log file '/var/log/sam
Nov 15 02:08:06 volumio winbindd[952]: [2018/11/15 02:08:06.719143, 0] …/lib/u
Nov 15 02:08:06 volumio winbindd[952]: Unable to open new log file '/var/log/sam
Nov 15 02:08:06 volumio smbd[948]: [2018/11/15 02:08:06.794657, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[948]: STATUS=daemon ‘smbd’ finished starting up and
Nov 15 02:08:06 volumio smbd[953]: [2018/11/15 02:08:06.802184, 0] …/lib/util/
Nov 15 02:08:06 volumio smbd[953]: Unable to open new log file '/var/log/samba/l
Nov 15 02:08:09 volumio hotspot[915]: Launching Ordinary Hostapd
Nov 15 02:08:09 volumio netplugd[922]: wlan0: state DOWN flags 0x00001003 UP,BRO
Nov 15 02:08:09 volumio netplugd[963]: /etc/netplug/netplug wlan0 in -> pid 963
Nov 15 02:08:09 volumio netplugd[922]: wlan0: state INNING pid 963 exited status
Nov 15 02:08:10 volumio volumio[924]: info: ------------------------------------
Nov 15 02:08:10 volumio volumio[924]: info: ----- Volumio2
Nov 15 02:08:10 volumio volumio[924]: info: ----- System startup
Nov 15 02:08:11 volumio volumio[924]: info: Plugin folders cleanup
Nov 15 02:08:11 volumio volumio[924]: info: Scanning into folder /volumio/app/pl
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category audio_interface
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category miscellanea
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category music_service
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category plugins.json
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category system_controller
Nov 15 02:08:11 volumio volumio[924]: info: Scanning category user_interface
Nov 15 02:08:11 volumio volumio[924]: info: Scanning into folder /data/plugins/
Nov 15 02:08:11 volumio volumio[924]: info: Plugin folders cleanup completed
Nov 15 02:08:11 volumio volumio[924]: info: Loading plugins from folder /volumio
Nov 15 02:08:11 volumio volumio[924]: info: Loading plugins from folder /data/pl
Nov 15 02:08:11 volumio volumio[924]: info: Loading plugin “system”…
Nov 15 02:08:11 volumio volumio[924]: info: Loading plugin “appearance”…
Nov 15 02:08:11 volumio volumio-remote-updater[677]: [2018-11-15 02:08:11] [conn
Nov 15 02:08:13 volumio volumio[924]: info: Loading plugin “network”…
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “services”…
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “alsa_controller”…
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “wizard”…
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin "volumio_command_line
Nov 15 02:08:14 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “upnp”…
Nov 15 02:08:14 volumio volumio[924]: info: [1542247694360] Starting Upmpd Daemo
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “mpd”…
Nov 15 02:08:14 volumio volumio[924]: info: Loading plugin “upnp_browser”…
Nov 15 02:08:16 volumio volumio[924]: info: Loading plugin “networkfs”…
Nov 15 02:08:16 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:16 volumio volumio[924]: info: Loading plugin “alarm-clock”…
Nov 15 02:08:16 volumio sudo[979]: volumio : TTY=unknown ; PWD=/ ; USER=root ; C
Nov 15 02:08:16 volumio sudo[979]: pam_unix(sudo:session): session opened for us
Nov 15 02:08:16 volumio kernel: FS-Cache: Netfs ‘cifs’ registered for caching
Nov 15 02:08:16 volumio kernel: Key type cifs.spnego registered
Nov 15 02:08:16 volumio kernel: Key type cifs.idmap registered
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “airplay_emulation”…
Nov 15 02:08:17 volumio volumio[924]: info: [1542247697114] Starting Shairport S
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “last_100”…
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “webradio”…
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “i2s_dacs”…
Nov 15 02:08:17 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “volumiodiscovery”…
Nov 15 02:08:17 volumio volumio[924]: *** WARNING *** The program ‘node’ uses th
Nov 15 02:08:17 volumio node[924]: *** WARNING *** The program ‘node’ uses the A
Nov 15 02:08:17 volumio node[924]: *** WARNING *** Please fix your application t
Nov 15 02:08:17 volumio node[924]: *** WARNING *** For more information see <htt
Nov 15 02:08:17 volumio node[924]: *** WARNING *** The program ‘node’ called 'DN
Nov 15 02:08:17 volumio volumio[924]: *** WARNING *** Please fix your applicatio
Nov 15 02:08:17 volumio volumio[924]: *** WARNING *** For more information see <
Nov 15 02:08:17 volumio volumio[924]: *** WARNING *** The program ‘node’ called
Nov 15 02:08:17 volumio volumio[924]: info: Applying required configuration para
Nov 15 02:08:17 volumio volumio[924]: Discovery: StartAdv! undefined
Nov 15 02:08:17 volumio volumio[924]: Discovery: Started advertising… Volumio
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “albumart”…
Nov 15 02:08:17 volumio volumio[924]: info: Plugin example_plugin is not enabled
Nov 15 02:08:17 volumio volumio[924]: info: Loading plugin “updater_comm”…
Nov 15 02:08:17 volumio sudo[979]: pam_unix(sudo:session): session closed for us
Nov 15 02:08:18 volumio volumio[924]: info: Plugin mpdemulation is not enabled
Nov 15 02:08:18 volumio volumio[924]: info: Loading plugin “rest_api”…
Nov 15 02:08:18 volumio volumio[924]: info: Loading plugin “websocket”…
Nov 15 02:08:18 volumio volumio[924]: info: ___________ START PLUGINS __________
Nov 15 02:08:18 volumio volumio[924]: info: PLUGIN START: appearance
Nov 15 02:08:18 volumio volumio[924]: info: PLUGIN START: wizard
Nov 15 02:08:18 volumio volumio[924]: info: PLUGIN START: upnp_browser
Nov 15 02:08:18 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:18 volumio volumio[924]: info: CoreCommandRouter::volumioAddToBrows
Nov 15 02:08:18 volumio volumio[924]: info: [1542247698416] CoreMusicLibrary::Ad
Nov 15 02:08:18 volumio volumio[924]: info: PLUGIN START: last_100
Nov 15 02:08:18 volumio volumio[924]: info: [1542247698459] CoreMusicLibrary::Ad
Nov 15 02:08:18 volumio volumio[924]: info: PLUGIN START: webradio
Nov 15 02:08:18 volumio volumio[924]: info: [1542247698467] CoreMusicLibrary::Ad
Nov 15 02:08:18 volumio volumio[924]: info: Loading i18n strings for locale en
Nov 15 02:08:18 volumio volumio[924]: Updating browse sources language
Nov 15 02:08:18 volumio volumio[924]: Cannot find translation for sourceMedia Se
Nov 15 02:08:18 volumio volumio[924]: info: CoreCommandRouter::initPlayerControl
Nov 15 02:08:18 volumio volumio[924]: info: BOOT COMPLETED
Nov 15 02:08:18 volumio volumio[924]: info: CoreCommandRouter::Close All Modals
Nov 15 02:08:18 volumio volumio[924]: Express server listening on port 3000
Nov 15 02:08:18 volumio volumio[924]: Volumio Calling Home
Nov 15 02:08:19 volumio kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Nov 15 02:08:19 volumio kernel: pcm512x 1-004d: No SCLK, using BCLK: -2
Nov 15 02:08:19 volumio volumio[924]: info: CoreStateMachine::resetVolumioState
Nov 15 02:08:19 volumio volumio[924]: info: CoreStateMachine::getcurrentVolume
Nov 15 02:08:19 volumio volumio[924]: info: CoreCommandRouter::volumioRetrievevo
Nov 15 02:08:19 volumio volumio[924]: info: CoreStateMachine::updateTrackBlock
Nov 15 02:08:19 volumio volumio[924]: info: CorePlayQueue::getTrackBlock
Nov 15 02:08:20 volumio volumio[924]: info: Setting Device type: Raspberry PI
Nov 15 02:08:20 volumio volumio[924]: info: MPD running with PID713 ,establishin
Nov 15 02:08:21 volumio volumio[924]: info: VolumeController:: Volume=14 Mute =f
Nov 15 02:08:21 volumio volumio[924]: info: CoreStateMachine::pushState
Nov 15 02:08:21 volumio volumio[924]: info: CoreStateMachine::getState
Nov 15 02:08:21 volumio volumio[924]: info: CorePlayQueue::getTrack 0
Nov 15 02:08:21 volumio volumio[924]: info: CoreCommandRouter::volumioPushState
Nov 15 02:08:21 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:21 volumio volumio[924]: info: interfaceApi::pushState
Nov 15 02:08:21 volumio volumio[924]: info: Volumio called home
Nov 15 02:08:21 volumio volumio[924]: info: Pushing Favourites {“service”:“mpd”,
Nov 15 02:08:22 volumio volumio[924]: info: Reloading queue from file
Nov 15 02:08:22 volumio volumio[924]: info: CoreStateMachine::setRepeat null sin
Nov 15 02:08:22 volumio volumio[924]: info: CoreStateMachine::pushState
Nov 15 02:08:22 volumio volumio[924]: info: CoreStateMachine::getState
Nov 15 02:08:22 volumio volumio[924]: info: CorePlayQueue::getTrack 0
Nov 15 02:08:22 volumio volumio[924]: info: CoreCommandRouter::volumioPushState
Nov 15 02:08:22 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:22 volumio volumio[924]: info: interfaceApi::pushState
Nov 15 02:08:22 volumio volumio[924]: info: CoreStateMachine::setRandom null
Nov 15 02:08:22 volumio volumio[924]: info: Pushing Favourites {“service”:“mpd”,
Nov 15 02:08:22 volumio volumio[924]: info: CoreCommandRouter::volumioGetState
Nov 15 02:08:22 volumio sudo[1058]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:08:22 volumio volumio[924]: Plugin multiroom or method getMultiroom no
Nov 15 02:08:22 volumio volumio[924]: info: Listing playlists
Nov 15 02:08:22 volumio volumio[924]: info: CoreCommandRouter::volumioGetBrowseS
Nov 15 02:08:22 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue
Nov 15 02:08:22 volumio sudo[1058]: pam_unix(sudo:session): session opened for u
Nov 15 02:08:22 volumio volumio[924]: info: CoreStateMachine::getQueue
Nov 15 02:08:22 volumio volumio[924]: info: CorePlayQueue::getQueue
Nov 15 02:08:22 volumio systemd[1]: Starting ShairportSync AirTunes receiver…
Nov 15 02:08:22 volumio systemd[1]: Started ShairportSync AirTunes receiver.
Nov 15 02:08:22 volumio sudo[1058]: pam_unix(sudo:session): session closed for u
Nov 15 02:08:22 volumio shairport-sync[1063]: Successful Startup
Nov 15 02:08:23 volumio volumio[924]: Discovery: adding ff20a633-96d5-448a-890e-
Nov 15 02:08:23 volumio volumio[924]: info: mDNS: Found device Volumio
Nov 15 02:08:23 volumio volumio[924]: info: [1542247703172] Shairport-Sync Start
Nov 15 02:08:23 volumio volumio[924]: Error adding Membership: Error: addMembers
Nov 15 02:08:23 volumio volumio[924]: Discovery: this is already registered, ff
Nov 15 02:08:23 volumio volumio[924]: info: CoreCommandRouter::volumioGetState
Nov 15 02:08:23 volumio volumio[924]: info: CoreStateMachine::getState
Nov 15 02:08:23 volumio volumio[924]: info: CorePlayQueue::getTrack 0
Nov 15 02:08:24 volumio volumio[924]: info: CoreCommandRouter::Close All Modals
Nov 15 02:08:24 volumio sudo[1078]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:08:24 volumio sudo[1078]: pam_unix(sudo:session): session opened for u
Nov 15 02:08:24 volumio systemd[1]: Starting UPnP Renderer front-end to MPD…
Nov 15 02:08:24 volumio systemd[1]: Started UPnP Renderer front-end to MPD.
Nov 15 02:08:24 volumio sudo[1078]: pam_unix(sudo:session): session closed for u
Nov 15 02:08:24 volumio volumio[924]: info: Upmpdcli Daemon Started
Nov 15 02:08:25 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:26 volumio volumio-remote-updater[677]: [2018-11-15 02:08:26] [conn
Nov 15 02:08:31 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:31 volumio volumio[924]: info: CURURI: music-library
Nov 15 02:08:31 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:08:34 volumio udisks-glue[675]: error: Timeout
Nov 15 02:08:41 volumio volumio[924]: info: CoreCommandRouter::volumioGetState
Nov 15 02:08:41 volumio volumio[924]: info: CoreStateMachine::getState
Nov 15 02:08:41 volumio volumio[924]: info: CorePlayQueue::getTrack 0
Nov 15 02:08:41 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue
Nov 15 02:08:41 volumio volumio[924]: info: CoreStateMachine::getQueue
Nov 15 02:08:41 volumio volumio[924]: info: CorePlayQueue::getQueue
Nov 15 02:08:52 volumio volumio[924]: info: CALLMETHOD: system_controller system
Nov 15 02:08:52 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:52 volumio volumio[924]: info: Device is now in test mode
Nov 15 02:08:56 volumio volumio[924]: info: CALLMETHOD: system_controller system
Nov 15 02:08:56 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:08:56 volumio sudo[1093]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:08:56 volumio sudo[1093]: pam_unix(sudo:session): session opened for u
Nov 15 02:08:56 volumio systemd[1]: Started OpenBSD Secure Shell server.
Nov 15 02:08:56 volumio sudo[1093]: pam_unix(sudo:session): session closed for u
Nov 15 02:08:56 volumio sudo[1101]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:08:56 volumio sudo[1101]: pam_unix(sudo:session): session opened for u
Nov 15 02:08:57 volumio systemd[1]: Reloading.
Nov 15 02:08:57 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown
Nov 15 02:08:57 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown
Nov 15 02:08:57 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown
Nov 15 02:08:57 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown
Nov 15 02:08:58 volumio systemd[1]: Reloading.
Nov 15 02:08:58 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown
Nov 15 02:08:58 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown
Nov 15 02:08:58 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown
Nov 15 02:08:58 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown
Nov 15 02:08:58 volumio sudo[1101]: pam_unix(sudo:session): session closed for u
Nov 15 02:08:58 volumio volumio[924]: info: enable SSH service success
Nov 15 02:08:58 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:09:02 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:09:21 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:09:27 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:09:31 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:09:38 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:10:28 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:10:48 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:10:55 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:10:57 volumio sshd[1151]: Invalid user voumio from 192.168.0.19
Nov 15 02:10:57 volumio sshd[1151]: input_userauth_request: invalid user voumio
Nov 15 02:11:02 volumio sshd[1151]: pam_unix(sshd:auth): check pass; user unknow
Nov 15 02:11:02 volumio sshd[1151]: pam_unix(sshd:auth): authentication failure;
Nov 15 02:11:04 volumio sshd[1151]: Failed password for invalid user voumio from
Nov 15 02:11:11 volumio sshd[1151]: pam_unix(sshd:auth): check pass; user unknow
Nov 15 02:11:13 volumio sshd[1151]: Failed password for invalid user voumio from
Nov 15 02:11:21 volumio sshd[1151]: Connection closed by 192.168.0.19 [preauth]
Nov 15 02:11:21 volumio sshd[1151]: PAM 1 more authentication failure; logname=
Nov 15 02:11:25 volumio volumio[924]: info: CALLMETHOD: system_controller system
Nov 15 02:11:25 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:11:25 volumio sudo[1159]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:11:25 volumio sudo[1159]: pam_unix(sudo:session): session opened for u
Nov 15 02:11:25 volumio systemd[1]: Started OpenBSD Secure Shell server.
Nov 15 02:11:26 volumio sudo[1159]: pam_unix(sudo:session): session closed for u
Nov 15 02:11:26 volumio sudo[1167]: volumio : TTY=unknown ; PWD=/ ; USER=root ;
Nov 15 02:11:26 volumio sudo[1167]: pam_unix(sudo:session): session opened for u
Nov 15 02:11:26 volumio systemd[1]: Reloading.
Nov 15 02:11:26 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown
Nov 15 02:11:26 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown
Nov 15 02:11:26 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown
Nov 15 02:11:26 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown
Nov 15 02:11:27 volumio systemd[1]: Reloading.
Nov 15 02:11:27 volumio systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown
Nov 15 02:11:27 volumio systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown
Nov 15 02:11:27 volumio systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown
Nov 15 02:11:27 volumio systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown
Nov 15 02:11:27 volumio sudo[1167]: pam_unix(sudo:session): session closed for u
Nov 15 02:11:27 volumio volumio[924]: info: enable SSH service success
Nov 15 02:11:28 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:11:32 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:11:54 volumio sshd[1215]: Accepted password for volumio from 192.168.0
Nov 15 02:11:54 volumio sshd[1215]: pam_unix(sshd:session): session opened for u
Nov 15 02:11:54 volumio systemd[1]: Starting user-1000.slice.
Nov 15 02:11:54 volumio systemd[1]: Created slice user-1000.slice.
Nov 15 02:11:54 volumio systemd[1]: Starting User Manager for UID 1000…
Nov 15 02:11:54 volumio systemd[1]: Starting Session c1 of user volumio.
Nov 15 02:11:54 volumio systemd[1]: Started Session c1 of user volumio.
Nov 15 02:11:54 volumio systemd-logind[685]: New session c1 of user volumio.
Nov 15 02:11:54 volumio systemd[1221]: pam_unix(systemd-user:session): session o
Nov 15 02:11:54 volumio systemd[1221]: Starting Paths.
Nov 15 02:11:54 volumio systemd[1221]: Reached target Paths.
Nov 15 02:11:54 volumio systemd[1221]: Starting Timers.
Nov 15 02:11:54 volumio systemd[1221]: Reached target Timers.
Nov 15 02:11:54 volumio systemd[1221]: Starting Sockets.
Nov 15 02:11:54 volumio systemd[1221]: Reached target Sockets.
Nov 15 02:11:54 volumio systemd[1221]: Starting Basic System.
Nov 15 02:11:54 volumio systemd[1221]: Reached target Basic System.
Nov 15 02:11:54 volumio systemd[1221]: Starting Default.
Nov 15 02:11:54 volumio systemd[1221]: Reached target Default.
Nov 15 02:11:54 volumio systemd[1221]: Startup finished in 50ms.
Nov 15 02:11:54 volumio systemd[1]: Started User Manager for UID 1000.
Nov 15 02:11:54 volumio sshd[1215]: lastlog_openseek: Couldn’t stat /var/log/las
Nov 15 02:11:55 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:12:01 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:12:48 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:12:48 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:12:48 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:13:35 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:13:41 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:14:10 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:14:16 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:14:19 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:14:34 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:14:35 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:14:35 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:14:35 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:14:39 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:14:45 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:16:05 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:16:11 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:16:13 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:16:13 volumio volumio[924]: error: MPD error: Error: read ECONNRESET
Nov 15 02:16:13 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:16:13 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:16:13 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:16:15 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:17:44 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:17:49 volumio sudo[1287]: volumio : TTY=pts/0 ; PWD=/var/log ; USER=ro
Nov 15 02:17:49 volumio sudo[1287]: pam_unix(sudo:session): session opened for u
Nov 15 02:17:49 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:17:50 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:17:50 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:17:50 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:17:51 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:17:55 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:18:01 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:18:07 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:18:11 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:18:15 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:18:17 volumio sudo[1287]: pam_unix(sudo:session): session closed for u
Nov 15 02:18:45 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:18:49 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:19:20 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:19:20 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:19:26 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:19:34 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:19:35 volumio volumio[924]: error: MPD error: Error: read ECONNRESET
Nov 15 02:19:35 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:19:35 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:19:35 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:20:10 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:20:16 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:21:05 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:21:06 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:21:10 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:21:14 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:21:14 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:21:14 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:21:14 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:21:14 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:21:25 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:21:29 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:21:33 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:21:50 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:21:56 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:22:09 volumio sshd[1215]: pam_unix(sshd:session): session closed for u
Nov 15 02:22:10 volumio systemd-logind[685]: Removed session c1.
Nov 15 02:22:10 volumio systemd[1]: Stopping User Manager for UID 1000…
Nov 15 02:22:10 volumio systemd[1221]: Stopping Default.
Nov 15 02:22:10 volumio systemd[1221]: Stopped target Default.
Nov 15 02:22:10 volumio systemd[1221]: Stopping Basic System.
Nov 15 02:22:10 volumio systemd[1221]: Stopped target Basic System.
Nov 15 02:22:10 volumio systemd[1221]: Stopping Paths.
Nov 15 02:22:10 volumio systemd[1221]: Stopped target Paths.
Nov 15 02:22:10 volumio systemd[1221]: Stopping Timers.
Nov 15 02:22:10 volumio systemd[1221]: Stopped target Timers.
Nov 15 02:22:10 volumio systemd[1221]: Stopping Sockets.
Nov 15 02:22:10 volumio systemd[1221]: Stopped target Sockets.
Nov 15 02:22:10 volumio systemd[1221]: Starting Shutdown.
Nov 15 02:22:10 volumio systemd[1221]: Reached target Shutdown.
Nov 15 02:22:10 volumio systemd[1221]: Starting Exit the Session…
Nov 15 02:22:10 volumio systemd[1221]: Received SIGRTMIN+24 from PID 1568 (kill)
Nov 15 02:22:10 volumio systemd[1224]: pam_unix(systemd-user:session): session c
Nov 15 02:22:10 volumio systemd[1]: Stopped User Manager for UID 1000.
Nov 15 02:22:10 volumio systemd[1]: Stopping user-1000.slice.
Nov 15 02:22:10 volumio systemd[1]: Removed slice user-1000.slice.
Nov 15 02:22:11 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:22:15 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:22:39 volumio systemd[1]: Starting Cleanup of Temporary Directories…
Nov 15 02:22:39 volumio systemd[1]: Started Cleanup of Temporary Directories.
Nov 15 02:22:40 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:22:44 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:22:46 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:23:00 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:23:00 volumio volumio[924]: error: MPD error: Error: read ECONNRESET
Nov 15 02:23:00 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:23:00 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:23:00 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:23:03 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:23:07 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:23:36 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:23:42 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:23:48 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:23:55 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:24:11 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:24:15 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:24:31 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:24:43 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:24:43 volumio volumio[924]: error: MPD error: Error: read ECONNRESET
Nov 15 02:24:43 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:24:43 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:24:43 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:26:10 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:26:13 volumio systemd[1]: mpd.service start operation timed out. Termi
Nov 15 02:26:16 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:26:21 volumio volumio[924]: Upnp client error: Error: This socket has
Nov 15 02:26:22 volumio systemd[1]: Failed to start Music Player Daemon.
Nov 15 02:26:22 volumio systemd[1]: Unit mpd.service entered failed state.
Nov 15 02:26:22 volumio systemd[1]: Starting Music Player Daemon…
Nov 15 02:26:22 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:26:28 volumio kernel: Voltage normalised (0x00000000)
Nov 15 02:27:06 volumio kernel: Under-voltage detected! (0x00050005)
Nov 15 02:27:06 volumio volumio[924]: info: CoreCommandRouter::volumioGetState
Nov 15 02:27:06 volumio volumio[924]: info: CoreStateMachine::getState
Nov 15 02:27:06 volumio volumio[924]: info: CorePlayQueue::getTrack 0
Nov 15 02:27:07 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin:
Nov 15 02:27:07 volumio volumio[924]: Plugin multiroom or method getMultiroom no
Nov 15 02:27:07 volumio volumio[924]: info: Listing playlists
Nov 15 02:27:07 volumio volumio[924]: info: No input data
Nov 15 02:27:11 volumio volumio[924]: info: CoreCommandRouter::volumioGetBrowseS
Nov 15 02:27:11 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue
Nov 15 02:27:11 volumio volumio[924]: info: CoreStateMachine::getQueue
Nov 15 02:27:11 volumio volumio[924]: info: CorePlayQueue::getQueue
Nov 15 02:27:11 volumio volumio[924]: info: No input data
There is no – __ ___//\ \ __ __ ___ ___ /_\ ___ option (press Nov 15 02:27:06 volumio kernel: Under-voltage detected! (0x00050005)
There is no -- __ ___\//\ \ __ __ ___ ___ /\_\ ___ option (press Nov 15 02:27:06 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:27:06 volumio volumio[924]: info: CoreCommandRouter::volumioGetState Nov 15 02:27:06 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:27:06 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:27:07 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:27:07 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:27:07 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:27:07 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:27:07 volumio volumio[924]: Plugin multiroom or method getMultiroom no Nov 15 02:27:07 volumio volumio[924]: info: Listing playlists Nov 15 02:27:07 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: CoreCommandRouter::volumioGetBrowseS Nov 15 02:27:11 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue Nov 15 02:27:11 volumio volumio[924]: info: CoreStateMachine::getQueue Nov 15 02:27:11 volumio volumio[924]: info: CorePlayQueue::getQueue Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:11 volumio volumio[924]: info: No input data Nov 15 02:27:13 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:27:13 volumio volumio[924]: info: CURURI: music-library Nov 15 02:27:16 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:27:42 volumio volumio[924]: info: CoreCommandRouter::volumioGetState Nov 15 02:27:42 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:27:42 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:27:42 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue Nov 15 02:27:42 volumio volumio[924]: info: CoreStateMachine::getQueue Nov 15 02:27:42 volumio volumio[924]: info: CorePlayQueue::getQueue Nov 15 02:27:43 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:27:47 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:27:52 volumio systemd[1]: mpd.service start operation timed out. Termi Nov 15 02:28:06 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:28:06 volumio volumio[924]: error: MPD error: Error: read ECONNRESET Nov 15 02:28:06 volumio systemd[1]: Failed to start Music Player Daemon. Nov 15 02:28:06 volumio systemd[1]: Unit mpd.service entered failed state. Nov 15 02:28:06 volumio systemd[1]: Starting Music Player Daemon... Nov 15 02:28:08 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:28:12 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:28:21 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:28:31 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:29:17 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:29:21 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:29:37 volumio systemd[1]: mpd.service start operation timed out. Termi Nov 15 02:29:50 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:29:50 volumio volumio[924]: error: MPD error: Error: read ECONNRESET Nov 15 02:29:50 volumio systemd[1]: Failed to start Music Player Daemon. Nov 15 02:29:50 volumio systemd[1]: Unit mpd.service entered failed state. Nov 15 02:29:50 volumio systemd[1]: Starting Music Player Daemon... Nov 15 02:29:52 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:30:09 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:30:11 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:30:15 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:31:09 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:31:10 volumio volumio[924]: info: CoreCommandRouter::volumioGetState Nov 15 02:31:10 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:31:10 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:31:11 volumio volumio[924]: info: No input data Nov 15 02:31:11 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:11 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:11 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:11 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:11 volumio volumio[924]: Plugin multiroom or method getMultiroom no Nov 15 02:31:11 volumio volumio[924]: info: Listing playlists Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::getUIConfigOnPlug Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:15 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:31:21 volumio systemd[1]: mpd.service start operation timed out. Termi Nov 15 02:31:25 volumio volumio[924]: info: CoreCommandRouter::volumioGetBrowseS Nov 15 02:31:25 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue Nov 15 02:31:25 volumio volumio[924]: info: CoreStateMachine::getQueue Nov 15 02:31:25 volumio volumio[924]: info: CorePlayQueue::getQueue Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:25 volumio volumio[924]: info: No input data Nov 15 02:31:32 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:31:40 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:31:40 volumio volumio[924]: error: MPD error: Error: read ECONNRESET Nov 15 02:31:40 volumio systemd[1]: Failed to start Music Player Daemon. Nov 15 02:31:40 volumio systemd[1]: Unit mpd.service entered failed state. Nov 15 02:31:40 volumio systemd[1]: Starting Music Player Daemon... Nov 15 02:31:40 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:31:47 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:31:49 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:31:53 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:32:10 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:32:16 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:32:53 volumio kernel: usb 1-1.2: USB disconnect, device number 5 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=54074 count=1 b Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189211 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189230 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189247 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189265 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189296 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=38489 count=1 b Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=54170 count=1 b Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189464 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189514 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189530 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=235552 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189546 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189580 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189596 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=189610 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=192540 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=193263 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=7027 count=1 br Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=194517 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=194630 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=194792 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=194978 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=195249 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=23823 count=1 b Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=39771 count=1 b Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read of MFT, mft=195918 count=1 Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x5: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x6: Input/output error Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x22: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x22: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x22: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x22: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio ntfs-3g[886]: ntfs_attr_pread_i: ntfs_pread failed: Inpu Nov 15 02:32:55 volumio ntfs-3g[886]: Failed to read vcn 0x56: Input/output erro Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: sd 1:0:0:0: [sdb] Synchronizing SCSI cache Nov 15 02:32:55 volumio kernel: sd 1:0:0:0: [sdb] Synchronize Cache(10) failed: Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio kernel: blk_partition_remap: fail for partition 2 Nov 15 02:32:55 volumio udisks-glue[675]: Device file /dev/sdb2 unmounted from / Nov 15 02:32:55 volumio udisks-glue[675]: Device file /dev/sdb2 removed Nov 15 02:32:55 volumio udisks-glue[675]: Device file /dev/sdb1 removed Nov 15 02:32:55 volumio udisks-glue[675]: Device file /dev/sdb removed Nov 15 02:32:55 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:32:56 volumio ntfs-3g[886]: Unmounting /dev/sdb2 (Seagate Expansion Dr Nov 15 02:32:56 volumio ntfs-3g[886]: Failed to sync device /dev/sdb2: Input/out Nov 15 02:32:56 volumio ntfs-3g[886]: Failed to close volume /dev/sdb2: Input/ou Nov 15 02:32:56 volumio systemd[1]: Started Music Player Daemon. Nov 15 02:32:56 volumio systemd[1]: Starting Multi-User System. Nov 15 02:32:56 volumio systemd[1]: Reached target Multi-User System. Nov 15 02:32:56 volumio systemd[1]: Starting Graphical Interface. Nov 15 02:32:56 volumio systemd[1]: Reached target Graphical Interface. Nov 15 02:32:56 volumio systemd[1]: Starting Update UTMP about System Runlevel C Nov 15 02:32:56 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:32:56 volumio udisks-glue[675]: Updating DB (#1) ... Nov 15 02:32:56 volumio udisks-glue[675]: volume: 40% repeat: off random: of Nov 15 02:32:56 volumio volumio[924]: info: Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:56 volumio volumio[924]: info: Nov 15 02:32:56 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:32:56 volumio volumio[924]: info: sending command... Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:56 volumio volumio[924]: info: sending command... Nov 15 02:32:56 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:32:56 volumio volumio[924]: Upnp client error: Error: This socket has Nov 15 02:32:56 volumio udisks-glue[675]: Updating DB (#1) ... Nov 15 02:32:56 volumio udisks-glue[675]: volume: 40% repeat: off random: of Nov 15 02:32:56 volumio volumio[924]: info: parsing response... Nov 15 02:32:56 volumio volumio[924]: info: parsing response... Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:56 volumio systemd[1]: Started Update UTMP about System Runlevel Ch Nov 15 02:32:56 volumio systemd[1]: Startup finished in 9.040s (kernel) + 25min Nov 15 02:32:56 volumio volumio[924]: info: Command Router : Notfying DB Updatet Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:56 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:32:56 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:32:56 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:56 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:32:56 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:56 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:56 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:56 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:56 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:56 volumio volumio[924]: info: No code Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:56 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:56 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:56 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:56 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:56 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:56 volumio volumio[924]: info: ------------------------------ 269ms Nov 15 02:32:56 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:56 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:57 volumio volumio[924]: info: MPD Database updated - AlbumList cac Nov 15 02:32:57 volumio volumio[924]: info: Nov 15 02:32:57 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:32:57 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:57 volumio volumio[924]: info: Nov 15 02:32:57 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:32:57 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:32:57 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:57 volumio volumio[924]: info: sending command... Nov 15 02:32:57 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:32:57 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:57 volumio volumio[924]: info: sending command... Nov 15 02:32:57 volumio volumio[924]: info: sending command... Nov 15 02:32:58 volumio volumio[924]: info: parsing response... Nov 15 02:32:58 volumio volumio[924]: info: parsing response... Nov 15 02:32:58 volumio volumio[924]: info: parsing response... Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:58 volumio volumio[924]: info: Command Router : Notfying DB Updatet Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::Close All Modals Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:32:58 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: No code Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:32:58 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: No code Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: ------------------------------ 506ms Nov 15 02:32:58 volumio volumio[924]: info: ------------------------------ 509ms Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:58 volumio volumio[924]: info: Nov 15 02:32:58 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:32:58 volumio volumio[924]: info: sending command... Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:32:58 volumio volumio[924]: info: sending command... Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:58 volumio volumio[924]: info: parsing response... Nov 15 02:32:58 volumio volumio[924]: info: parsing response... Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:58 volumio volumio[924]: info: Command Router : Notfying DB Updatef Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::Close All Modals Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:32:58 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:32:58 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: No code Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:32:58 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:32:58 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:32:58 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:32:58 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:32:58 volumio volumio[924]: info: ------------------------------ 175ms Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:32:58 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:33:01 volumio volumio[924]: info: Nov 15 02:33:01 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:33:01 volumio volumio[924]: info: sending command... Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:33:01 volumio volumio[924]: info: sending command... Nov 15 02:33:01 volumio volumio[924]: info: parsing response... Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:33:01 volumio volumio[924]: info: Command Router : Notfying DB Updatet Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::Close All Modals Nov 15 02:33:01 volumio volumio[924]: info: parsing response... Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:33:01 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:01 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:33:01 volumio volumio[924]: info: No code Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:01 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:33:01 volumio volumio[924]: info: ------------------------------ 87ms Nov 15 02:33:01 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:33:01 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:33:01 volumio volumio[924]: info: Nov 15 02:33:01 volumio volumio[924]: ---------------------------- MPD announces Nov 15 02:33:01 volumio volumio[924]: info: sending command... Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::getState Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::sendMpdCommand status Nov 15 02:33:01 volumio volumio[924]: info: sending command... Nov 15 02:33:01 volumio volumio[924]: info: parsing response... Nov 15 02:33:01 volumio volumio[924]: info: parsing response... Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:33:01 volumio volumio[924]: info: Command Router : Notfying DB Updatef Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::Close All Modals Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::parseState Nov 15 02:33:01 volumio volumio[924]: info: ControllerMpd::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::servicePushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: STATE SERVICE {"status":"stop","posi Nov 15 02:33:01 volumio volumio[924]: info: CURRENT POSITION 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState stateS Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::syncState curren Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:01 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:33:01 volumio volumio[924]: info: No code Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::pushState Nov 15 02:33:01 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:33:01 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::volumioPushState Nov 15 02:33:01 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:01 volumio volumio[924]: info: interfaceApi::pushState Nov 15 02:33:01 volumio volumio[924]: info: ------------------------------ 76ms Nov 15 02:33:01 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:33:01 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 15 02:33:02 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:33:31 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:33:37 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:33:40 volumio volumio[924]: info: CoreCommandRouter::volumioGetState Nov 15 02:33:40 volumio volumio[924]: info: CoreStateMachine::getState Nov 15 02:33:40 volumio volumio[924]: info: CorePlayQueue::getTrack 0 Nov 15 02:33:40 volumio volumio[924]: info: No input data Nov 15 02:33:40 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:40 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:40 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:40 volumio volumio[924]: info: CoreCommandRouter::executeOnPlugin: Nov 15 02:33:40 volumio volumio[924]: Plugin multiroom or method getMultiroom no Nov 15 02:33:40 volumio volumio[924]: info: Listing playlists Nov 15 02:33:41 volumio kernel: Under-voltage detected! (0x00050005) Nov 15 02:33:42 volumio volumio[924]: info: CoreCommandRouter::volumioGetBrowseS Nov 15 02:33:42 volumio volumio[924]: info: CoreCommandRouter::volumioGetQueue Nov 15 02:33:42 volumio volumio[924]: info: CoreStateMachine::getQueue Nov 15 02:33:42 volumio volumio[924]: info: CorePlayQueue::getQueue Nov 15 02:33:43 volumio volumio[924]: info: No input data Nov 15 02:33:43 volumio volumio[924]: info: No input data Nov 15 02:33:43 volumio volumio[924]: info: No input data Nov 15 02:33:43 volumio vo
Nov 15 02:39:33 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:34 volumio volumio[924]: info: Preparing to unpack .../libxml2-dev_ Nov 15 02:39:34 volumio volumio[924]: info: Unpacking libxml2-dev:armhf (2.9.1+d Nov 15 02:39:35 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:35 volumio volumio[924]: info: Preparing to unpack .../libsoup2.4-d Nov 15 02:39:35 volumio volumio[924]: info: Unpacking libsoup2.4-dev (2.48.0-1+d Nov 15 02:39:36 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:36 volumio volumio[924]: info: Preparing to unpack .../libsox-fmt-a Nov 15 02:39:36 volumio volumio[924]: info: Unpacking libsox-fmt-ao:armhf (14.4. Nov 15 02:39:36 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:36 volumio volumio[924]: info: Preparing to unpack .../libtwolame0_ Nov 15 02:39:36 volumio volumio[924]: info: Unpacking libtwolame0 (0.3.13-1.1) . Nov 15 02:39:36 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:36 volumio volumio[924]: info: Preparing to unpack .../libsox-fmt-m Nov 15 02:39:36 volumio volumio[924]: info: Unpacking libsox-fmt-mp3:armhf (14.4 Nov 15 02:39:37 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:37 volumio volumio[924]: info: Preparing to unpack .../libsox-fmt-o Nov 15 02:39:37 volumio volumio[924]: info: Unpacking libsox-fmt-oss:armhf (14.4 Nov 15 02:39:37 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:37 volumio volumio[924]: info: Preparing to unpack .../libsox-fmt-p Nov 15 02:39:37 volumio volumio[924]: info: Unpacking libsox-fmt-pulse:armhf (14 Nov 15 02:39:37 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:37 volumio volumio[924]: info: Preparing to unpack .../libsox-fmt-a Nov 15 02:39:37 volumio volumio[924]: info: Unpacking libsox-fmt-all:armhf (14.4 Nov 15 02:39:37 volumio volumio[924]: info: Selecting previously unselected pack Nov 15 02:39:37 volumio volumio[924]: info: Preparing to unpack .../libsox-dev_1 Nov 15 02:39:38 volumio volumio[924]: info: Unpacking libsox-dev:armhf (14.4.1-5 Nov 15 02:39:38 volumio volumio[924]: info: Processing triggers for libglib2.0-0 Nov 15 02:39:39 volumio volumio[924]: info: Setting up libxml2:armhf (2.9.1+dfsg Nov 15 02:39:39 volumio volumio[924]: info: Setting up libdconf1:armhf (0.22.0-1 Nov 15 02:39:40 volumio volumio[924]: info: Setting up libelfg0:armhf (0.8.13-5) Nov 15 02:39:40 volumio volumio[924]: info: Setting up libjson-glib-1.0-common ( Nov 15 02:39:40 volumio volumio[924]: info: Setting up libjson-glib-1.0-0:armhf Nov 15 02:39:40 volumio volumio[924]: info: Setting up libnotify4:armhf (0.7.6-2 Nov 15 02:39:40 volumio volumio[924]: info: Setting up libpcrecpp0:armhf (2:8.35 Nov 15 02:39:40 volumio volumio[924]: info: Setting up libproxy1:armhf (0.4.11-4 Nov 15 02:39:40 volumio volumio[924]: info: Setting up glib-networking-common (2 Nov 15 02:39:40 volumio volumio[924]: info: Setting up glib-networking-services Nov 15 02:39:41 volumio volumio[924]: info: Setting up dconf-service (0.22.0-1) Nov 15 02:39:41 volumio volumio[924]: info: Setting up dconf-gsettings-backend:a Nov 15 02:39:41 volumio volumio[924]: info: Setting up gsettings-desktop-schemas Nov 15 02:39:41 volumio volumio[924]: info: Setting up glib-networking:armhf (2. Nov 15 02:39:41 volumio volumio[924]: info: Setting up libsoup2.4-1:armhf (2.48. Nov 15 02:39:41 volumio volumio[924]: info: Setting up libsoup-gnome2.4-1:armhf Nov 15 02:39:41 volumio volumio[924]: info: Setting up libx11-6:armhf (2:1.6.2-3 Nov 15 02:39:41 volumio volumio[924]: info: Setting up libgirepository-1.0-1:arm Nov 15 02:39:41 volumio volumio[924]: info: Setting up gir1.2-glib-2.0:armhf (1. Nov 15 02:39:41 volumio volumio[924]: info: Setting up gir1.2-gdkpixbuf-2.0 (2.3 Nov 15 02:39:41 volumio volumio[924]: info: Setting up gir1.2-json-1.0 (1.0.2-1) Nov 15 02:39:42 volumio volumio[924]: info: Setting up gir1.2-notify-0.7 (0.7.6- Nov 15 02:39:42 volumio volumio[924]: info: Setting up gir1.2-soup-2.4 (2.48.0-1 Nov 15 02:39:42 volumio volumio[924]: info: Setting up libc-dev-bin (2.19-18+deb Nov 15 02:39:42 volumio volumio[924]: info: Setting up linux-libc-dev:armhf (3.1 Nov 15 02:39:42 volumio volumio[924]: info: Setting up libc6-dev:armhf (2.19-18+ Nov 15 02:39:42 volumio volumio[924]: info: Setting up libao-dev (1.1.0-3) ... Nov 15 02:39:42 volumio volumio[924]: info: Setting up libglib2.0-data (2.42.1-1 Nov 15 02:39:42 volumio volumio[924]: info: Setting up libglib2.0-bin (2.42.1-1) Nov 15 02:39:42 volumio volumio[924]: info: Setting up libpcre3-dev:armhf (2:8.3 Nov 15 02:39:42 volumio volumio[924]: info: Setting up zlib1g-dev:armhf (1:1.2.8 Nov 15 02:39:42 volumio volumio[924]: info: Setting up libglib2.0-dev (2.42.1-1) Nov 15 02:39:44 volumio volumio[924]: info: Setting up libdbus-glib-1-dev (0.102 Nov 15 02:39:44 volumio volumio[924]: info: Setting up xorg-sgml-doctools (1:1.1 Nov 15 02:39:44 volumio volumio[924]: info: Setting up x11proto-core-dev (7.0.31 Nov 15 02:39:44 volumio volumio[924]: info: Setting up libxau-dev:armhf (1:1.0.8 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libxdmcp-dev:armhf (1:1.1 Nov 15 02:39:45 volumio volumio[924]: info: Setting up x11proto-input-dev (2.3.1 Nov 15 02:39:45 volumio volumio[924]: info: Setting up x11proto-kb-dev (1.0.6-2) Nov 15 02:39:45 volumio volumio[924]: info: Setting up xtrans-dev (1.3.5-1) ... Nov 15 02:39:45 volumio volumio[924]: info: Setting up libpthread-stubs0-dev:arm Nov 15 02:39:45 volumio volumio[924]: info: Setting up libxcb1-dev:armhf (1.10-3 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libx11-dev:armhf (2:1.6.2 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libpng12-dev:armhf (1.2.5 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libgdk-pixbuf2.0-dev (2.3 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libjson-glib-dev (1.0.2-1 Nov 15 02:39:45 volumio volumio[924]: info: Setting up libnotify-dev (0.7.6-2) . Nov 15 02:39:46 volumio volumio[924]: info: Setting up libtinfo-dev:armhf (5.9+2 Nov 15 02:39:46 volumio volumio[924]: info: Setting up libreadline6-dev:armhf (6 Nov 15 02:39:46 volumio volumio[924]: info: Setting up libreadline-dev:armhf (6. Nov 15 02:39:46 volumio volumio[924]: info: Setting up libxml2-dev:armhf (2.9.1+ Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsoup2.4-dev (2.48.0-1+ Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsox-fmt-ao:armhf (14.4 Nov 15 02:39:46 volumio volumio[924]: info: Setting up libtwolame0 (0.3.13-1.1) Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsox-fmt-mp3:armhf (14. Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsox-fmt-oss:armhf (14. Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsox-fmt-pulse:armhf (1 Nov 15 02:39:46 volumio volumio[924]: info: Setting up libsox-fmt-all:armhf (14. Nov 15 02:39:47 volumio volumio[924]: info: Setting up libsox-dev:armhf (14.4.1- Nov 15 02:39:47 volumio volumio[924]: info: Processing triggers for libc-bin (2. Nov 15 02:39:51 volumio sudo[3856]: pam_unix(sudo:session): session closed for u Nov 15 02:39:52 volumio volumio[924]: info: Installing Spop and libspotify Nov 15 02:39:52 volumio volumio[924]: info: armhf Nov 15 02:40:05 volumio sudo[5191]: root : TTY=unknown ; PWD=/tmp ; USER=root ; Nov 15 02:40:05 volumio sudo[5191]: pam_unix(sudo:session): session opened for u Nov 15 02:40:05 volumio volumio[924]: info: etc/ Nov 15 02:40:05 volumio volumio[924]: info: etc/spopd.conf Nov 15 02:40:05 volumio volumio[924]: info: lib/ Nov 15 02:40:05 volumio volumio[924]: info: lib/systemd/ Nov 15 02:40:05 volumio volumio[924]: info: lib/systemd/system/ Nov 15 02:40:05 volumio volumio[924]: info: lib/systemd/system/spop.service Nov 15 02:40:05 volumio volumio[924]: info: usr/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/include/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/include/libspotify/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/include/libspotify/api.h Nov 15 02:40:05 volumio volumio[924]: info: usr/local/lib/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/lib/pkgconfig/ Nov 15 02:40:05 volumio volumio[924]: info: usr/local/lib/pkgconfig/libspotify.p Nov 15 02:40:05 volumio volumio[924]: info: usr/local/lib/libspotify.so Nov 15 02:40:05 volumio volumio[924]: info: usr/local/lib/libspotify.so.12.1.103 Nov 15 02:40:06 volumio sudo[5191]: pam_unix(sudo:session): session closed for u Nov 15 02:40:06 volumio volumio[924]: info: usr/local/lib/libspotify.so.12 Nov 15 02:40:06 volumio volumio[924]: info: usr/share/ Nov 15 02:40:06 volumio volumio[924]: info: usr/share/spop/ Nov 15 02:40:06 volumio volumio[924]: info: usr/share/spop/awesome/ Nov 15 02:40:06 volumio volumio[924]: info: usr/share/spop/awesome/spop.lua Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/ Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/systemd/ Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/systemd/user/ Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/systemd/user/spopd.socket Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/systemd/user/spopd.service Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_plugin_savestate.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_audio_ao.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_plugin_awesome.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_audio_sox.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_plugin_mpris2.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_plugin_scrobble.so Nov 15 02:40:06 volumio volumio[924]: info: usr/lib/libspop_audio_oss.so Nov 15 02:40:06 volumio volumio[924]: info: usr/bin/ Nov 15 02:40:06 volumio volumio[924]: info: usr/bin/dspop Nov 15 02:40:06 volumio volumio[924]: info: usr/bin/spopd Nov 15 02:40:06 volumio sudo[5209]: root : TTY=unknown ; PWD=/tmp ; USER=root ; Nov 15 02:40:06 volumio sudo[5209]: pam_unix(sudo:session): session opened for u Nov 15 02:40:06 volumio sudo[5209]: pam_unix(sudo:session): session closed for u Nov 15 02:40:06 volumio sudo[2971]: pam_unix(sudo:session): session closed for u Nov 15 02:40:06 volumio volumio[924]: Plugin install end detected on script Nov 15 02:40:06 volumio volumio[924]: info: Install script completed Nov 15 02:40:06 volumio volumio[924]: info: Adding reference to registry Nov 15 02:40:06 volumio volumio[924]: info: Done installing plugin. Nov 15 02:40:06 volumio volumio[924]: info: Folder /tmp/plugins removed Nov 15 02:40:06 volumio volumio[924]: info: Folder /tmp/downloaded_plugin.zip re Nov 15 02:40:06 volumio volumio[924]: info: Folder /data/temp removed Nov 15 02:40:54 volumio kernel: Voltage normalised (0x00000000) Nov 15 02:40:56 volumio kernel: Under-voltage detected! (0x00050005) ...skipping... Nov 16 00:18:42 volumio volumio[924]: info: CoreStateMachine::stPlaybackTimer Nov 16 00:18:42 volumio volumio[924]: info: ------------------------------ 44ms Nov 16 00:18:42 volumio volumio[924]: info: Pushing Favourites {"service":"mpd", Nov 16 00:18:49 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:18:59 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:19:03 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:19:22 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:19:28 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:19:33 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:19:37 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:19:43 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:19:47 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:19:51 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:19:58 volumio sudo[9254]: volumio : TTY=pts/0 ; PWD=/var/log ; USER=ro Nov 16 00:19:58 volumio sudo[9254]: pam_unix(sudo:session): session opened for u Nov 16 00:20:02 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:20:10 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:20:14 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:20:20 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:20:47 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:20:50 volumio kernel: Under-voltage detected! (0x00050005) Nov 16 00:20:54 volumio kernel: Voltage normalised (0x00000000) Nov 16 00:20:56 volumio kernel: Under-voltage detected! (0x00050005)
