Library update: Seems to crash Volumio on Raspi
Jepp, but the problem is also on another Pi which has 512 MB
By now its stopped again . . . took much longer now.
I will now use the SD card in the other Pi and boot that one up . . . see what happens with this . . .
So, I just used the same card as for the smaller PI on the Rev2 with 512MB now ( no reflash )
it came up scanned the library and here the last few messages before it died
Mem-Info:
Apr 05 10:52:09 volumio kernel: active_anon:11037 inactive_anon:18944 isolated_anon:0
                                 active_file:39471 inactive_file:42922 isolated_file:9
                                 unevictable:0 dirty:10 writeback:0 unstable:0
                                 slab_reclaimable:4579 slab_unreclaimable:1940
                                 mapped:16727 shmem:4181 pagetables:525 bounce:0
                                 free:247 free_pcp:52 free_cma:0
Apr 05 10:52:09 volumio kernel: Normal free:988kB min:2808kB low:3508kB high:4212kB active_anon:44148kB inactive_anon:75776kB active_file:157884kB inactive_file:171688kB unevictable:0kB isolated(anon):0kB isolated(file):36kB present:507904kB managed:493848kB mlocked:0kB dirty:40kB writeback:0kB mapped:66908kB shmem:16724kB slab_reclaimable:18316kB slab_unreclaimable:7760kB kernel_stack:1112kB pagetables:2100kB unstable:0kB bounce:0kB free_pcp:208kB local_pcp:208kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Apr 05 10:52:09 volumio kernel: lowmem_reserve[]: 0 0
Apr 05 10:52:09 volumio kernel: Normal: 65*4kB (UME) 31*8kB (ME) 30*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 988kB
Apr 05 10:52:09 volumio kernel: 86852 total pagecache pages
Apr 05 10:52:09 volumio kernel: 11 pages in swap cache
Apr 05 10:52:09 volumio kernel: Swap cache stats: add 75, delete 64, find 0/0
Apr 05 10:52:09 volumio kernel: Free swap  = 523984kB
Apr 05 10:52:09 volumio kernel: Total swap = 524284kB
Apr 05 10:52:09 volumio kernel: 126976 pages RAM
Apr 05 10:52:09 volumio kernel: 0 pages HighMem/MovableOnly
Apr 05 10:52:09 volumio kernel: 3514 pages reserved
Apr 05 10:52:09 volumio kernel: 2048 pages cma reserved
Apr 05 10:52:09 volumio kernel: smsc95xx 1-1.1:1.0 eth0: kevent 2 may have been dropped
Apr 05 10:52:09 volumio kernel: avahi-daemon: page allocation failure: order:0, mode:0x2080020
Apr 05 10:52:09 volumio kernel: CPU: 0 PID: 511 Comm: avahi-daemon Not tainted 4.4.9+ #884
Apr 05 10:52:09 volumio kernel: Hardware name: BCM2708
Apr 05 10:52:09 volumio kernel: [<c0016c9c>] (unwind_backtrace) from [<c0013c20>] (show_stack+0x20/0x24)
Apr 05 10:52:09 volumio kernel: [<c0013c20>] (show_stack) from [<c02e319c>] (dump_stack+0x20/0x28)
Apr 05 10:52:09 volumio kernel: [<c02e319c>] (dump_stack) from [<c00de5bc>] (warn_alloc_failed+0xe4/0x130)
Apr 05 10:52:09 volumio kernel: [<c00de5bc>] (warn_alloc_failed) from [<c00e1aa0>] (__alloc_pages_nodemask+0x8a8/0xa8c)
Apr 05 10:52:09 volumio kernel: [<c00e1aa0>] (__alloc_pages_nodemask) from [<c00e1eac>] (__alloc_page_frag+0x160/0x190)
Apr 05 10:52:09 volumio kernel: [<c00e1eac>] (__alloc_page_frag) from [<c04870d8>] (__netdev_alloc_skb+0xa4/0x14c)
Apr 05 10:52:09 volumio kernel: [<c04870d8>] (__netdev_alloc_skb) from [<c03c630c>] (rx_submit+0x3c/0x240)
Apr 05 10:52:09 volumio kernel: [<c03c630c>] (rx_submit) from [<c03c6574>] (rx_alloc_submit+0x64/0x84)
Apr 05 10:52:09 volumio kernel: [<c03c6574>] (rx_alloc_submit) from [<c03c6788>] (usbnet_bh+0x1f4/0x24c)
Apr 05 10:52:09 volumio kernel: [<c03c6788>] (usbnet_bh) from [<c0025d18>] (tasklet_action+0x84/0xd8)
Apr 05 10:52:09 volumio kernel: [<c0025d18>] (tasklet_action) from [<c00252d8>] (__do_softirq+0x124/0x314)
Apr 05 10:52:09 volumio kernel: [<c00252d8>] (__do_softirq) from [<c00255b4>] (do_softirq+0x94/0xa0)
Apr 05 10:52:09 volumio kernel: [<c00255b4>] (do_softirq) from [<c00256ac>] (__local_bh_enable_ip+0xec/0x110)
Apr 05 10:52:09 volumio kernel: [<c00256ac>] (__local_bh_enable_ip) from [<c04fab8c>] (first_packet_length+0x170/0x248)
Apr 05 10:52:09 volumio kernel: [<c04fab8c>] (first_packet_length) from [<c04fac98>] (udp_ioctl+0x34/0x9c)
Apr 05 10:52:09 volumio kernel: [<c04fac98>] (udp_ioctl) from [<c0506a60>] (inet_ioctl+0x1c0/0x1d0)
Apr 05 10:52:09 volumio kernel: [<c0506a60>] (inet_ioctl) from [<c0479094>] (sock_ioctl+0x1d8/0x2ac)
Apr 05 10:52:09 volumio kernel: [<c0479094>] (sock_ioctl) from [<c013d3d4>] (do_vfs_ioctl+0x3dc/0x5a8)
Apr 05 10:52:09 volumio kernel: [<c013d3d4>] (do_vfs_ioctl) from [<c013d5e4>] (SyS_ioctl+0x44/0x6c)
Apr 05 10:52:09 volumio kernel: [<c013d5e4>] (SyS_ioctl) from [<c000f820>] (ret_fast_syscall+0x0/0x1c)
Apr 05 10:52:09 volumio kernel: Mem-Info:
Apr 05 10:52:09 volumio systemd[1]: Starting Journal Service...
Apr 05 10:52:09 volumio systemd[1]: systemd-logind.service watchdog timeout (limit 1min)!
Apr 05 10:52:04 volumio mpd[514]: client: [11] closed
Apr 05 10:52:06 volumio node[1549]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Apr 05 10:52:06 volumio node[1549]: *** WARNING *** Please fix your application to use the native API of Avahi!
Apr 05 10:52:06 volumio node[1549]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Apr 05 10:52:06 volumio node[1549]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Apr 05 10:52:06 volumio node[1549]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Apr 05 10:52:04 volumio systemd[1]: systemd-journald.service watchdog timeout (limit 1min)!
Apr 05 10:52:09 volumio systemd-journal[1588]: Journal stopped
Apr 05 10:52:10 volumio systemd-journal[1620]: Runtime journal is using 16.0M (max allowed 30.0M, trying to leave 36.1M free of 224.5M available → current limit 30.0M).
Apr 05 10:52:10 volumio systemd-journald[1588]: Received SIGTERM from PID 1 (systemd).
Apr 05 10:52:10 volumio systemd[1]: Unit systemd-journald.service entered failed state.
Apr 05 10:52:10 volumio systemd[1]: systemd-journald.service has no holdoff time, scheduling restart.
Apr 05 10:52:10 volumio systemd[1]: Stopping Journal Service...
Apr 05 10:52:10 volumio systemd[1]: Starting Journal Service...
Apr 05 10:52:10 volumio systemd[1]: Started Journal Service.
Apr 05 10:52:10 volumio systemd-journal[1620]: Journal started
Apr 05 10:52:10 volumio systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Apr 05 10:52:10 volumio systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Apr 05 10:52:11 volumio systemd[1]: Unit systemd-logind.service entered failed state.
Apr 05 10:52:11 volumio systemd[1]: systemd-logind.service has no holdoff time, scheduling restart.
Apr 05 10:52:11 volumio systemd[1]: Stopping Login Service...
Apr 05 10:52:11 volumio systemd[1]: Starting Login Service...
Apr 05 10:52:11 volumio systemd-logind[1630]: New seat seat0.
Apr 05 10:52:11 volumio systemd[1]: Started Login Service.
Apr 05 10:52:11 volumio systemd-logind[1630]: New session c1 of user volumio.
Apr 05 10:52:13 volumio kernel: CIFS VFS: Server HOSTSERVER has not responded in 120 seconds. Reconnecting...
Apr 05 10:52:15 volumio systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Apr 05 10:52:15 volumio mpd[514]: update: added NAS/Musik/Maria Callas/O madre mia La Giaconda, Ponchielli.mp3
Apr 05 10:52:15 volumio systemd[1]: Unit volumio.service entered failed state.
Apr 05 10:52:15 volumio systemd[1]: volumio.service holdoff time over, scheduling restart.
Apr 05 10:52:15 volumio systemd[1]: Stopping Volumio Backend Module...
Apr 05 10:52:15 volumio systemd[1]: Starting Volumio Backend Module...
Apr 05 10:52:15 volumio systemd[1]: Started Volumio Backend Module.
Apr 05 10:52:15 volumio systemd[1]: Starting dynamicswap.service...
Apr 05 10:52:15 volumio mpd[514]: update: added NAS/Musik/Maria Callas/1-Oh notte rea! Sogno spietato!.mp3
Apr 05 10:52:15 volumio systemd[1]: Started dynamicswap.service.
Apr 05 10:52:16 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Vanne E Li Cela Entrambi - Scena E Duetto (Norma, Clotilde).mp3
Apr 05 10:52:16 volumio mpd[514]: update: added NAS/Musik/Maria Callas/1-O dolce suol natio.mp3
Apr 05 10:52:16 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Ah ! Finalmente (Angelotti, Sagrestano, Cavaradossi).mp3
Apr 05 10:52:17 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Dormono Entrambi - Scena (Norma).mp3
Apr 05 10:52:17 volumio mpd[514]: update: added NAS/Musik/Maria Callas/La Forza del Destino (G.Verdi).mp3
Apr 05 10:52:17 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Mario _ Mario_! (Tosca, Scarpia).mp3
Apr 05 10:52:17 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Gente Là dentro (Cavaradossi, Angelotti).mp3
Apr 05 10:52:18 volumio mpd[514]: update: added NAS/Musik/Maria Callas/1-Le colpe ad espiar.mp3
Apr 05 10:52:18 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/04 Al Doce Guidami.mp3
Apr 05 10:52:19 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/07 Ben Lo T'Invenni (2).mp3
Apr 05 10:52:20 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/13 Habanera.mp3
Apr 05 10:52:21 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/14 J'ai Perdu Mon Euridce.mp3
Apr 05 10:52:22 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/03 Ah! Non Giunge Uman Pensiero.mp3
Apr 05 10:52:23 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/07 Ben Lo T'Invenni.mp3
Apr 05 10:52:24 volumio mpd[514]: client: [12] opened from ::ffff:127.0.0.1:38538
Apr 05 10:52:24 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/01 Addio Del Passato.mp3
Apr 05 10:52:25 volumio mpd[514]: update: added NAS/Musik/Maria Callas/Maria Callas/11 El Strano! Ah Forse E Lui.mp3
What does ‘cat /proc/cpuinfo’ say on the second pi?
volumio@musikzimmer:~$ cat /proc/cpuinfo
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 000d
Serial		: 00000000f9fdfa16
and here is where we got stuck this time ( copied from the terminal )
Apr 05 12:53:49 volumio dhcpcd[439]: eth0: leased 192.168.0.37 for 864000 seconds
Apr 05 12:53:49 volumio dhcpcd[439]: eth0: adding host route to 192.168.0.37 via 127.0.0.1
Apr 05 12:53:49 volumio avahi-daemon[511]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.37.
Apr 05 12:53:49 volumio avahi-daemon[511]: New relevant interface eth0.IPv4 for mDNS.
Apr 05 12:53:49 volumio avahi-daemon[511]: Registering new address record for 192.168.0.37 on eth0.IPv4.
Apr 05 12:53:49 volumio dhcpcd[439]: eth0: adding route to 192.168.0.0/24
Apr 05 12:53:49 volumio dhcpcd[439]: eth0: adding default route via 192.168.0.3
Apr 05 12:53:49 volumio wireless.js[1493]: killing: kill `pgrep -f "^wpa_supplicant"` || true
Apr 05 12:53:49 volumio wireless.js[1493]: Stopped aP
Apr 05 12:53:49 volumio wireless.js[1493]: Start wireless flow
Apr 05 12:53:49 volumio wireless.js[1493]: Stopped hotspot (if there)..
Apr 05 12:53:50 volumio sudo[1537]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ip addr flush dev wlan0
Apr 05 12:53:50 volumio sudo[1537]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:50 volumio wireless.js[1493]: ifdeconfigstderr: Device "wlan0" does not exist.
Apr 05 12:53:50 volumio sudo[1537]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:50 volumio wireless.js[1493]: Conf sudo ip addr flush dev wlan0 && sudo ifconfig wlan0 down
Apr 05 12:53:50 volumio wireless.js[1493]: launching wpa_supplicant args:
Apr 05 12:53:50 volumio wireless.js[1493]: [ '-d',
Apr 05 12:53:50 volumio wireless.js[1493]: '-s',
Apr 05 12:53:50 volumio wireless.js[1493]: '-B',
Apr 05 12:53:50 volumio wireless.js[1493]: '-Dnl80211,wext',
Apr 05 12:53:50 volumio wireless.js[1493]: '-c/etc/wpa_supplicant/wpa_supplicant.conf',
Apr 05 12:53:50 volumio wireless.js[1493]: '-iwlan0' ]
Apr 05 12:53:50 volumio volumio[1101]: Discovery: adding 7b4657da-9d91-446b-a586-be159f361d36
Apr 05 12:53:50 volumio volumio[1101]: info: mDNS: Found device Volumio
Apr 05 12:53:50 volumio wireless.js[1493]: wpasupp undefined
Apr 05 12:53:50 volumio wireless.js[1493]: DHCP IP
Apr 05 12:53:50 volumio wireless.js[1493]: launching /usr/bin/sudo args:
Apr 05 12:53:50 volumio wireless.js[1493]: [ '/sbin/dhcpcd' ]
Apr 05 12:53:50 volumio wpa_supplicant[1549]: wpa_supplicant v2.3
Apr 05 12:53:50 volumio wpa_supplicant[1549]: random: Trying to read entropy from /dev/random
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Successfully initialized wpa_supplicant
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'nl80211,wext' ctrl_interface 'N/A' bridge 'N/A'
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
Apr 05 12:53:50 volumio wireless.js[1493]: Start ap
Apr 05 12:53:50 volumio ntpd[535]: Listen normally on 4 eth0 192.168.0.37 UDP 123
Apr 05 12:53:50 volumio ntpd[535]: peers refreshed
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Could not read interface wlan0 flags: No such device
Apr 05 12:53:50 volumio wireless.js[1493]: ifdeconfigchild process exited with code 1
Apr 05 12:53:50 volumio wpa_supplicant[1549]: nl80211: Driver does not support authentication/association or connect commands
Apr 05 12:53:50 volumio wpa_supplicant[1549]: nl80211: Remove monitor interface: refcount=0
Apr 05 12:53:50 volumio wpa_supplicant[1549]: netlink: Operstate: ifindex=0 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
Apr 05 12:53:50 volumio sudo[1552]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/dhcpcd
Apr 05 12:53:50 volumio wpa_supplicant[1549]: nl80211: Set mode ifindex 0 iftype 2 (STATION)
Apr 05 12:53:50 volumio wpa_supplicant[1549]: nl80211: Failed to set interface 0 to mode 2: -19 (No such device)
Apr 05 12:53:50 volumio wpa_supplicant[1549]: wlan0: Failed to initialize driver interface - try next driver wrapper
Apr 05 12:53:50 volumio sudo[1552]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:50 volumio wpa_supplicant[1549]: WEXT: Could not set interface 'wlan0' UP
Apr 05 12:53:50 volumio wpa_supplicant[1549]: Failed to add interface wlan0
Apr 05 12:53:50 volumio wpa_supplicant[1549]: wlan0: Cancelling scan request
Apr 05 12:53:50 volumio wpa_supplicant[1549]: wlan0: Cancelling authentication timeout
Apr 05 12:53:50 volumio wireless.js[1493]: wpa supplicantchild process exited with code 255
Apr 05 12:53:50 volumio dhcpcd[1564]: version 6.0.5 starting
Apr 05 12:53:50 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: version 6.0.5 starting
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: eth0: rebinding lease of 192.168.0.37
Apr 05 12:53:51 volumio dhcpcd[1564]: eth0: rebinding lease of 192.168.0.37
Apr 05 12:53:51 volumio dhcpcd[1564]: eth0: leased 192.168.0.37 for 864000 seconds
Apr 05 12:53:51 volumio dhcpcd[439]: eth0: removing route to 192.168.0.0/24
Apr 05 12:53:51 volumio dhcpcd[1564]: eth0: adding host route to 192.168.0.37 via 127.0.0.1
Apr 05 12:53:51 volumio dhcpcd[1564]: eth0: adding route to 192.168.0.0/24
Apr 05 12:53:51 volumio dhcpcd[1564]: eth0: adding default route via 192.168.0.3
Apr 05 12:53:51 volumio dhcpcd[439]: eth0: removing default route via 192.168.0.3
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: eth0: leased 192.168.0.37 for 864000 seconds
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: eth0: adding host route to 192.168.0.37 via 127.0.0.1
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: eth0: adding route to 192.168.0.0/24
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: eth0: adding default route via 192.168.0.3
Apr 05 12:53:51 volumio dhcpcd[1606]: eth0: removing route to 192.168.0.0/24
Apr 05 12:53:51 volumio dhcpcd[1606]: eth0: removing default route via 192.168.0.3
Apr 05 12:53:51 volumio dhcpcd[1564]: forked to background, child pid 1606
Apr 05 12:53:51 volumio sudo[1552]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientstderr: dhcpcd[1564]: forked to background, child pid 1606
Apr 05 12:53:51 volumio wireless.js[1493]: dhclientchild process exited with code 0
Apr 05 12:53:51 volumio wireless.js[1493]: trying...
Apr 05 12:53:51 volumio sudo[1611]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:51 volumio sudo[1611]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:51 volumio sudo[1611]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:52 volumio wireless.js[1493]: trying...
Apr 05 12:53:53 volumio sudo[1620]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:53 volumio sudo[1620]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:53 volumio sudo[1620]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:54 volumio wireless.js[1493]: trying...
Apr 05 12:53:54 volumio sudo[1629]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:54 volumio sudo[1629]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:54 volumio sudo[1629]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:55 volumio volumio[1101]: info: CoreCommandRouter::executeOnPlugin: upnp , onRestart
Apr 05 12:53:55 volumio wireless.js[1493]: trying...
Apr 05 12:53:55 volumio sudo[1638]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall upmpdcli
Apr 05 12:53:55 volumio sudo[1640]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:55 volumio sudo[1638]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:55 volumio sudo[1640]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:55 volumio sudo[1640]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:55 volumio volumio[468]: :2:src/ohmetacache.cxx:122::dmcacheSaveWorker: can't get task from queue
Apr 05 12:53:55 volumio volumio[468]: :3:/usr/include/libupnpp/workqueue.h:193::SaveQueue: tasks 0 nowakes 0 wsleeps 1 csleeps 0
Apr 05 12:53:55 volumio mpd[517]: client: [1] closed
Apr 05 12:53:55 volumio sudo[1638]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:55 volumio sudo[1659]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start upmpdcli.service
Apr 05 12:53:55 volumio sudo[1659]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:56 volumio systemd[1]: Starting UPnP Renderer front-end to MPD...
Apr 05 12:53:56 volumio systemd[1]: Started UPnP Renderer front-end to MPD.
Apr 05 12:53:56 volumio sudo[1659]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:56 volumio volumio[1101]: info: Upmpdcli Daemon Started
Apr 05 12:53:56 volumio mpd[517]: client: [3] opened from ::ffff:127.0.0.1:35846
Apr 05 12:53:56 volumio wireless.js[1493]: trying...
Apr 05 12:53:56 volumio sudo[1678]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:56 volumio sudo[1678]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:56 volumio sudo[1678]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:57 volumio wireless.js[1493]: trying...
Apr 05 12:53:58 volumio sudo[1687]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:58 volumio sudo[1687]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:58 volumio sudo[1687]: pam_unix(sudo:session): session closed for user root
Apr 05 12:53:59 volumio wireless.js[1493]: trying...
Apr 05 12:53:59 volumio sudo[1696]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:53:59 volumio sudo[1696]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:53:59 volumio sudo[1696]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:00 volumio wireless.js[1493]: trying...
Apr 05 12:54:00 volumio sudo[1706]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:00 volumio sudo[1706]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:00 volumio sudo[1706]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:01 volumio wireless.js[1493]: trying...
Apr 05 12:54:01 volumio sudo[1715]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:01 volumio sudo[1715]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:01 volumio sudo[1715]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:02 volumio wireless.js[1493]: trying...
Apr 05 12:54:02 volumio sudo[1724]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:02 volumio sudo[1724]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:02 volumio sudo[1724]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:03 volumio wireless.js[1493]: trying...
Apr 05 12:54:03 volumio sudo[1734]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:04 volumio sudo[1734]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:04 volumio sudo[1734]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:05 volumio wireless.js[1493]: trying...
Apr 05 12:54:05 volumio sudo[1743]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:05 volumio sudo[1743]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:05 volumio sudo[1743]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:06 volumio wireless.js[1493]: trying...
Apr 05 12:54:06 volumio sudo[1752]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:06 volumio sudo[1752]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:06 volumio sudo[1752]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:07 volumio wireless.js[1493]: trying...
Apr 05 12:54:07 volumio sudo[1761]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:07 volumio sudo[1761]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:07 volumio sudo[1761]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:08 volumio wireless.js[1493]: trying...
Apr 05 12:54:08 volumio sudo[1770]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:08 volumio sudo[1770]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:08 volumio sudo[1770]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:09 volumio wireless.js[1493]: trying...
Apr 05 12:54:09 volumio sudo[1779]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:09 volumio sudo[1779]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:09 volumio sudo[1779]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:11 volumio wireless.js[1493]: trying...
Apr 05 12:54:11 volumio sudo[1788]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:11 volumio sudo[1788]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:11 volumio sudo[1788]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:11 volumio volumio[1101]: info: CoreCommandRouter::getUIConfigOnPlugin
Apr 05 12:54:11 volumio volumio[1101]: info: Received Get System Version
Apr 05 12:54:11 volumio volumio[1101]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Apr 05 12:54:12 volumio wireless.js[1493]: trying...
Apr 05 12:54:12 volumio sudo[1797]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:12 volumio sudo[1797]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:12 volumio sudo[1797]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:13 volumio wireless.js[1493]: trying...
Apr 05 12:54:13 volumio sudo[1806]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:13 volumio sudo[1806]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:13 volumio sudo[1806]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:14 volumio wireless.js[1493]: trying...
Apr 05 12:54:14 volumio sudo[1815]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwgetid -r
Apr 05 12:54:14 volumio sudo[1815]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:14 volumio sudo[1815]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:15 volumio wireless.js[1493]: Overtime, starting plan B
Apr 05 12:54:15 volumio wireless.js[1493]: killing: kill `pgrep -f "^/usr/bin/sudo"` || true
Apr 05 12:54:15 volumio wireless.js[1493]: killing: kill `pgrep -f "^wpa_supplicant"` || true
Apr 05 12:54:19 volumio systemd[1]: Stopped hotspot.service.
Apr 05 12:54:19 volumio wireless.js[1493]: stophotspotchild process exited with code 0
Apr 05 12:54:19 volumio sudo[1831]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ip addr flush dev wlan0
Apr 05 12:54:19 volumio sudo[1831]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:19 volumio wireless.js[1493]: ifdeconfigstderr: Device "wlan0" does not exist.
Apr 05 12:54:19 volumio sudo[1831]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:19 volumio wireless.js[1493]: ifdeconfigchild process exited with code 1
Apr 05 12:54:19 volumio wireless.js[1493]: confighotspotstderr: SIOCSIFADDR: No such device
Apr 05 12:54:19 volumio wireless.js[1493]: confighotspotstderr: wlan0: ERROR while getting interface flags: No such device
Apr 05 12:54:19 volumio wireless.js[1493]: ifconfig Error: Command failed: ifconfig wlan0 192.168.211.1 up
Apr 05 12:54:19 volumio wireless.js[1493]: SIOCSIFADDR: No such device
Apr 05 12:54:19 volumio wireless.js[1493]: wlan0: ERROR while getting interface flags: No such device
Apr 05 12:54:19 volumio wireless.js[1493]: launching systemctl args:
Apr 05 12:54:19 volumio wireless.js[1493]: [ 'start', 'hotspot.service' ]
Apr 05 12:54:19 volumio wireless.js[1493]: confighotspotchild process exited with code 255
Apr 05 12:54:19 volumio systemd[1]: Starting hotspot.service...
Apr 05 12:54:19 volumio systemd[1]: Started hotspot.service.
Apr 05 12:54:19 volumio wireless.js[1493]: hotspotchild process exited with code 0
Apr 05 12:54:19 volumio systemd[1]: Starting dhcpd.service...
Apr 05 12:54:19 volumio systemd[1]: Starting dnsmasq.service...
Apr 05 12:54:19 volumio dhcpd[1852]: Internet Systems Consortium DHCP Server 4.3.1
Apr 05 12:54:19 volumio hotspot[1852]: Internet Systems Consortium DHCP Server 4.3.1
Apr 05 12:54:19 volumio dhcpd[1852]: Copyright 2004-2014 Internet Systems Consortium.
Apr 05 12:54:19 volumio dhcpd[1852]: All rights reserved.
Apr 05 12:54:19 volumio dhcpd[1852]: For info, please visit https://www.isc.org/software/dhcp/
Apr 05 12:54:19 volumio dhcpd[1852]: Config file: /etc/dhcp/dhcpd.conf
Apr 05 12:54:19 volumio dhcpd[1852]: Database file: /var/lib/dhcp/dhcpd.leases
Apr 05 12:54:19 volumio dhcpd[1852]: PID file: /var/run/dhcpd.pid
Apr 05 12:54:19 volumio netplugd[1099]: eth0: state PROBING_UP pid 1412 exited status 0
Apr 05 12:54:19 volumio sudo[1376]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:19 volumio netplugd[1854]: /etc/netplug/netplug eth0 in -> pid 1854
Apr 05 12:54:19 volumio dnsmasq[1857]: started, version 2.72 cachesize 150
Apr 05 12:54:19 volumio dnsmasq[1857]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect
Apr 05 12:54:19 volumio dnsmasq[1857]: reading /etc/resolv.conf
Apr 05 12:54:19 volumio dnsmasq[1857]: using nameserver 192.168.0.3#53
Apr 05 12:54:19 volumio dnsmasq[1857]: using nameserver 8.8.4.4#53
Apr 05 12:54:19 volumio dnsmasq[1857]: read /etc/hosts - 4 addresses
Apr 05 12:54:20 volumio netplugd[1099]: eth0: state INNING pid 1854 exited status 0
Apr 05 12:54:19 volumio systemd[1]: Started Wireless Services.
Apr 05 12:54:19 volumio systemd[1]: Started dnsmasq.service.
Apr 05 12:54:20 volumio systemd[1]: Starting Host and Network Name Lookups.
Apr 05 12:54:20 volumio systemd[1]: Reached target Host and Network Name Lookups.
Apr 05 12:54:20 volumio dhcpd[1852]: Internet Systems Consortium DHCP Server 4.3.1
Apr 05 12:54:20 volumio dhcpd[1852]: Copyright 2004-2014 Internet Systems Consortium.
Apr 05 12:54:20 volumio dhcpd[1852]: All rights reserved.
Apr 05 12:54:20 volumio dhcpd[1852]: For info, please visit https://www.isc.org/software/dhcp/
Apr 05 12:54:20 volumio dhcpd[1852]: Wrote 0 leases to leases file.
Apr 05 12:54:20 volumio dhcpd[1852]: No subnet declaration for eth0 (192.168.0.37).
Apr 05 12:54:20 volumio dhcpd[1852]: ** Ignoring requests on eth0.  If this is not what
Apr 05 12:54:20 volumio dhcpd[1852]: you want, please write a subnet declaration
Apr 05 12:54:20 volumio dhcpd[1852]: in your dhcpd.conf file for the network segment
Apr 05 12:54:20 volumio dhcpd[1852]: to which interface eth0 is attached. **
Apr 05 12:54:20 volumio dhcpd[1852]: Not configured to listen on any interfaces!
Apr 05 12:54:20 volumio dhcpd[1852]: If you think you have received this message due to a bug rather
Apr 05 12:54:20 volumio dhcpd[1852]: than a configuration issue please read the section on submitting
Apr 05 12:54:20 volumio dhcpd[1852]: bugs on either our web page at www.isc.org or in the README file
Apr 05 12:54:20 volumio dhcpd[1852]: before submitting a bug.  These pages explain the proper
Apr 05 12:54:20 volumio dhcpd[1852]: process and the information we find helpful for debugging..
Apr 05 12:54:20 volumio dhcpd[1852]: exiting.
Apr 05 12:54:20 volumio systemd[1]: dhcpd.service: control process exited, code=exited status=1
Apr 05 12:54:20 volumio systemd[1]: Failed to start dhcpd.service.
Apr 05 12:54:20 volumio systemd[1]: Unit dhcpd.service entered failed state.
Apr 05 12:54:20 volumio hotspot[1852]: Copyright 2004-2014 Internet Systems Consortium.
Apr 05 12:54:20 volumio hotspot[1852]: All rights reserved.
Apr 05 12:54:20 volumio hotspot[1852]: For info, please visit https://www.isc.org/software/dhcp/
Apr 05 12:54:20 volumio hotspot[1852]: Config file: /etc/dhcp/dhcpd.conf
Apr 05 12:54:20 volumio hotspot[1852]: Database file: /var/lib/dhcp/dhcpd.leases
Apr 05 12:54:20 volumio hotspot[1852]: PID file: /var/run/dhcpd.pid
Apr 05 12:54:20 volumio hotspot[1852]: Wrote 0 leases to leases file.
Apr 05 12:54:20 volumio hotspot[1852]: No subnet declaration for eth0 (192.168.0.37).
Apr 05 12:54:20 volumio hotspot[1852]: ** Ignoring requests on eth0.  If this is not what
Apr 05 12:54:20 volumio hotspot[1852]: you want, please write a subnet declaration
Apr 05 12:54:20 volumio hotspot[1852]: in your dhcpd.conf file for the network segment
Apr 05 12:54:20 volumio hotspot[1852]: to which interface eth0 is attached. **
Apr 05 12:54:20 volumio hotspot[1852]: Not configured to listen on any interfaces!
Apr 05 12:54:20 volumio hotspot[1852]: If you think you have received this message due to a bug rather
Apr 05 12:54:20 volumio hotspot[1852]: than a configuration issue please read the section on submitting
Apr 05 12:54:20 volumio hotspot[1852]: bugs on either our web page at www.isc.org or in the README file
Apr 05 12:54:20 volumio hotspot[1852]: before submitting a bug.  These pages explain the proper
Apr 05 12:54:20 volumio hotspot[1852]: process and the information we find helpful for debugging..
Apr 05 12:54:20 volumio hotspot[1852]: exiting.
Apr 05 12:54:20 volumio hotspot[1851]: Cannot get driver information: No such device
Apr 05 12:54:20 volumio hotspot[1851]: /bin/hotspot.sh: line 8: [: too many arguments
Apr 05 12:54:20 volumio hotspot[1851]: Launching Ordinary Hostapd
Apr 05 12:54:20 volumio hotspot[1851]: Configuration file: /etc/hostapd/hostapd.conf
Apr 05 12:54:20 volumio hotspot[1851]: Could not read interface wlan0 flags: No such device
Apr 05 12:54:20 volumio hotspot[1851]: nl80211: Driver does not support authentication/association or connect commands
Apr 05 12:54:20 volumio hotspot[1851]: nl80211 driver initialization failed.
Apr 05 12:54:20 volumio hotspot[1851]: hostapd_free_hapd_data: Interface wlan0 wasn't started
Apr 05 12:54:20 volumio systemd[1]: hotspot.service: main process exited, code=exited, status=1/FAILURE
Apr 05 12:54:20 volumio hotspot[1875]: Killing Hostapd
Apr 05 12:54:20 volumio systemd[1]: Stopping Host and Network Name Lookups.
Apr 05 12:54:20 volumio systemd[1]: Stopped target Host and Network Name Lookups.
Apr 05 12:54:20 volumio systemd[1]: Stopping dnsmasq.service...
Apr 05 12:54:20 volumio dnsmasq[1857]: exiting on receipt of SIGTERM
Apr 05 12:54:20 volumio systemd[1]: Stopped dnsmasq.service.
Apr 05 12:54:20 volumio sudo[1877]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall hostapd
Apr 05 12:54:20 volumio sudo[1877]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:21 volumio hotspot[1875]: hostapd: no process found
Apr 05 12:54:21 volumio sudo[1877]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:21 volumio hotspot[1875]: Killing Dhcpd
Apr 05 12:54:21 volumio sudo[1886]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall dhcpd
Apr 05 12:54:21 volumio sudo[1886]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:21 volumio hotspot[1875]: dhcpd: no process found
Apr 05 12:54:21 volumio sudo[1886]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:21 volumio systemd[1]: hotspot.service: control process exited, code=exited status=1
Apr 05 12:54:21 volumio systemd[1]: Unit hotspot.service entered failed state.
Apr 05 12:54:30 volumio volumio[1101]: info: CoreCommandRouter::executeOnPlugin: upnp , onRestart
Apr 05 12:54:30 volumio sudo[1897]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall upmpdcli
Apr 05 12:54:30 volumio sudo[1897]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:30 volumio volumio[1664]: :2:src/ohmetacache.cxx:122::dmcacheSaveWorker: can't get task from queue
Apr 05 12:54:30 volumio volumio[1664]: :3:/usr/include/libupnpp/workqueue.h:193::SaveQueue: tasks 0 nowakes 0 wsleeps 1 csleeps 0
Apr 05 12:54:30 volumio sudo[1897]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:30 volumio mpd[517]: client: [3] closed
Apr 05 12:54:30 volumio sudo[1909]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start upmpdcli.service
Apr 05 12:54:30 volumio sudo[1909]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:30 volumio systemd[1]: Starting UPnP Renderer front-end to MPD...
Apr 05 12:54:30 volumio systemd[1]: Started UPnP Renderer front-end to MPD.
Apr 05 12:54:30 volumio sudo[1909]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:30 volumio volumio[1101]: info: Upmpdcli Daemon Started
Apr 05 12:54:30 volumio mpd[517]: client: [4] opened from ::ffff:127.0.0.1:35848
Apr 05 12:54:32 volumio volumio[1101]: info: CALLMETHOD: system_controller system saveGeneralSettings [object Object]
Apr 05 12:54:32 volumio volumio[1101]: info: CoreCommandRouter::executeOnPlugin: system , saveGeneralSettings
Apr 05 12:54:32 volumio volumio[1101]: info: System name has changed, restarting Shairport Sync
Apr 05 12:54:32 volumio sudo[1931]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall upmpdcli
Apr 05 12:54:32 volumio sudo[1931]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:32 volumio sudo[1933]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/hosts
Apr 05 12:54:32 volumio sudo[1933]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:32 volumio volumio[1914]: :2:src/ohmetacache.cxx:122::dmcacheSaveWorker: can't get task from queue
Apr 05 12:54:32 volumio volumio[1914]: :3:/usr/include/libupnpp/workqueue.h:193::SaveQueue: tasks 0 nowakes 0 wsleeps 1 csleeps 0
Apr 05 12:54:32 volumio mpd[517]: client: [4] closed
Apr 05 12:54:32 volumio sudo[1931]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:32 volumio sudo[1933]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:32 volumio sudo[1939]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart airplay
Apr 05 12:54:32 volumio sudo[1939]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:32 volumio volumio[1101]: info: Permissions for /etc/hosts set
Apr 05 12:54:33 volumio systemd[1]: Stopping ShairportSync AirTunes receiver...
Apr 05 12:54:33 volumio shairport-sync[1201]: exit...
Apr 05 12:54:33 volumio systemd[1]: Starting ShairportSync AirTunes receiver...
Apr 05 12:54:33 volumio systemd[1]: Started ShairportSync AirTunes receiver.
Apr 05 12:54:33 volumio sudo[1939]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:33 volumio shairport-sync[1960]: startup
Apr 05 12:54:33 volumio volumio[1101]: info: [1491396873443] Shairport-Sync Started
Apr 05 12:54:33 volumio volumio[1101]: info: Hostname now is musikzimmer
Apr 05 12:54:35 volumio sudo[1959]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/hostname Musikzimmer
Apr 05 12:54:35 volumio sudo[1959]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:35 Musikzimmer sudo[1959]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:35 Musikzimmer sudo[1967]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/avahi/services/volumio.service
Apr 05 12:54:35 Musikzimmer volumio[1101]: info: New hostname set
Apr 05 12:54:35 Musikzimmer sudo[1967]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:35 Musikzimmer sudo[1969]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start upmpdcli.service
Apr 05 12:54:35 Musikzimmer sudo[1967]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:35 Musikzimmer sudo[1969]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:35 Musikzimmer volumio[1101]: Canot set permissions for /etc/hosts: Error: Command failed: /usr/bin/sudo /bin/chmod 777 /etc/avahi/services/volumio.service
Apr 05 12:54:35 Musikzimmer volumio[1101]: /bin/chmod: cannot access '/etc/avahi/services/volumio.service': No such file or directory
Apr 05 12:54:35 Musikzimmer systemd[1]: Starting UPnP Renderer front-end to MPD...
Apr 05 12:54:35 Musikzimmer systemd[1]: Started UPnP Renderer front-end to MPD.
Apr 05 12:54:35 Musikzimmer sudo[1969]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:35 Musikzimmer volumio[1101]: info: Upmpdcli Daemon Started
Apr 05 12:54:35 Musikzimmer mpd[517]: client: [5] opened from ::ffff:127.0.0.1:35868
Apr 05 12:54:36 Musikzimmer sudo[2007]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart avahi-daemon.service
Apr 05 12:54:36 Musikzimmer sudo[2007]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:54:36 Musikzimmer systemd[1]: Stopping ShairportSync AirTunes receiver...
Apr 05 12:54:36 Musikzimmer shairport-sync[1960]: exit...
Apr 05 12:54:36 Musikzimmer systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Apr 05 12:54:36 Musikzimmer avahi-daemon[511]: Got SIGTERM, quitting.
Apr 05 12:54:36 Musikzimmer avahi-daemon[511]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.37.
Apr 05 12:54:36 Musikzimmer avahi-daemon[511]: avahi-daemon 0.6.31 exiting.
Apr 05 12:54:36 Musikzimmer volumio[1101]: info: mDNS Browse raised the following error Error: dns service error: unknown
Apr 05 12:54:36 Musikzimmer dbus[521]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service'
Apr 05 12:54:37 Musikzimmer systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Process 511 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Found user 'avahi' (UID 104) and group 'avahi' (GID 105).
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Successfully dropped root privileges.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: avahi-daemon 0.6.31 starting up.
Apr 05 12:54:37 Musikzimmer dbus[521]: [system] Successfully activated service 'org.freedesktop.Avahi'
Apr 05 12:54:37 Musikzimmer sudo[2007]: pam_unix(sudo:session): session closed for user root
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Successfully called chroot().
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Successfully dropped remaining capabilities.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: No service file found in /etc/avahi/services.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.37.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: New relevant interface eth0.IPv4 for mDNS.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Network interface enumeration completed.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Registering new address record for 192.168.0.37 on eth0.IPv4.
Apr 05 12:54:37 Musikzimmer avahi-daemon[2015]: Registering HINFO record with values 'ARMV6L'/'LINUX'.
Apr 05 12:54:37 Musikzimmer systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Apr 05 12:54:37 Musikzimmer systemd[1]: Starting ShairportSync AirTunes receiver...
Apr 05 12:54:37 Musikzimmer systemd[1]: Started ShairportSync AirTunes receiver.
Apr 05 12:54:37 Musikzimmer volumio[1101]: Discovery: ERRORError: dns service error: unknown
Apr 05 12:54:37 Musikzimmer volumio[1101]: info: mDNS Advertisement raised the following error Error: dns service error: unknown
Apr 05 12:54:37 Musikzimmer volumio[1101]: info: Avahi Daemon Restarted
Apr 05 12:54:37 Musikzimmer shairport-sync[2019]: startup
Apr 05 12:54:38 Musikzimmer avahi-daemon[2015]: Server startup complete. Host name is Musikzimmer.local. Local service cookie is 610153568.
Apr 05 12:54:42 Musikzimmer volumio[1101]: Discovery: StartAdv! undefined
Apr 05 12:54:42 Musikzimmer volumio[1101]: Discovery: Started advertising... Musikzimmer - undefined
Apr 05 12:54:43 Musikzimmer volumio[1101]: Discovery: this is already registered,  7b4657da-9d91-446b-a586-be159f361d36
Apr 05 12:54:43 Musikzimmer volumio[1101]: info: mDNS: Found device Musikzimmer
Apr 05 12:55:09 Musikzimmer volumio[1101]: info: []
Apr 05 12:55:30 Musikzimmer volumio[1101]: info: CoreCommandRouter::getUIConfigOnPlugin
Apr 05 12:55:30 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: albumart , getConfigParam
Apr 05 12:55:30 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:30 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Apr 05 12:55:34 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:36 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: networkfs , discoverShares
Apr 05 12:55:38 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:42 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:46 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:50 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:54 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:55:58 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:02 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:06 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:10 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:14 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:18 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:22 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:26 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:30 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:34 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:38 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:42 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:46 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:50 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:54 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:58 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:56:59 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: networkfs , addShare
Apr 05 12:56:59 Musikzimmer volumio[1101]: info: Adding a new share
Apr 05 12:56:59 Musikzimmer volumio[1101]: info: No correspondence found in configuration for share Plex on IP 192.168.0.45
Apr 05 12:56:59 Musikzimmer sudo[2039]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t nfs -o ro,soft,noauto 192.168.0.45:/mnt/data/Mediendaten/MB /mnt/NAS/Plex
Apr 05 12:56:59 Musikzimmer sudo[2039]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 05 12:57:00 Musikzimmer sudo[2039]: pam_unix(sudo:session): session closed for user root
Apr 05 12:57:00 Musikzimmer mpd[517]: client: [6] opened from local
Apr 05 12:57:00 Musikzimmer mpd[517]: client: [6] closed
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020230] ControllerMpd::sendMpdCommand status
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: Mpd Status Update: update
Apr 05 12:57:00 Musikzimmer volumio[1101]: [1491397020309] ---------------------------- MPD announces state update
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020348] sending command...
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020361] ControllerMpd::getState
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020371] ControllerMpd::sendMpdCommand status
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020382] sending command...
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020411] parsing response...
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020428] parsing response...
Apr 05 12:57:00 Musikzimmer volumio[1101]: info: [1491397020447] ControllerMpd::parseState
Apr 05 12:57:00 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/06 Lonely Woman.mp3
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: Command Router : Notfying DB Updatetrue
Apr 05 12:57:01 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/10 Silver Treads Among My Soul.mp3
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: [1491397021489] ControllerMpd::parseState
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: [1491397021501] ControllerMpd::pushState
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: CoreCommandRouter::servicePushState
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: [1491397021679] CoreStateMachine::syncState
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: [1491397021689] CorePlayQueue::getTrack 0
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: STATE SERVICE {"status":"stop","position":null,"seek":null,"duration":null,"samplerate":null,"bitdepth":null,"channels":null,"random":false,"updatedb":true,"repeat":false,"isStreaming":false,"title":null,"artist":null,"album":null,"uri":null}
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: CURRENT POSITION 0
Apr 05 12:57:01 Musikzimmer volumio[1101]: info: [1491397021994] CoreStateMachine::syncState   stateService stop
Apr 05 12:57:02 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/03 Calcutta Cutie.mp3
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022015] CoreStateMachine::syncState   currentStatus stop
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022019] CoreStateMachine::pushState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022036] CoreStateMachine::getState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022039] CorePlayQueue::getTrack 0
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: CoreCommandRouter::volumioPushState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022107] interfaceApi::pushState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022120] InterfaceWebUI::pushState
Apr 05 12:57:02 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/09 Sighin' and Cryin'.mp3
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022694] No code
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022704] CoreStateMachine::pushState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022786] CoreStateMachine::getState
Apr 05 12:57:02 Musikzimmer volumio[1101]: info: [1491397022891] CorePlayQueue::getTrack 0
Apr 05 12:57:03 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 05 12:57:03 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/05 The Kicker.mp3
Apr 05 12:57:03 Musikzimmer volumio[1101]: info: [1491397023031] interfaceApi::pushState
Apr 05 12:57:03 Musikzimmer volumio[1101]: info: [1491397023034] InterfaceWebUI::pushState
Apr 05 12:57:03 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/08 Que Pasa (trio version).mp3
Apr 05 12:57:03 Musikzimmer volumio[1101]: info: [1491397023559] ------------------------------ 3280ms
Apr 05 12:57:03 Musikzimmer volumio[1101]: info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
Apr 05 12:57:04 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/04 Que Pasa.mp3
Apr 05 12:57:04 Musikzimmer volumio[1101]: info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
Apr 05 12:57:04 Musikzimmer volumio[1101]: info: [1491397024067] Database update started
Apr 05 12:57:04 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Apr 05 12:57:04 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/02 The Natives Are Restless Tonight.mp3
Apr 05 12:57:05 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/07 Sanctimonious Sam.mp3
Apr 05 12:57:05 Musikzimmer mpd[517]: update: added NAS/Plex/The Horace Silver Quintet/Song for My Father/01 Song for My Father.mp3
Apr 05 12:57:05 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:57:06 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/11 Samba '88.mp3
Apr 05 12:57:06 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/01 How High the Moon _ Ornithology.mp3
Apr 05 12:57:06 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:57:07 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/08 Stompin' at the Savoy.mp3
Apr 05 12:57:07 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/04 Night and Day.mp3
Apr 05 12:57:08 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/07 Good Morning Heartache.mp3
Apr 05 12:57:08 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/06 Yardbird Suite.mp3
Apr 05 12:57:08 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/02 Gee Baby.mp3
Apr 05 12:57:09 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/10 Some Other Time.mp3
Apr 05 12:57:09 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/05 Blame It on My Youth.mp3
Apr 05 12:57:10 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/03 Bernie's Tune.mp3
Apr 05 12:57:10 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Azure-Té/09 Azure-Té.mp3
Apr 05 12:57:10 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:57:11 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Daydream/08 Everything Must Change.mp3
Apr 05 12:57:11 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/11 In a Sentimental Mood.mp3
Apr 05 12:57:12 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/12 I Love Paris.mp3
Apr 05 12:57:12 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/03 Can't We Be Friends.mp3
Apr 05 12:57:13 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/07 Sweet Home Cookin' Man.mp3
Apr 05 12:57:13 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/10 Dindi.mp3
Apr 05 12:57:14 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/06 No Moon at All.mp3
Apr 05 12:57:14 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/09 Social Call.mp3
Apr 05 12:57:14 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/02 I Cover the Waterfront.mp3
Apr 05 12:57:15 Musikzimmer volumio[1101]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Apr 05 12:57:15 Musikzimmer mpd[517]: update: added NAS/Plex/Karrin Allyson/Sweet Home Cookin'/08 You Are Too Beautiful.mp3
and this I see quite frequently
Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** Please fix your application to use the native API of Avahi! Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** Please fix your application to use the native API of Avahi! Apr 05 13:36:57 musikzimmer node[1517]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
I can’t see anything wrong in the logs in your last two posts. All the errors about page allocations and memory are not present. Does this RPi (B version 2 with 512MB RAM) still crash/become unresponsive?
Yes it does, the messages in my last post where “the last words” before it died
They may have been the “last words” but they do they give any indication of any problems. The problem with cutting and pasting parts of the journal is that we don’t see the whole picture.
Please do a factory reset of the RPi B Rev 2 device, add your NAS and allow to run until it becomes unresponsive. Reboot, and send the log via the “dev” page.
Ok, will do.
Will be during the weekend . . . I ma currently away from the raspi.
With factory reset you mean a fresh flash incl. formatting/preparing the SD card?
cheers
T
I just uploaded the log
What I did :
I formatted a card, flashed it, started Raspi, waited quite some time . . . then I launched the WebUI, added the NAS and let it update until it fell asleep . . .
Hope you are able to see something in the log
cheers
T
I wonder if you have been able to see something in the log.
cheers
T
I just replaced the power supply to a 5V/2A but it changed nothing . . .
It even collapsed quite early during the process of populating the library
cheers
T
Sorry for no reply. I am away from my computer this week. Erm, I can’t see your log based on the date of your post (and you haven’t included your username).
I think I added something like “Torsten log after reboot” in the subject line
But anyway I can redo it later . . .
So, I just uploaded the log
logs.volumio.org/volumio/SfKJ7V4.html
I did not see anythin suspicious, you should send the log just after the crash.
I just removed it, we need to make it more secure and hide cifs mount passwords
How do I get a log after the crash ?
I cannot access anymore the device is like dead . . . I rebooted and sent the log
I am aware about the password I used a “onetime” for this purpose now
I got two logs now
The first I setup like
sudo journalctl -f > logfile and let it run until dead
the second I did almost the same but I watched
sudo journalctl -f and copied the screen buffer
And now how do I get these files to you guys . . . the “upload attachment” function does not allow me
Hi Torsten,
if you’re haveing trouble with attachments (perhaps it is too large) then you could you use pastebin or something similar.
Actually it is not really too big ( like 230 kB and 63kB ) but it does not allow the extension ( neither txt, nor any other I tried )
I will then try with pastebin or similar . . .
