Library disappear
Hi, i use volumio from may 2017 with no problem.
2 days ago i update version to 2.368 and after configure my fritz nas i play a song, than library disappear, if i rescan/refresh hd led blink but in web ui nothing happen. i have to reset to factory and rescan so i play a random song and i have same problem again.
i have reinstalled july version of volumio and i have same problem, reinstalled 2.368 idem, i changed sd but nothing change. What i can do?
i use not dac, have mor or less than 13000 traks on a hard disk mounted on a fritz box, i repeat till 3 days ago i have no problem
hi,
i use also fritz nas, sometimes my fritzbox “loses” the HD! switch off switch on the HD safe sometimes my life. once my fritzbox lost the “user” for nas (user and password in volumio is set?). have you switch your HD to a laptop or something else for checking your HD (maybe broken)?
greets
So, i have a smart tv, smartphone, pc, uebbi, all devices connect to hd without any problems, in ftp, in apps, ecc. User ftp and passwords is set on volumio, now i install YouTube playback plugin and chek if library still alive
I start a song from my nas and library is gone again, if i rescan/refresh hd led blink but volumio ui do nothing, YouTube plug in was installed but not active. I think volumio cant handle over 10000 traks, the 2 billion upgrades not resolve this anciest bug
strange.
“i use volumio from may 2017 with no problem.” “2 days ago i update version to 2.368” “i have reinstalled july version of volumio and i have same problem”.
the question is, what is the change?! have you the possibility to change your psu for the raspi?
after this i think the time is come for logging! reproduce the problem. volumio.local/dev (there is a point i think send logging or so) copy and paste the logging in this threat
Man the mistery is solved
i use plugin simple equalizer, the latest version of this plugin make something to my library.
when i install equalizer my library disappear and don’t refresh/rescan, if i uninstall equalizer and restart raspberry everything back normal.
so i use raspberry whitout a dac and an equalizer help,
1.there is an alternative equalizer plugin?
2.how can i install plugin in this version of volumio if there is not plugin upload button?
3.i have a raspberry pi 1 B (the one whit 2 usb port) what dac can i buy for this model?
