LED on when VOLUMIO is playing
Hi there.
First of all, I’m sorry for my english :confused:
I’m looking for a script that set’s a GPIO to high while Volumio is playing.
Any ideas?
all I found did not work :confused:
have a look at the “Ampswitch plugin” - should do it :slight_smile:
Best Regards
Josef
Damn it! Sometimes you don’t see the gold right in front of you :smiley:
Big thanks to you! Plugin works fine
