Latest Volumio image doesn not support RCA
I’ve installed the latest volumio image. In the volumio interface, the output is HDMI or DAC.
My Rasperry Pi doesn’t have a hdmi. Only RCA jack. How can I add support for this audio output
you mean only the RPI jack? Just select 'headphone" as output in the settings.
2 it’s the red/white stereo output
so you have a DAC (hat plugged on your RPI, right?
something like
Enable i2s dac and choose yours, or a compatible.
Without more info, we can’t help more…
you can try these: -
  1. Use a USB Audio Interface
  2. Use a HAT (Hardware Attached on Top)
  3. Use a Software-Based Audio Output
