plugin doesnt work. it says:
raspi_nfc_spi Plugin
This plugin is failing to start. Please install updated version, or contact plugin developer.
how can i fix it? thanks
I tried to update my setup to the latest volumio version. Some of the plugins do not work anymore. I also see a very slow response time at least for the hardware linked plugins (button control, rotary encoder). It seems that volumio got too heavy for the RaspPi Zero. I will buy the RaspPi Zero 2 and try to get the hardware running again. Does anybody know if there is a tutorial to adapt the volumio 2 plugins for volumio 3.
This is maybe a bit off-topic, but I tried to install volumio on my old Samsung NC10 netbook. I thought that it might have been a good option for my kids to use Spotify without having the ability to browse the web (and find content that is not suitable for them). Unfortunately I was not able to get the screen running. So I decided to install lubuntu on it. I also removed the taskbar and the start menu. The only accessible program is the PSST, a Spotify Player with minimal functionality: search and play. Hence it is not possible to access any video content, that Spotify provides. In addition the player is really quick. Since my kids are already a bit older, this might be the best solution for them.
This is exactly the project I need. I’ve installed Volumio and the buttons work, but I don’t know how to install the extra plugin for the MFC522 card reader (Github repository). I’m a total newbie in this area. Does anyone here have a step-by-step guide for this?
