Issues with Pure PI II and TransportPI Digi II
Hi everyone,
I recently purchased the Ian Canada Pure PI, Transporter PI Digi II, and Monitor PI Pro.
I installed everything following the instructions and using Volume Ver. 4.119 as the OS on raspberry pi 4 8GB.
I chose the Hifiberry Digi+ Pro as the device, using the SPDIF output.
I also configured the optical output on the DAC.
Unfortunately, when I play, the Monitor PI Pro shows no signal and the XO LEDs remain off.
The OS also gives me the error message that there is no output device.
If I change the I2S configuration to Generic Dac I2S, I don’t get any OS error messages, but the PI Pro monitor indicates a lack of signal
Have any of you had the same issues as me?
I solved the problem.
I reinstalled Volumio on the SSD, then connected the DAC to the Raspberry Pi, and now it plays very well.
