Is Raspberry Pi 2 too weak for Volumio 4 + Touch Screen plugin?
Hello forum,
I’ve been trying for a while to display something using the Raspberry Pi 2B and I’m getting nowhere…
I wrote the latest image to a SanDisk 32gb card, first boot shows the splash screen and then the QR code afterwards. I go to Volumio.local, configure and install the Touch Screen plugin. Check it’s enabled and it looks good.
When I reboot after, I see the splash screen then no QR screen. Soon the screen goes white, then grey, then finally no signal on my Dell monitor.
I’ve reflashed the SD like five times now, so definitely not a corrupted image. Is the Touch Screen plugin trying to use some kind of 64bit software to do it’s display hence the failures?
I guess my next go is to get the Pi 4 instead? I do see that Volumio is supported for Pi2 here:
https://help.volumio.com/en/articles/10-what-3rd-party-devices-are-supported
Headless is fine, bit slow but it isn’t the same as trying to run a HD monitor so it’s not wrong I guess.
The rPi2 is not powerfull enough to run both Volumio4 as the touchscreen plugin.
