I use Rivo, Volumio 4.209 and Nova 0.261012.0
The original very old post I referred to was not by me, but I can reproduce the problem consistently regardless of which hires album is played and so can others as you can see in that thread. You need to let the track finish and the next one to start to notice the issue in the ‘Listening’ pane or in the now playing field at the bottom of the Volumio screen. As I said this is a Volumio / GUI / Tidal integration display/report issue. Nothing to do with the DAC or with what is actually sent to it. The DAC reports the bit rate correctly.
Hi @NikosR
Apologies, I was only looking at the DAC’s screen. Yes, I see the same as you in the now playing screen. Logs do show the correct value.
Nova is going stable! ![]()
Hi everyone,
First of all: thank you. About 700 of you joined the Nova beta, tested it on your setups, reported bugs and told us what didn’t feel right. Nova is a lot better today because of you, and we really mean that.
Here’s what happens next.
Today: the new stable build starts rolling out
This build already includes Nova, but for now it stays switched off for anyone who hasn’t tried it yet. We want to make sure the update itself runs smoothly before turning Nova on for everyone. We’re starting with Motivo, Integro, Primo 2, Raspberry Pi and x86. If nothing major comes up, Primo+, Rivo and Rivo+ follow tomorrow.
If you already use Nova
Nothing changes for you: after the update you keep Nova, and you’ll receive this update whichever channel you’re on.
Next Monday: Nova for everyone
If all goes well, from Monday we’ll turn Nova on for all Volumio devices, and for Raspberry Pi and x86 later in the week. Everyone who hasn’t tried it yet will see an invite to switch. If you’re already on Nova, you won’t see it: you’re already in.
Switching back to Manifest in the next few days
Until Monday, if you go back to Manifest you won’t be able to return to Nova from the settings. It’s a temporary technical limitation that goes away as soon as Nova is turned on for everyone. You’ll see a warning before switching.
About the test channel
We’ll keep using it to try major features before they reach stable, so if you like being first, feel free to stay. If you prefer things calm and stable, you can switch back to stable anytime: you’ll keep Nova anyway.
As always, if something looks off after the update, reply here (or directly in Nova) with your device, version and what happened (logs help a lot).
Thanks again for building this with us! ![]()
The Volumio team
v0.261021.1
New
Search now remembers the source you last searched, and shows clearly which one is active.
Improved
The volume slider hides itself automatically when your player has no volume control, with a short note explaining why.
Text size and the volume slider setting now stick across a restart.
Browsing remembers each screen’s own scroll position instead of jumping to where a subfolder left off.
Browse’s home tiles (Artists, Albums, Playlists, Favourites) now share the same look.
Fixed
The seek bar and lyrics no longer jump backward during Qobuz Connect playback.
The track menu no longer closes itself while a long title scrolls.
Working well. The Browse page looks much cleaner and pinning some sources (Bandcamp) was awkward before, but works as it should now.
My Volumio systems are based on the RPI3B+ and Allo DigiOne (as well as the Signature version), followed by a Topping E50, Apollon Nilai500 ST Power Amp, and Boenicke Audio W5 SE speakers. I listen almost exclusively to Qobuz, along with the occasional radio broadcast. Very rarely, I also play FLAC files from my NAS.
In my view, Nova runs very well—it’s fast and stable. As far as I’m concerned, Nova leaves almost nothing to be desired!
Many thanks to the creators!!!
Hi @leorigna
A couple of minor, non urgent tweaks in the phone view.
On my laptop, the bitrate, sample rate and audio format are displayed, but on my phone screen the digital audio format is not shown. I know space is limited, but could that be (optionally?) added.
Also missing on mobile phone screen is the menu item ‘About’, which is shown on my laptop’s screen.
It’s really easy to use Nova:
After updating to V4, go to Settings → System → User Interface Style/Layout and select Nova
Hi @leorigna
I did notice the same thing as @SimonE that on the phone the source is not shown (in this case Qobuz).
I have my Primo V2 (that i bought recently) connected to my tv via the HDMI output, so I did try how the new Nova interface is shown on my tv – it looks good, but it does show a 12-hour clock in the upper right corner – and I can not see where it can be changed to a 24-hour clock?
Volume Slider toggle switch seems not to be sticky across Nova release updates.
I have Rivo+ with latest version 4.
I don’t have User Interface Style/Layout available ?
It dissapeard, i had it in version 3.
Under Nova, it should be under Settings → Appearance → Interface theme
I checked but it isn’t there ?1?
Even the Manifest is gone.
Try a cold restart (remove the mains plug, wait 5 minutes and reboot). If this doesn’t work try a factory reset. You can always open a ticket with support.
Nova v0.261103.0
New
On phone, tap the audio quality pill on Now Playing to see the format, source, bit depth, sample rate and bitrate.
Improved
About (device and Nova version, logs, check for updates) is now reachable from Settings on phone.
Fixed
Devices that already include Premium no longer show the button to buy Premium.
The back button on the subscription plans screen works again after finishing a checkout.
Advanced Audio Settings (DAC Filter, Roon Ready options) now show up reliably on Playback Options right after your device boots, instead of sometimes going missing.
Hi!
What is the build version of your device?
Can you send a bug report? So we are able to investigate on this:)
Excellent solution given the limited real estate. Works perfectly. Thanks.
Any chance to see Nova Interface even on myvolumio?
I’ve noticed that lyrics are often not retrieved for tracks. Which sources are used? For example, why does this happen much less frequently with the “Now Playing” plugin? With Nova, I often notice that lyrics are missing even when they are available on Genius Lyrics.
