Hi. New to forum but no to Volumio. I had a working version for a couple of years but I have decided to upgrade to latest version of Volumio. I have reflashed my 8gb microSD card from a windows PC and have put the card into the RaspberryPI. In the past it booted after a few seconds. The new version is not booting up at all. I have connected a HDMI cable to see what is going on and the boot process is stuck on a line that states ‘Volumio login:’. It would appear it is waiting for an input from me. It has never done this before and I have never connected a keyboard to my PI before (in fact I don’t have a keyboard). There is no mention of this in the setup guide, so I am a bit confused. Have I done something wrong?
when booting process is finished, at this point (hdmi) there is always a login.
volumio is headless, that means, you have to use another device (like smartphone,tablet,…) to see what you are looking for.
try to find on wlan 'volumio" and login with 'volumio2" - then u should have a smile in your face
Nobody seems to understand my problem. Volumio does not boot complete the boot process. it stops early on asking for a user name. I know how to access Volumio when it boots as I have used it for over 2 years. the new installation I have made today using the latest version does not boot.
maybe some more info helps. which RPI? and which error occurs? photo from screen? or try another mSD card…
over 2 years? user experience should be very different right now.
Thanks for all the replies. It turns out it was a network problem. One of my homeplugs had been turned off at the wall by my wife. Once the network was back on everything was fine.
