volumio@volumio:~$ systemctl status mpd.service
● mpd.service - Music Player Daemon
Loaded: loaded (/lib/systemd/system/mpd.service; enabled)
Active: failed (Result: exit-code) since Sat 2021-01-02 21:52:28 UTC; 6min ago
Docs: man:mpd(1)
man:mpd.conf(5)
Process: 3279 ExecStart=/usr/bin/mpd --no-daemon (code=exited, status=127)
Main PID: 3279 (code=exited, status=127)
Jan 02 21:52:28 volumio systemd[1]: Starting Music Player Daemon...
Jan 02 21:52:28 volumio mpd[3279]: /usr/bin/mpd: error while loading shared libraries: libbcm_host.s...ctory
Jan 02 21:52:28 volumio systemd[1]: mpd.service: main process exited, code=exited, status=127/n/a
Jan 02 21:52:28 volumio systemd[1]: Failed to start Music Player Daemon.
Jan 02 21:52:28 volumio systemd[1]: Unit mpd.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
What version of Volumio are you on?
I must warn you that what you are trying to achieve is not the normal use case Volumio was designed for. So don’t expect to get step by step guides/help on how to achieve this.
Do expect to spend some time figuring things out on your own.
When you do manage to get things working, do please share how you achieved it in the case someone else would like to follow suit.
version 2.861
