Install problems
Hi guys
I am newbie with Linux.
When I start my Audiophonics Rasptouch (with touchscreen), program ask me for a volumio login with password. I input root/volumio or volumio/volumio but no with the touchscreen. Only with a USB keyboard.
Well I come to my browser with volumio.org on ma PC and it is correct for configuration. But when I try to put my wy wifi password, it is impossible for me.
And which is the correct I2S option for a GD Audio R2R DAC ?
All I want is to use my Rasptouch as a music server… Boot… Go directly to touchscreen (cause I do not want tu use a keyboard) and start browser with volumio.org. That’s all.
Is it possible to do that automatically when I start the Rasp ?
Thank you for replies and excuse me for my (bad) english (I am french).
Kind regards
Marc
I don’t have a touch screen myself but as you see the shell on startup, I can tell something’s not right.
First of all, I think you need the touch display plugin:
volumio-plugins-collection-t6251.html
Beware, there could be installation problems: touch-display-installation-bug-t10015.html#p49168
Don’t know if your device has the official touch display but the plugin is optimized for that one.
About I2S I can’t help you, sorry. I’m sure there’s enough info if you search the forum, though.
