I only tried the one you ask about, gpio-buttons plugin and that installed and worked fine for me.
are you also on version 3.163?
I have just flashed a fresh 3.163, set it all up…etc
Then through command line installed GPIO buttons, also updating node modules
then activated in volumio 3, set it up to use power button to shutdown which also works as it should. Click and instant shut down…soo much better than V2 which sometimes took a week to shut down.
SSH window of installing GPIO- buttons
___
/\_ \ __
__ __ ___\//\ \ __ __ ___ ___ /\_\ ___
/\ \/\ \ / __`\\ \ \ /\ \/\ \ /' __` __`\/\ \ / __`\
\ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \
\ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/
\/__/ \/___/ \/____/ \/___/ \/_/\/_/\/_/\/_/\/___/
Free Audiophile Linux Music Player - Version 3.0
© 2015-2021 Michelangelo Guarise - Volumio Team - Volumio.org
permitted by applicable law.
Welcome to Volumio for Raspberry Pi (5.4.83-v7l+ armv7l)
volumio@volumio:~$ sudo apt-get update
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
Get:6 https://deb.nodesource.com/node_14.x buster/main armhf Packages [779 B]
Get:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58 .8 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [1 04 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages [1360 B ]
Fetched 13.6 MB in 8s (1719 kB/s)
Reading package lists... Done
volumio@volumio:~$ sudo apt -y install build-essential
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for volumio:
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
bzip2 cpp cpp-8 dpkg-dev fakeroot g++ g++-8 gcc gcc-8 libalgorithm-diff-perl
libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan5 libcc1-0
libfakeroot libgcc-8-dev libisl19 libmpc3 libmpfr6 libstdc++-8-dev libubsan1
make patch
Suggested packages:
bzip2-doc cpp-doc gcc-8-locales debian-keyring gcc-8-doc libstdc++6-8-dbg
gcc-multilib autoconf automake libtool flex bison gdb gcc-doc libgcc1-dbg
libgomp1-dbg libitm1-dbg libatomic1-dbg libasan5-dbg liblsan0-dbg
libtsan0-dbg libubsan1-dbg libmpx2-dbg libquadmath0-dbg libstdc++-8-doc
make-doc ed diffutils-doc
The following NEW packages will be installed:
build-essential bzip2 cpp cpp-8 dpkg-dev fakeroot g++ g++-8 gcc gcc-8
libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl
libasan5 libcc1-0 libfakeroot libgcc-8-dev libisl19 libmpc3 libmpfr6
libstdc++-8-dev libubsan1 make patch
0 upgraded, 24 newly installed, 0 to remove and 7 not upgraded.
Need to get 27.8 MB of archives.
After this operation, 93.0 MB of additional disk space will be used.
Get:2 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libisl19 armhf 0.20-2 [439 kB]
Get:7 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libcc1-0 armhf 8.3.0-6+rpi1 [37.9 kB]
Get:9 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libubsan1 armhf 8.3.0-6+rpi1 [103 kB]
Get:12 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf gcc armhf 4:8.3.0-1+rpi2 [5200 B]
Get:13 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libstdc++-8-dev armhf 8.3.0-6+rpi1 [1545 kB]
Get:15 http://raspbian.raspberrypi.org/raspbian buster/main armhf g++ armhf 4:8. 3.0-1+rpi2 [1632 B]
Get:19 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf build-essential armhf 12.6 [7568 B]
Get:21 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf fakeroot armhf 1.23-1 [85.2 kB]
Get:24 http://mirror1.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libalgorithm-merge-perl all 0.08-3 [12.7 kB]
Get:1 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf bzip2 armhf 1.0.6-9.2~deb10u1 [46.2 kB]
Get:3 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libmpfr6 armhf 4.0.2-1 [723 kB]
Get:4 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libmpc3 armhf 1.1.0-1 [32.1 kB]
Get:5 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf cpp-8 armhf 8.3.0-6+rpi1 [6787 kB]
Get:6 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf cpp armhf 4:8.3.0-1+rpi2 [19.6 kB]
Get:8 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bus ter/main armhf libasan5 armhf 8.3.0-6+rpi1 [317 kB]
Get:10 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libgcc-8-dev armhf 8.3.0-6+rpi1 [595 kB]
Get:11 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf gcc-8 armhf 8.3.0-6+rpi1 [7223 kB]
Get:14 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf g++-8 armhf 8.3.0-6+rpi1 [7464 kB]
Get:16 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf make armhf 4.2.1-1.2 [321 kB]
Get:17 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf patch armhf 2.7.6-3+deb10u1 [115 kB]
Get:18 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf dpkg-dev all 1.19.7 [1773 kB]
Get:20 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libfakeroot armhf 1.23-1 [43.3 kB]
Get:22 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libalgorithm-diff-perl all 1.19.03-2 [47.9 kB]
Get:23 http://mirror0.it.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian bu ster/main armhf libalgorithm-diff-xs-perl armhf 0.04-5+b1 [11.4 kB]
Fetched 27.8 MB in 12s (2372 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package bzip2.
(Reading database ... 34194 files and directories currently installed.)
Preparing to unpack .../00-bzip2_1.0.6-9.2~deb10u1_armhf.deb ...
Unpacking bzip2 (1.0.6-9.2~deb10u1) ...
Selecting previously unselected package libisl19:armhf.
Preparing to unpack .../01-libisl19_0.20-2_armhf.deb ...
Unpacking libisl19:armhf (0.20-2) ...
Selecting previously unselected package libmpfr6:armhf.
Preparing to unpack .../02-libmpfr6_4.0.2-1_armhf.deb ...
Unpacking libmpfr6:armhf (4.0.2-1) ...
Selecting previously unselected package libmpc3:armhf.
Preparing to unpack .../03-libmpc3_1.1.0-1_armhf.deb ...
Unpacking libmpc3:armhf (1.1.0-1) ...
Selecting previously unselected package cpp-8.
Preparing to unpack .../04-cpp-8_8.3.0-6+rpi1_armhf.deb ...
Unpacking cpp-8 (8.3.0-6+rpi1) ...
Selecting previously unselected package cpp.
Preparing to unpack .../05-cpp_4%3a8.3.0-1+rpi2_armhf.deb ...
Unpacking cpp (4:8.3.0-1+rpi2) ...
Selecting previously unselected package libcc1-0:armhf.
Preparing to unpack .../06-libcc1-0_8.3.0-6+rpi1_armhf.deb ...
Unpacking libcc1-0:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package libasan5:armhf.
Preparing to unpack .../07-libasan5_8.3.0-6+rpi1_armhf.deb ...
Unpacking libasan5:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package libubsan1:armhf.
Preparing to unpack .../08-libubsan1_8.3.0-6+rpi1_armhf.deb ...
Unpacking libubsan1:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package libgcc-8-dev:armhf.
Preparing to unpack .../09-libgcc-8-dev_8.3.0-6+rpi1_armhf.deb ...
Unpacking libgcc-8-dev:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package gcc-8.
Preparing to unpack .../10-gcc-8_8.3.0-6+rpi1_armhf.deb ...
Unpacking gcc-8 (8.3.0-6+rpi1) ...
Selecting previously unselected package gcc.
Preparing to unpack .../11-gcc_4%3a8.3.0-1+rpi2_armhf.deb ...
Unpacking gcc (4:8.3.0-1+rpi2) ...
Selecting previously unselected package libstdc++-8-dev:armhf.
Preparing to unpack .../12-libstdc++-8-dev_8.3.0-6+rpi1_armhf.deb ...
Unpacking libstdc++-8-dev:armhf (8.3.0-6+rpi1) ...
Selecting previously unselected package g++-8.
Preparing to unpack .../13-g++-8_8.3.0-6+rpi1_armhf.deb ...
Unpacking g++-8 (8.3.0-6+rpi1) ...
Selecting previously unselected package g++.
Preparing to unpack .../14-g++_4%3a8.3.0-1+rpi2_armhf.deb ...
Unpacking g++ (4:8.3.0-1+rpi2) ...
Selecting previously unselected package make.
Preparing to unpack .../15-make_4.2.1-1.2_armhf.deb ...
Unpacking make (4.2.1-1.2) ...
Selecting previously unselected package patch.
Preparing to unpack .../16-patch_2.7.6-3+deb10u1_armhf.deb ...
Unpacking patch (2.7.6-3+deb10u1) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../17-dpkg-dev_1.19.7_all.deb ...
Unpacking dpkg-dev (1.19.7) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../18-build-essential_12.6_armhf.deb ...
Unpacking build-essential (12.6) ...
Selecting previously unselected package libfakeroot:armhf.
Preparing to unpack .../19-libfakeroot_1.23-1_armhf.deb ...
Unpacking libfakeroot:armhf (1.23-1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../20-fakeroot_1.23-1_armhf.deb ...
Unpacking fakeroot (1.23-1) ...
Selecting previously unselected package libalgorithm-diff-perl.
Preparing to unpack .../21-libalgorithm-diff-perl_1.19.03-2_all.deb ...
Unpacking libalgorithm-diff-perl (1.19.03-2) ...
Selecting previously unselected package libalgorithm-diff-xs-perl.
Preparing to unpack .../22-libalgorithm-diff-xs-perl_0.04-5+b1_armhf.deb ...
Unpacking libalgorithm-diff-xs-perl (0.04-5+b1) ...
Selecting previously unselected package libalgorithm-merge-perl.
Preparing to unpack .../23-libalgorithm-merge-perl_0.08-3_all.deb ...
Unpacking libalgorithm-merge-perl (0.08-3) ...
Setting up libalgorithm-diff-perl (1.19.03-2) ...
Setting up bzip2 (1.0.6-9.2~deb10u1) ...
Setting up libfakeroot:armhf (1.23-1) ...
Setting up fakeroot (1.23-1) ...
update-alternatives: using /usr/bin/fakeroot-sysv to provide /usr/bin/fakeroot ( fakeroot) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/es/man1/fakeroot.1 .gz because associated file /usr/share/man/es/man1/fakeroot-sysv.1.gz (of link g roup fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man1/faked.1.gz because associated file /usr/share/man/es/man1/faked-sysv.1.gz (of link group f akeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/fakeroot.1 .gz because associated file /usr/share/man/fr/man1/fakeroot-sysv.1.gz (of link g roup fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/faked.1.gz because associated file /usr/share/man/fr/man1/faked-sysv.1.gz (of link group f akeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/fakeroot.1 .gz because associated file /usr/share/man/sv/man1/fakeroot-sysv.1.gz (of link g roup fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/faked.1.gz because associated file /usr/share/man/sv/man1/faked-sysv.1.gz (of link group f akeroot) doesn't exist
Setting up libasan5:armhf (8.3.0-6+rpi1) ...
Setting up make (4.2.1-1.2) ...
Setting up libmpfr6:armhf (4.0.2-1) ...
Setting up libmpc3:armhf (1.1.0-1) ...
Setting up patch (2.7.6-3+deb10u1) ...
Setting up libubsan1:armhf (8.3.0-6+rpi1) ...
Setting up libisl19:armhf (0.20-2) ...
Setting up cpp-8 (8.3.0-6+rpi1) ...
Setting up libalgorithm-diff-xs-perl (0.04-5+b1) ...
Setting up libcc1-0:armhf (8.3.0-6+rpi1) ...
Setting up libalgorithm-merge-perl (0.08-3) ...
Setting up dpkg-dev (1.19.7) ...
Setting up libgcc-8-dev:armhf (8.3.0-6+rpi1) ...
Setting up cpp (4:8.3.0-1+rpi2) ...
Setting up libstdc++-8-dev:armhf (8.3.0-6+rpi1) ...
Setting up gcc-8 (8.3.0-6+rpi1) ...
Setting up gcc (4:8.3.0-1+rpi2) ...
Setting up g++-8 (8.3.0-6+rpi1) ...
Setting up g++ (4:8.3.0-1+rpi2) ...
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mo de
Setting up build-essential (12.6) ...
Processing triggers for libc-bin (2.28-10+rpt2+rpi1) ...
volumio@volumio:~$ cd ~
volumio@volumio:~$ wget http://plugins.volumio.org/plugins/volumio/armhf/system_ controller/gpio-buttons/gpio-buttons.zip
--2021-12-04 21:44:35-- http://plugins.volumio.org/plugins/volumio/armhf/system _controller/gpio-buttons/gpio-buttons.zip
Resolving plugins.volumio.org (plugins.volumio.org)... 192.64.119.194
Connecting to plugins.volumio.org (plugins.volumio.org)|192.64.119.194|:80... co nnected.
HTTP request sent, awaiting response... 302 Found
Location: http://plugins.volumio.workers.dev/plugins/volumio/armhf/system_contro ller/gpio-buttons/gpio-buttons.zip [following]
--2021-12-04 21:44:40-- http://plugins.volumio.workers.dev/plugins/volumio/armh f/system_controller/gpio-buttons/gpio-buttons.zip
Resolving plugins.volumio.workers.dev (plugins.volumio.workers.dev)... 172.67.15 3.54, 104.21.34.20, 2606:4700:3030::ac43:9936, ...
Connecting to plugins.volumio.workers.dev (plugins.volumio.workers.dev)|172.67.1 53.54|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1096326 (1.0M) [application/zip]
Saving to: 'gpio-buttons.zip'
gpio-buttons.zip 100%[===================>] 1.04M 6.43MB/s in 0.2s
2021-12-04 21:44:41 (6.43 MB/s) - 'gpio-buttons.zip' saved [1096326/1096326]
volumio@volumio:~$ mkdir ./gpio-buttons
volumio@volumio:~$ miniunzip gpio-buttons.zip -d ./gpio-buttons
MiniUnz 1.01b, demo of zLib + Unz package written by Gilles Vollant
more info at http://www.winimage.com/zLibDll/unzip.html
gpio-buttons.zip opened
extracting:.....snip
volumio@volumio:~$ cd gpio-buttons
volumio@volumio:~/gpio-buttons$ volumio plugin install
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
Progress: 10
Status :Downloading plugin
nloading plugin at http://127.0.0.1:3000/plugin-serve/gpio-buttons.zip
Progress: 30
Status :Creating install location
Progress: 40
Status :Unpacking plugin
Unpacking plugin
Progress: 45
Status :Checking that the plugin is suitable for this version of Volumio The plu gin has no node version dependency information. The plugin has no Volumio versio n dependency information. The plugin may not work on this version of Volumio
Checking that the plugin is suitable for this version of Volumio The plugin has no node version dependency information. The plugin has no Volumio version depend ency information. The plugin may not work on this version of Volumio
Progress: 50
Status :Checking for duplicate plugin
Progress: 60
Status :Copying plugin to location
Progress: 70
Status :Installing necessary utilities
Progress: 70
Initializing config
Progress: 90
Status :Finalizing installation
Progress: 100
Status :GPIO Buttons Successfully Installed, Do you want to enable the plugin no w?
Done! Plugin Successfully Installed
volumio@volumio:~/gpio-buttons$ ^C
volumio@volumio:~/gpio-buttons$ cd /data/plugins/system_controller/gpio-buttons/
volumio@volumio:/data/plugins/system_controller/gpio-buttons$ npm install --save onoff@6.0.0
> epoll@4.0.1 install /data/plugins/system_controller/gpio-buttons/node_modules/epoll
> node-gyp rebuild
make: Entering directory '/data/plugins/system_controller/gpio-buttons/node_modules/epoll/build'
CXX(target) Release/obj.target/epoll/src/epoll.o
SOLINK_MODULE(target) Release/obj.target/epoll.node
COPY Release/epoll.node
make: Leaving directory '/data/plugins/system_controller/gpio-buttons/node_modules/epoll/build'
npm WARN gpio-buttons@0.8.1 No repository field.
+ onoff@6.0.0
added 2 packages from 4 contributors, updated 4 packages and audited 61 packages in 12.827s
found 7 vulnerabilities (3 low, 3 high, 1 critical)
run `npm audit fix` to fix them, or `npm audit` for details
please re-flash the latest image on a SD-card and to the procedure again, you already had some attempt in your system
OK . everything made new. and now it worked. had a few errors during installation, but it works.
Hi M1ck,
Could you summarize or show only commands for ssh (GPIO buttons install)?
Hi Alain
I posted how I did in this thread here post 2 although, further down Ashthespy posted a more streamlined way of doing this.
