Initial Volumio configuration without client update - how to!
Hi, for some reasons I would like to stick to version 3.631 of Volumio.
I am using RPI zero v2 with wi-fi connectivity.
However, every time I am starting with new configuration via Android app I am being forced to provide wi-fi network, after which update to newest OS is starting. Hence I would like to know how to simply avoid initial update. Later on once GUI is visible I am able to switch auto updates off, but initially it is not possible. I am thinking of connectig RPI to network via eth.adapter by cable and start initial configuration via local webpage, but not sure if that will change anything. or copy configuration file with stored wi-fi credentials etc. to fresh installation so that initial config won’t be required.
In short, how to install old image OS and avoid initial update to newest version. (via android app. I see it is impossible).
Thanks in advance for your feedback.
