Will there be an OTA for an odroid or take it here?
I am at a loss, I have downloaded the new version and flashed in onto an SD card, the result all the faults remain. I cannot access Qobuz which was why I wanted Volumio in the first place, my Music library on an external HDD keeps disappearing, if I change any settings I cannot keep the changes etc etc. I am using a Pi 3 with Digieone hat bought as a complete player which at present is no use to me at all. I see I am not the only one with problems, what I donāt see is any sign of Volumio being fixed. I will try and supply further detail if anyone can suggest how to fix this
Please can you do the following: remove the Dac, boot and select headphone output Volumio settings.
Other details, have you enable myvolumio for this device?
Yours problems may come from a PSu failure or a corrupted SD card.
I have already tried that, changing the output in settings, I got no output from the headphones, incidentally I have tried the device in two separate parts of my network, connected to two different different network cables and dacs, The first sd was supplied by Allo and was replaced by one I bought new and flashed with an image downloaded from Volumio, so if one is corrupted so was the other. As for a corrupted PSu what is that, the power supply of which I have tried to different ones, the Pi itself or what. Volumio went wrong at the same time as it did for many others, the fix which has worked for some people does nothing here.
Yes myvolumio is enabled, at least it shows as enabled but does not work.
I mean removing physically the Dac
The external DAC connected by SPDIF ?, I have two, I have disconnected and reconnected both of them, particularly when I tried using headphones.
I suppose that counts as removing physically the Dac, if not I am at a loss as to your meaning.
@volumio ⦠now fixed with a reset and rescan, but first and more critically I plugged the Pi and NAS directly into a range extender with a strong connection to the router. Going very fast now for local files and snappy for Tidal as well. Happy again
After the update, there is still no connection to Tidal
with the newest version on raspi zero i cant connect to my wifi anymore. in the network section all! of my wifi networks dont show up anymore.
Dear Volumio,
Iām a big fan of Volumio and I have two Volumio devices.
First one is odroid C1+ and another one is raspberry pi 3b.
I tried to update on Raspberry pi3, and the update is working without any issues in my case.
However, there is no update available when I tried to check updates on odroid C1+.
The current version is 2.877.
Do I need to fresh install 2.916?
I was wondering if you could share the ETA of update on odroid C1+.
Best Regards,
Chris Choe.
A new image 2.916 for the C1/C1+ was built last Friday night.
Did you try to set test mode on C1+ and then check for updates?
Thank you for the feedback.
Update on odroid C1+ is completed under test mode enabled.
Best Regards,
Chris Choe.
Hi!
Since the update 2.915 both my Raspberry pi 3b+ is connecting to spotify again and i can see my playlists, great!
But after playing a few songs it keeps stoping. I have tried disconnected the device and all the cables, rebooted my hole system and nothing works. Sometimes it plays one song then it stops and sometimes it plays 3-5 songs then it stops. Anyone else having this problem?
Thanks for all your hard work and fast response to fix issues like this, Volumio crew rocks!
/Nash
U mnie też nie dziaÅa tidal i spotify nie mogÄ ich wÅaczycā¦wersja 2.861 i nie chce sie zaktualizowacā¦
English please
I updated mine because the expired ca-certificate issue was preventing the Radio Paradise feeds from working. The update to 2.915 released Sept 30th fixed the problem.
Although the UI shows I have Myvolumio neither Qobuz or Tidal appears as an option for connection, so Iām guessing that I need to enable myvolumio, how do I do this please ?
Did you activate the services under āsourcesā?
Settings > Sources (2nd from top, I think)
Now some songs stop playing in Spotify after 30 seconds and some after a minute. Anyone else having this issue?
Hi, Iām using Khadas VIM3L and Toneboard. I tried the update - the Volumio app tells me Iām running v2.748 but when I click on check for updates it tells me Iām on the latest version?
Any advice much appreciated
