I cannot find answer to my issue.
I plan to make a button in Home Assistant as the URL action to shortcut restart Volumio when needed.
I have tried to check the Firefox developer mode to find out what is the URL directing after the pressing ‘‘Restart’’ button. Could not found as looks like is directing to JavaScript command.
Is there someone who knows who could guide me? http://local.host/XXXXXXXX???
I mean using the IR plugin. I have buttons on a physical remote that can turn the Pi off, or do ‘volumio vrestart’. That may not be the type of solution that you’re looking for though.
Is it posibble to run the script base on url request ? I do not have an IR transmitter set up from Home Assistant yet and would like to avoid if that can be arranged in easier way fo mh set-up.
Anyway thanks!
