hey guys , i have rasberry Pi4 , and i want to make the WiFi signal stronger and better, becouse hi is in a box, can you help me , maybe in config or bvoot can something to do it, THX
Nothing you can do…
IMHO powerline is the best solution
Ethernet cable.
I don’t use any cases with mine as they reduce the wifi signal. Metal cases are the worst.
