How to limit Sound Quality to 24bit-96kHz in streaming mode
Dear Volumio community, I have been gifted an Audio Note DAC2 Signature and I connected it to a Volumio Streamer with Allo DigiOne HAT. The DAC does not play 192 kHz content so I need to limit the output of music to 96 kHz. I know that there is a drop down menu for Sound Quality under Sources section but it didnt work for me. I chose Sound Quality to FLAC Hi-Res 24bit up to 96 kHz but Qobuz still sends 192 kHz data. How can I limit Qobuz output ? (I also tried Audio Resampling under Playback Options but no result)
The Allo Digione supports up to 24bit / 192kHz??
yes, there is no problem with streaming 192 kHz, my problem is to limit it to 96 kHz.
Then I didn’t get your ask correct.
You can try it with FusionDSP Plugin, didn’t test it myself, You might give it a try.
Or in Qobuz:
But keep in mind, If Qobuz only loaded an album @192kHz, then the @192kHz you get.
Although it is installed, I dont want to activate Fusion DSP but for sure it is an option. Will give it a try if I have no other option.
This thing didnt work for me. But I searched that I need to set Volume Options - Mixer Type to Software. Mine was set to None… I will try this now
I did try changing the mixer type to Software and even tried Resampling Target Sample Rate to 96 kHz but still… it doesnt work.
