I was wondering if you were aware of any graphical interface able to easily create complex configuration files for CamillaDSP? I have in mind crossover and FIR correction for 3 ways (6 channels) speakers. I know everything could be directly coded with text files, but when working with the graphic software provided with AnalogDevices Shark DSP chips, it makes setup and adjustment much more handy.
Maybe someone has same kind of software able to output the config file that might be loaded in CamillaDSP.
Have the same functions ported through a web interface might be overly complicated.
Iâm looking to perform some filtering in volumio to perform real time click reduction in vinyl records. From my understanding I should be able to apply a camilla dsp pipeline in fusion dsp as itâs essentially what it is doing. If I want to configure my own pipeline, where can I create that in fusion dsp? Or should I just edit the camilladsp.conf.yml manually and insert my pipeline filters in there?
