Is there any easy way how to disable Volumio’s internal upnp ( upmpdcli)?
I have two Volumio devices and some other streaming devices (eg Pioneer Blue Ray) in one home network, installed BubbleUpnp on my Synology NAS and started Lumin on my iPad.
What I can see in Lumin’s streamers list is that both Volumios are shown twice (4 instead 2). I believe the first one is due to internal Volumio upnp and the second one due to Bubble Upnp running on my NAS. When I switched Bubble Upnp off, I can onle see each Volumio device once in Lumin app - which is fine. However I don’t see other streaming devices - Pioneer BD.
So what I think I would need to do instead is to disable internal volumio upnp ( upmpdcli) while keep Bubble upnp running. In this case I should see each volumio device just once and also will see Pioneer BD.
Is it possible to do it?
