I have a MiniPC with Windows which has an SSD attached through an external USB port. Volumio is installed on the external SSD. My music files are on the MiniPC’s internal drive.This is a dual boot installation. I’ve tried many times but have been unable to add the internal drive where the music files are located to Volumio. Now I think the best thing to do is to simply make a directory on the same external SSD as Volumio and use Volumio’s finder/scan function to index and add the music files. My question: How do you copy the Music file containing the mp3 files from Windows and add them to the SSD containing Volumio? I need the command sequence if possible.
TIA!
2 ways:
- use filezilla or winscp (preferred way)
- Type
\\<your-devices-ip\in the windows explorer
