How to connect a NFS share to Linux based musicplayers
NFS uses about 30 % less processor capacity of your NAS then SAMBA or CIFS. Thats why.
  1. Check if NFS on your NAS is enabled.
  2. Check if SSH on your player is enabled.
Commands (capitals our important)
ssh volumio@
pswd:volumio
command
cd /data/INTERNAL/ (change to this directory)
command
pwd (prints now directory where you are working)
command
mkdir music (create directory called music)
command
ls (list you see now your directory music)
command
sudo nano /etc/fstab/
pswd volumio
below the other entry´s ad this line one entry add the time
use tab button to jump to next sextion of the file (or columms)
/data/INTERNAL/music
nfs
users,rw,auto
0
0
press
confirm with y
enter
check if our entry is there
close windows
reboot
update music libary in volumio
Jan
Just mount the NFS using the webUi… No need cmd line :wink:
