Nowdays, i find many people always ask how to make the router as the switch? If you also want to know ,you can follow:
A:1. connection: ADSL—- routing in A WAN —-LAN - B LAN routing —-LAN mouth —- computer.
2. change the router LAN port IP (changed to other network address or a different network address) and other equipment to avoid network conflict.
3.close the router DHCP server, connect the network cable to the router LAN port (WAN portidle)
Following the detailed setup steps:
change the router LAN port IP:
Input 192.168.0.1 landing router management interface in the browser address bar, click the”advanced settings” - ”LAN port settings”, the LAN port address default to 192.168.0.1, change to a different address, to avoid conflicts within the network and equipment. -
close the router DHCP server:
Landing routers and click on “DHCP server” - ”DHCP services” will “enable” before the hook can be removed off the DHCP server.
Wish this can help you. As Cisco 2960 switch had brought us many surpries, Router-Switch annouced to offer huge disscount for network users.It seems good.
