How to calibrate touch screen
Hi
Just installed 3.5" Ali screen and followed instruction I found here.
It went well but I have slide problem with the touch interface.
I rotated the screen 180 deg but unfortunately the touch did not rotate.
So everything that is supposed to be in the top right corner is in the bottom left corner.
Is there any settings I could try? I am not tech savvy or linux guru :blush:
I am using rpi3b and the screen is 3.5 from Ali
Which of them? :wink:
More information (manufacturer and exact model name) about the screen is required. If manufacturer and model should be unknown post a picture of the screen’s printed circuit board and a link to the page where you bought the screen from.
Thanks it just cure itself I was messing with rotate in the web interface and some how it just works now :slight_smile:
Thank you
yeah don’t under estimate @gvolt powers…
