How to add Rivo's SD card to Roon
How can I add my Volumio Rivo’s SD card to Roon? I have tried the “Add network share” option, without success.
I can play its content from Volumio without any problem.
You can stream music from the Roon server using Volumio as an endpoint, there is no way to play with Roon from a Volumio mounted share. As you need a Rock server (database) on your network, why not copy your “Volumio” music there?
Ok, thanks.
