Hi!
Well done!.
Even if I have not yet tried, few questions:
Why do you need to “extended Ui”. It can’t be done in plugin?
Why do you compile bluez at install time?. Is it long on a RPI ? . Maybe you could provide a pre compiled version for the plugin .
Can you provide a zip file to easily install your plugin?
Thanks!
Edit : typo correction
Well done geeks-r-us. I think that this is s sufficiently important topic to open it’s own appropriately named thread so that people can find it easily & submit comments etc. Would you mind doing that please? Thanks in anticipation
However, I am too noob to get this running - think I need to wait for a more step-by-step description on how to install this or a simple plugin…
Thanks again,
I wasn’t able to send the found bluetooth devices to the browser by only using the plugin api.
Because there are more platforms that could provide bluetooth support beside the RPi and I don’t have access to them to provide packages for all of them. Installation take about 2 minutes on a RPi 3
[/quote]
I’ll prepare it and start a new thread with them as suggested by chsims1
Ok thanks for the answer.
For the different arch, you just need a x86 version and a armv6 version to cover all volumio devices. With a copy detection at install time to download the required binaries. It is done like that in volspotconnect2.
For the Ui I think it is problematic… It is more complicated to install and may break OTA update. Unless it is integrated in volumio…
I think there is some workaround. I don’t know exactly the problem, but it’s to select a output that not appears in the output list, you can use things such it is done in volsimpleequal. But as I haven’t tested yet I’m not sure it is your problem…
