The log is pasted below.
Thanks for your help.
Jeff
2016-12-31T01:30:00.523Z - info: -------------------------------------------
2016-12-31T01:30:00.616Z - info: ----- Volumio2 ----
2016-12-31T01:30:00.622Z - info: -------------------------------------------
2016-12-31T01:30:00.628Z - info: ----- System startup ----
2016-12-31T01:30:00.630Z - info: -------------------------------------------
2016-12-31T01:30:02.855Z - info: Plugin folders cleanup
2016-12-31T01:30:02.862Z - info: Scanning into folder /volumio/app/plugins/
2016-12-31T01:30:02.879Z - info: Scanning category audio_interface
2016-12-31T01:30:02.889Z - info: Scanning category miscellanea
2016-12-31T01:30:02.909Z - info: Scanning category music_service
2016-12-31T01:30:02.932Z - info: Scanning category plugins.json
2016-12-31T01:30:02.939Z - info: Scanning category system_controller
2016-12-31T01:30:02.962Z - info: Scanning category user_interface
2016-12-31T01:30:02.975Z - info: Scanning into folder /data/plugins/
2016-12-31T01:30:02.985Z - info: Scanning category music_service
2016-12-31T01:30:03.005Z - info: Plugin folders cleanup completed
2016-12-31T01:30:03.017Z - info: Loading plugins from folder /volumio/app/plugins/
2016-12-31T01:30:03.121Z - info: Loading plugins from folder /data/plugins/
2016-12-31T01:30:03.164Z - info: Loading plugin “system”…
2016-12-31T01:30:03.726Z - info: Loading plugin “appearance”…
2016-12-31T01:30:07.204Z - info: Loading plugin “network”…
2016-12-31T01:30:07.933Z - info: Loading plugin “services”…
2016-12-31T01:30:07.995Z - info: Loading plugin “alsa_controller”…
2016-12-31T01:30:09.080Z - info: Loading plugin “volumio_command_line_client”…
2016-12-31T01:30:09.150Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:09.170Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:09.177Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:09.455Z - info: Loading plugin “volumiodiscovery”…
2016-12-31T01:30:10.068Z - info: Applying required configuration parameters for plugin volumiodiscovery
2016-12-31T01:30:10.351Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2016-12-31T01:30:10.361Z - info: Loading plugin “upnp”…
2016-12-31T01:30:10.411Z - info: [1483147810405] Starting Upmpd Daemon
2016-12-31T01:30:10.504Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2016-12-31T01:30:10.512Z - info: Loading plugin “airplay_emulation”…
2016-12-31T01:30:10.566Z - info: [1483147810545] Starting Shairport Sync
2016-12-31T01:30:10.588Z - info: Loading plugin “mpd”…
2016-12-31T01:30:10.935Z - info: Loading plugin “networkfs”…
2016-12-31T01:30:11.230Z - info: Loading plugin “alarm-clock”…
2016-12-31T01:30:12.651Z - info: Loading plugin “webradio”…
2016-12-31T01:30:16.585Z - info: Loading plugin “i2s_dacs”…
2016-12-31T01:30:16.666Z - info: I2S DAC not set, start Auto-detection on USB Bus
2016-12-31T01:30:16.729Z - info: Loading plugin “albumart”…
2016-12-31T01:30:16.806Z - info: Plugin example_plugin is not enabled
2016-12-31T01:30:16.817Z - info: Loading plugin “updater_comm”…
2016-12-31T01:30:19.474Z - info: Plugin mpdemulation is not enabled
2016-12-31T01:30:19.485Z - info: Loading plugin “websocket”…
2016-12-31T01:30:19.909Z - info: Loading plugin “spop”…
2016-12-31T01:30:26.972Z - info: Applying required configuration parameters for plugin spop
2016-12-31T01:30:27.045Z - info: ___________ START PLUGINS ___________
2016-12-31T01:30:27.115Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2016-12-31T01:30:27.135Z - info: [1483147827118] CoreMusicLibrary::Adding element Webradio
2016-12-31T01:30:27.354Z - info: Loading i18n strings for locale en
2016-12-31T01:30:28.285Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:28.291Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:28.305Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:28.308Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:28.310Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-31T01:30:28.615Z - info: BOOT COMPLETED
2016-12-31T01:30:29.525Z - info: [1483147829495] CoreStateMachine::resetVolumioState
2016-12-31T01:30:29.566Z - info: [1483147829529] CoreStateMachine::getcurrentVolume
2016-12-31T01:30:29.625Z - info: CoreCommandRouter::volumioRetrievevolume
2016-12-31T01:30:29.895Z - info: [1483147829829] CoreStateMachine::updateTrackBlock
2016-12-31T01:30:29.925Z - info: [1483147829899] CorePlayQueue::getTrackBlock
2016-12-31T01:30:32.744Z - info: SpopD Daemon Started
2016-12-31T01:30:33.309Z - info: MPD running with PID577 ,establishing connection
2016-12-31T01:30:33.924Z - info: Setting Device type: Raspberry PI
2016-12-31T01:30:34.856Z - info: [1483147834850] VolumeController:: Volume=100 Mute =false
2016-12-31T01:30:34.874Z - info: [1483147834868] CoreStateMachine::pushState
2016-12-31T01:30:34.884Z - info: [1483147834878] CoreStateMachine::getState
2016-12-31T01:30:34.893Z - info: [1483147834887] CorePlayQueue::getTrack 0
2016-12-31T01:30:34.902Z - info: CoreCommandRouter::volumioPushState
2016-12-31T01:30:34.908Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T01:30:34.928Z - info: [1483147834922] InterfaceWebUI::pushState
2016-12-31T01:30:35.022Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T01:30:35.659Z - info: Reloading queue from file
2016-12-31T01:30:36.011Z - info: Volumio called home
2016-12-31T01:30:36.060Z - info:
2016-12-31T01:30:36.297Z - info: Setting volume on startup at disabled
2016-12-31T01:30:36.530Z - info:
[1483147836521] ---------------------------- Client requests Volume disabled
2016-12-31T01:30:36.561Z - info: [1483147836554] VolumeController::SetAlsaVolumedisabled
2016-12-31T01:30:36.618Z - info: [1483147836611] ------------------------------ 93ms
2016-12-31T01:30:37.256Z - info: mDNS: Found device Volumio
2016-12-31T01:30:37.541Z - info: [1483147837514] VolumeController::Volume 100
2016-12-31T01:30:37.555Z - info: [1483147837544] CoreStateMachine::pushState
2016-12-31T01:30:37.575Z - info: [1483147837556] CoreStateMachine::getState
2016-12-31T01:30:37.606Z - info: [1483147837576] CorePlayQueue::getTrack 0
2016-12-31T01:30:37.625Z - info: CoreCommandRouter::volumioPushState
2016-12-31T01:30:37.635Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T01:30:37.666Z - info: [1483147837641] InterfaceWebUI::pushState
2016-12-31T01:30:37.984Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T01:30:38.185Z - info: [1483147838175] Shairport-Sync Started
2016-12-31T01:30:38.191Z - info: Upmpdcli Daemon Started
2016-12-31T01:30:38.217Z - info: Connecting to daemon
2016-12-31T01:30:39.416Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2016-12-31T01:30:39.423Z - info: [1483147839417] CoreMusicLibrary::Adding element Spotify
2016-12-31T01:30:39.655Z - info: FIRST BRANCH
2016-12-31T01:30:41.255Z - info: Spotify access token expires at 1483151438286
2016-12-31T01:30:41.264Z - info: Spotify access token is BQBefP7nGpdHg0r9qOWwgP0RRap7_DE2s33cLC21YsTrqCBBkDYsg2uNCp35rH4RDRsB23eOSywdVV2-xy2tRQ
2016-12-31T01:30:41.272Z - info: Spotify credentials grant success
2016-12-31T19:03:01.041Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-31T19:03:01.187Z - info: CoreCommandRouter::volumioGetState
2016-12-31T19:03:01.194Z - info: [1483210981188] CoreStateMachine::getState
2016-12-31T19:03:01.200Z - info: [1483210981195] CorePlayQueue::getTrack 0
2016-12-31T19:03:01.211Z - info:
[1483210981202] ---------------------------- Client requests Volumio state
2016-12-31T19:03:01.223Z - info: [1483210981217] InterfaceWebUI::pushState
2016-12-31T19:03:01.248Z - info: [1483210981243] ------------------------------ 62ms
2016-12-31T19:03:01.469Z - info: [1483210981463] Listing playlists
2016-12-31T19:03:01.598Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2016-12-31T19:03:01.644Z - info:
[1483210981635] ---------------------------- Client requests Menu Items
2016-12-31T19:03:01.750Z - info: [1483210981745] ------------------------------ 110ms
2016-12-31T19:03:13.224Z - info: CoreCommandRouter::volumioGetBrowseSources
2016-12-31T19:03:13.243Z - info: CoreCommandRouter::volumioGetQueue
2016-12-31T19:03:13.251Z - info: [1483210993245] CoreStateMachine::getQueue
2016-12-31T19:03:13.259Z - info: [1483210993253] CorePlayQueue::getQueue
2016-12-31T19:03:13.265Z - info:
[1483210993260] ---------------------------- Client requests Volumio queue
2016-12-31T19:03:13.272Z - info: [1483210993269] InterfaceWebUI::pushQueue
2016-12-31T19:03:13.285Z - info: []
2016-12-31T19:03:13.296Z - info: [1483210993291] ------------------------------ 55ms
2016-12-31T19:03:14.612Z - info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
2016-12-31T19:29:49.147Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2016-12-31T19:29:51.994Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2016-12-31T19:29:53.165Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2016-12-31T19:29:58.018Z - info: CoreCommandRouter::getUIConfigOnPlugin
2016-12-31T19:29:58.108Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T19:29:58.375Z - info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
2016-12-31T19:30:02.106Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T19:30:06.122Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T19:30:09.106Z - info: CoreCommandRouter::executeOnPlugin: mpd , rescanDb
2016-12-31T19:30:09.118Z - info: [1483212609112] ControllerMpd::sendMpdCommand rescan
2016-12-31T19:30:09.128Z - info: [1483212609121] sending command…
2016-12-31T19:30:09.156Z - info: [1483212609149] ControllerMpd::sendMpdCommand status
2016-12-31T19:30:09.170Z - info: Mpd Status Update: update
2016-12-31T19:30:09.186Z - info:
[1483212609176] ---------------------------- MPD announces state update
2016-12-31T19:30:09.217Z - info: [1483212609209] parsing response…
2016-12-31T19:30:09.236Z - info: [1483212609229] sending command…
2016-12-31T19:30:09.253Z - info: [1483212609243] ControllerMpd::getState
2016-12-31T19:30:09.265Z - info: [1483212609256] ControllerMpd::sendMpdCommand status
2016-12-31T19:30:09.279Z - info: [1483212609270] sending command…
2016-12-31T19:30:09.302Z - info: [1483212609295] parsing response…
2016-12-31T19:30:09.313Z - info: [1483212609307] parsing response…
2016-12-31T19:30:09.339Z - info: [1483212609331] ControllerMpd::parseState
2016-12-31T19:30:09.355Z - info: Command Router : Notfying DB Updatetrue
2016-12-31T19:30:09.385Z - info: [1483212609374] ControllerMpd::parseState
2016-12-31T19:30:09.400Z - info: [1483212609390] ControllerMpd::pushState
2016-12-31T19:30:09.409Z - info: CoreCommandRouter::servicePushState
2016-12-31T19:30:09.442Z - info: [1483212609435] CoreStateMachine::syncState
2016-12-31T19:30:09.451Z - info: [1483212609443] CorePlayQueue::getTrack 0
2016-12-31T19:30:09.463Z - info: STATE SERVICE {“status”:“stop”,“position”:null,“seek”:null,“duration”:null,“samplerate”:null,“bitdepth”:null,“channels”:null,“random”:false,“updatedb”:true,“repeat”:false,“isStreaming”:false,“title”:null,“artist”:null,“album”:null,“uri”:null}
2016-12-31T19:30:09.472Z - info: CURRENT POSITION 0
2016-12-31T19:30:09.486Z - info: [1483212609474] CoreStateMachine::syncState stateService stop
2016-12-31T19:30:09.497Z - info: [1483212609487] CoreStateMachine::syncState currentStatus stop
2016-12-31T19:30:09.507Z - info: [1483212609499] CoreStateMachine::pushState
2016-12-31T19:30:09.516Z - info: [1483212609509] CoreStateMachine::getState
2016-12-31T19:30:09.527Z - info: [1483212609517] CorePlayQueue::getTrack 0
2016-12-31T19:30:09.537Z - info: CoreCommandRouter::volumioPushState
2016-12-31T19:30:09.548Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T19:30:09.567Z - info: [1483212609554] InterfaceWebUI::pushState
2016-12-31T19:30:09.588Z - info: [1483212609580] No code
2016-12-31T19:30:09.597Z - info: [1483212609589] CoreStateMachine::pushState
2016-12-31T19:30:09.605Z - info: [1483212609597] CoreStateMachine::getState
2016-12-31T19:30:09.614Z - info: [1483212609605] CorePlayQueue::getTrack 0
2016-12-31T19:30:09.619Z - info: CoreCommandRouter::volumioPushState
2016-12-31T19:30:09.631Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T19:30:09.651Z - info: [1483212609644] InterfaceWebUI::pushState
2016-12-31T19:30:09.698Z - info: [1483212609684] ------------------------------ 525ms
2016-12-31T19:30:09.735Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T19:30:09.759Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T19:30:10.112Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T19:30:14.128Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T19:30:18.147Z - info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
2016-12-31T20:23:07.427Z - info: Mpd Status Update: database
2016-12-31T20:23:07.435Z - info:
[1483215787429] ---------------------------- MPD announces state update
2016-12-31T20:23:07.455Z - info: [1483215787450] ControllerMpd::sendMpdCommand status
2016-12-31T20:23:07.459Z - info: Mpd Status Update: update
2016-12-31T20:23:07.461Z - info:
[1483215787459] ---------------------------- MPD announces state update
2016-12-31T20:23:07.480Z - info: [1483215787475] ControllerMpd::getState
2016-12-31T20:23:07.489Z - info: [1483215787482] ControllerMpd::sendMpdCommand status
2016-12-31T20:23:07.497Z - info: [1483215787492] sending command…
2016-12-31T20:23:07.516Z - info: [1483215787510] ControllerMpd::getState
2016-12-31T20:23:07.522Z - info: [1483215787517] ControllerMpd::sendMpdCommand status
2016-12-31T20:23:07.529Z - info: [1483215787524] sending command…
2016-12-31T20:23:07.541Z - info: [1483215787533] sending command…
2016-12-31T20:23:07.558Z - info: [1483215787553] parsing response…
2016-12-31T20:23:07.568Z - info: [1483215787562] parsing response…
2016-12-31T20:23:07.576Z - info: [1483215787570] parsing response…
2016-12-31T20:23:07.595Z - info: [1483215787578] ControllerMpd::parseState
2016-12-31T20:23:07.602Z - info: Command Router : Notfying DB Updatefalse
2016-12-31T20:23:07.635Z - info: [1483215787621] ControllerMpd::parseState
2016-12-31T20:23:07.643Z - info: [1483215787638] ControllerMpd::parseState
2016-12-31T20:23:07.660Z - info: [1483215787654] ControllerMpd::pushState
2016-12-31T20:23:07.666Z - info: CoreCommandRouter::servicePushState
2016-12-31T20:23:07.680Z - info: [1483215787668] CoreStateMachine::syncState
2016-12-31T20:23:07.687Z - info: [1483215787681] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.705Z - info: STATE SERVICE {“status”:“stop”,“position”:null,“seek”:null,“duration”:null,“samplerate”:null,“bitdepth”:null,“channels”:null,“random”:false,“updatedb”:false,“repeat”:false,“isStreaming”:false,“title”:null,“artist”:null,“album”:null,“uri”:null}
2016-12-31T20:23:07.711Z - info: CURRENT POSITION 0
2016-12-31T20:23:07.718Z - info: [1483215787712] CoreStateMachine::syncState stateService stop
2016-12-31T20:23:07.732Z - info: [1483215787719] CoreStateMachine::syncState currentStatus stop
2016-12-31T20:23:07.742Z - info: [1483215787736] CoreStateMachine::pushState
2016-12-31T20:23:07.749Z - info: [1483215787742] CoreStateMachine::getState
2016-12-31T20:23:07.752Z - info: [1483215787750] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.770Z - info: CoreCommandRouter::volumioPushState
2016-12-31T20:23:07.772Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T20:23:07.786Z - info: [1483215787780] InterfaceWebUI::pushState
2016-12-31T20:23:07.802Z - info: [1483215787797] No code
2016-12-31T20:23:07.809Z - info: [1483215787803] CoreStateMachine::pushState
2016-12-31T20:23:07.815Z - info: [1483215787809] CoreStateMachine::getState
2016-12-31T20:23:07.821Z - info: [1483215787815] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.823Z - info: CoreCommandRouter::volumioPushState
2016-12-31T20:23:07.829Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T20:23:07.842Z - info: [1483215787833] InterfaceWebUI::pushState
2016-12-31T20:23:07.854Z - info: [1483215787849] ControllerMpd::pushState
2016-12-31T20:23:07.860Z - info: CoreCommandRouter::servicePushState
2016-12-31T20:23:07.866Z - info: [1483215787861] CoreStateMachine::syncState
2016-12-31T20:23:07.869Z - info: [1483215787867] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.872Z - info: STATE SERVICE {“status”:“stop”,“position”:null,“seek”:null,“duration”:null,“samplerate”:null,“bitdepth”:null,“channels”:null,“random”:false,“updatedb”:false,“repeat”:false,“isStreaming”:false,“title”:null,“artist”:null,“album”:null,“uri”:null}
2016-12-31T20:23:07.886Z - info: CURRENT POSITION 0
2016-12-31T20:23:07.888Z - info: [1483215787887] CoreStateMachine::syncState stateService stop
2016-12-31T20:23:07.891Z - info: [1483215787889] CoreStateMachine::syncState currentStatus stop
2016-12-31T20:23:07.893Z - info: [1483215787892] CoreStateMachine::pushState
2016-12-31T20:23:07.906Z - info: [1483215787894] CoreStateMachine::getState
2016-12-31T20:23:07.909Z - info: [1483215787907] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.911Z - info: CoreCommandRouter::volumioPushState
2016-12-31T20:23:07.914Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T20:23:07.931Z - info: [1483215787928] InterfaceWebUI::pushState
2016-12-31T20:23:07.947Z - info: [1483215787946] No code
2016-12-31T20:23:07.950Z - info: [1483215787948] CoreStateMachine::pushState
2016-12-31T20:23:07.953Z - info: [1483215787951] CoreStateMachine::getState
2016-12-31T20:23:07.965Z - info: [1483215787953] CorePlayQueue::getTrack 0
2016-12-31T20:23:07.967Z - info: CoreCommandRouter::volumioPushState
2016-12-31T20:23:07.970Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-31T20:23:07.985Z - info: [1483215787973] InterfaceWebUI::pushState
2016-12-31T20:23:08.012Z - info: [1483215788006] ------------------------------ 589ms
2016-12-31T20:23:08.024Z - info: [1483215788019] ------------------------------ 562ms
2016-12-31T20:23:08.052Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T20:23:08.063Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T20:23:08.075Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2016-12-31T20:23:08.086Z - info: Pushing Favourites {“service”:“mpd”,“uri”:"",“favourite”:false}
2017-01-01T15:28:16.894Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2017-01-01T15:28:17.294Z - info: CoreCommandRouter::volumioGetState
2017-01-01T15:28:17.300Z - info: [1483284497295] CoreStateMachine::getState
2017-01-01T15:28:17.307Z - info: [1483284497301] CorePlayQueue::getTrack 0
2017-01-01T15:28:17.315Z - info:
[1483284497308] ---------------------------- Client requests Volumio state
2017-01-01T15:28:17.328Z - info: [1483284497322] InterfaceWebUI::pushState
2017-01-01T15:28:17.346Z - info: [1483284497340] ------------------------------ 52ms
2017-01-01T15:28:17.366Z - info: [1483284497361] Listing playlists
2017-01-01T15:28:17.394Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2017-01-01T15:28:17.425Z - info:
[1483284497405] ---------------------------- Client requests Menu Items
2017-01-01T15:28:17.603Z - info: [1483284497597] ------------------------------ 192ms
2017-01-01T15:28:20.441Z - info: CoreCommandRouter::volumioGetBrowseSources
2017-01-01T15:28:20.492Z - info: CoreCommandRouter::volumioGetQueue
2017-01-01T15:28:20.499Z - info: [1483284500494] CoreStateMachine::getQueue
2017-01-01T15:28:20.506Z - info: [1483284500500] CorePlayQueue::getQueue
2017-01-01T15:28:20.515Z - info:
[1483284500507] ---------------------------- Client requests Volumio queue
2017-01-01T15:28:20.519Z - info: [1483284500518] InterfaceWebUI::pushQueue
2017-01-01T15:28:20.522Z - info: []
2017-01-01T15:28:20.540Z - info: [1483284500534] ------------------------------ 47ms
2017-01-01T15:28:21.841Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2017-01-01T15:28:22.733Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2017-01-01T15:28:23.756Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2017-01-01T15:28:30.516Z - info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
2017-01-01T15:28:39.950Z - info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
