Help with Broken Piece on Volumio Rivo Ethernet Port
Hi, the thin piece on the top middle portion of the ethernet port on the rear of my Volumio Rivo broke off. Now, the ethernet cable will not click and sit right in the ethernet port. The cable comes loose and ethernet disconnects. Has this happened to anyone else, and would anyone have any tips or ideas about how i might fix the issue? Is there a way to fix the issue or a way to repair it? I appreciate your help. (I don’t know if there’s a way to upload a photo.) Thanks!
Hi Jrodude,
Unfortunately is not possible to fix it but we can repair it for you. Please DM me support@volumio.com - and ill let you know all the infos.
Best Regards,
Marco Volumio
