Works for me, except for the first time I click on My Playlists. There the progress bar takes a long time to complete and in the end nothing happens. Going back and clicking My Playlists again it works like a charm. (latest version from 15 June)
Yeah, I think that’s a timing issue when I first refresh the access token asynchronously. Will be fixing that when I add some pagination to the results.
For me everything seams to work perfectly!
All the lists come with many (correct) entries and all album arts.
Playback is working and album art is shown at pb screen.
Good work!!
Thx a lot!!
Just rebuilt my Volumio installation and discovered the Playlists issue. Followed your instructions for replacing the index.js file with the updated version with the token and they now appear.
Excellent news! I really like the “My Top Artists”, because I can then click on “Related Artists” and build up interesting playlists. Which reminds me, I need to get the grid view working in that screen.
I installed the modified index.js and it seems to work.
Well, at least a little more than before: I can only see my first 20 playlists, the (alphabetically) first 50 saved albums
Hi There, it’s a general problem that we need to add pagination into the UI for all kinds of things. The Spotify Web API fully supports getting chunks of results, its more of a matter of how to add it to the UI. Making too many Spotify API requests at once can trigger its rate limit caps.
Kind of busy right now, but when I next get some free time I will attempt to add pagination of results throughout the interface.
I just checked on both of my volumio systems and one shows 20 playlists, the other shows 50. That’s really odd, pretty sure I have the same code on both systems, and I did verify on the system only showing 20 that the API call is passing in teh “{limit : 50}” parameter.
Will have to look further into this when I return from Lake Tahoe later this week.
skikirkwood, thanks for your reply - take your time
I’m more than glad that someone is working on the Spotify issue and I’m sure there will be a solution soon.
