Please post the complete output of
ls -al
for the folder containing the files extracted from the zip file you have downloaded.
Meanwhile a shot in the dark: Check if there is a zip file in the folder into which the downloaded zip file has been extracted. It should not be there and I guess it would let fail “volumio plugin install”.
@gvolt - Not really a shot in the dark - your plugin is missing the npm packages - you will need the run
npm install
in your install.sh or pre package them into the zip file for install via the command line tool. Also -
volumio plugin package
does this for you already.
On my GitHub repo I had removed the zip file some time ago as I had the impression (actually I think I read it somewhere here on the forum, but can’t remember reliably…) that we were discouraged to publish pre packaged zip files - maybe I misunderstood or had a memory failure on my side
I’m new to volumio and pi, but have just set up a pi with digione and volumio to send to my rega dac-r. I’d like to add the volparametriceq you created, but really don’t understand how to do it. Do I unzip the zip file and add the contents to the sd card? Is there then an option to select volumio plugin install in the volumio app, or am I needing to run that somewhere else?
Thanks for that Lalashok. I have enabled ssh and tried to obtain the zip to install the plugin with the details, but an error comes up when trying to connect to github:
volumio@volumio:~$ wget https://github.com/balbueze/volumio-plugins/raw/master/p lugins/audio_interface/volparametriceq/volparametriceq.zip
converted ‘https:/githubcom/balbueze/volumio-plugins/raw/master/plugins/audio_ interface/volparametriceq/volparametriceq.zip’ (ANSI_X3.4-1968) -> ‘https:/gith ubcom/balbueze/volumio-plugins/raw/master/plugins/audio_interface/volparametric eq/volparametriceq.zip’ (UTF-8)
–2021-01-02 16:42:40-- https:/github.com/balbueze/volumio-plugins/raw/master/ plugins/audio_interface/volparametriceq/volparametriceq.zip
Resolving github (github)… 140.82.121.3
Connecting to github (github)|140.82.121.3|:443… connected.
HTTP request sent, awaiting response… 404 Not Found
2021-01-02 16:42:40 ERROR 404: Not Found.
Had to delete the / and . off the github address as i’m a new user and only allowed 2 links, but left the full address on the first bit to show what i had entered
For future reference, in most terminals (Putty included) - you can hit right-click on your mouse to paste stuff in. If you are on Win10, you don’t need Putty any longer, and it (finally!) includes a native ssh client. Try searching for it
