I have a problem with volumio, it’s impossible to install plugin. When i try I have an error and it’s the same for all plugin.
Before, it was possible because i have several plugins.
This is the second time i have to reinstall volumio to install plugin
You need a internet connection to install a plugin allowed to access Debian repo and github.
Maybe something is corrupted on your SD card. Have you tried to reflash?
No problem using a 8gb SD card
I had a similar result when trying to install a plugin from a new install.
Checking the details revealed that dpkg was configuring the keyboard and waiting for a response to select the default layout… which was not possible from the web UI.
My solution was to ssh into volumio and force a continuation of the install…
ssh etc
sudo su
apt-get install -f
This will probably give a message about a failed configuration of the keyboard and you will need to configure the keyboard correctly
dpkg-reconfigure keyboard-configuration
Once configured, try re-installing the plugin from the web UI.
for the first line : wget -q --tries=10 --timeout=20 --spider google.com
I have nothing
for the second : Fetched 17.9 MB in 37s (481 kB/s)
Greythane :
I have the keyboard on volumio (chromium)
ssh etc.
ssh: Could not resolve hostname etc.: Name or service not known
$ sudo su
[sudo] password for volumio:
root@sdb1:/home/volumio# apt-get install -f
Reading package lists… Done
Building dependency tree
Reading state information… Done
0 upgraded, 0 newly installed, 0 to remove and 47 not upgraded.
It’s not a problem, just a different way of accessing Volumio at the command line. You can either do it directly with a screen and keyboard (as you appear to have), or remotely from a different computer using ssh.
I had the Problem installing the Touch display plugin while a keyboard was connected, it always stopped at 70%. It worked when I removed the keyboard, but now the plugin is not listed as “installed”, which is why I can’t install the updates.
