Raspberry Pi 4 2GB, Audiophonics I-Sabre ES9028Q2M
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 3/3
card 2: DAC [I-Sabre Q2M DAC], device 0: I-Sabre Q2M DAC i-sabre-codec-i2c.1-0048-0 [I-Sabre Q2M DAC i-sabre-codec-i2c.1-0048-0]
Subdevices: 1/1
dede
February 9, 2021, 6:38am
22
Raspberry Pi 3B+
JustBoom DAC Boards
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: sndrpijustboomd [snd_rpi_justboom_dac], device 0: JustBoom DAC HiFi pcm512x-hifi-0 [JustBoom DAC HiFi pcm512x-hifi-0]
Subdevices: 1/1
dede
February 9, 2021, 6:41am
23
Raspberry Pi 3B+
Allo Boss
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: BossDAC [BossDAC], device 0: Boss DAC HiFi [Master] pcm512x-hifi-0 [Boss DAC HiFi [Master] pcm512x-hifi-0]
Subdevices: 1/1
Raspberry Pi 3 Model B Rev 1.2
[ApplePi-DAC]
Subdevices: 4/4
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI 1]
Subdevices: 1/1
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 H eadphones]
Subdevices: 3/3
card 2: ApplePiDAC [ApplePi-DAC], device 0: bcm2835-i2s-pcm1794a-hifi pcm1794a-c odec-0 [bcm2835-i2s-pcm1794a-hifi pcm1794a-codec-0]
Subdevices: 1/1
Darmur
February 12, 2021, 9:11pm
25
Added all cards till the previous post.
ashthespy:
@Darmur @timothyjward If you are just interested in the Card’s id and name as set by the driver, you could just parse the drivers directly from the raspberrypi/linux kernel tree…
Of course you can improve the regex, but here is a simple list to get started with.
I had a quick look, a few remarks:
Not all the DACs in the json list have a corresponding entry on the source files from the kernel tree
I don’t understand how to link the declaration from the source file to the cardname we need. As an example, I had a look to the FiPi DAC, the name I get from aplay -l is “Audio”, in fe-pi-audio.c the declared name is “Fe-Pi Audio”. If the cardname has no spaces, the matching is correct.
Yep, the these are just the ones that need drivers. For the ones that can get by using the audio-graph-card or simple-audio-card will have their name under the label key in their corresponding overlay file… Example allo-boss2-dac-audio-overlay
Darmur:
Interesting, looks a bit odd that it is returning only the part after the space? From a quick peek, aplay should be calling snd_ctl_card_info_get_id and snd_ctl_card_info_get_name from alsalib, and I doubt it’s doing something funky there.
Does this happen only on Volumio? Or even on Raspbian?
Raspberry Pi 4B with HIFIBerry Digi+ Pro
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HiFiBerry Digi+ Pro HiFi wm8804-spdif-0 [HiFiBerry Digi+ Pro HiFi wm8804-spdif-0]
Subdevices: 1/1
Darmur
February 13, 2021, 9:13am
28
same in latest Raspios
pi@raspios-cm4:~ $ aplay -l
card 0: Audio [Fe-Pi Audio], device 0: Fe-Pi HiFi sgtl5000-0 [Fe-Pi HiFi sgtl5000-0]
Subdevices: 1/1
pi@raspios-cm4:~ $
pi@raspios-cm4:~ $ uname -a
Linux raspios-cm4 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
What part of the aplay output are you actually interested in?
According to ALSA terminology, this would be
card = 0;
card_id = "Audio";
card_name = "Fe-Pi Audio";
device = 0;
device_id = "Fe-Pi HiFi sgtl5000-0";
device_name = "Fe-Pi HiFi sgtl5000-0";
The terminology here is a bit confusing (for me), so I was under the impression you wanted the card name, but it looks like you are interested in the card_id?
Looking at the dacs.json entry, this is mapped as:
"id":"fe-pi-audio",
"name":"Fe-Pi Audio", // ALSA card_name
"overlay":"fe-pi-audio",
"alsanum":"2", // ALSA_card
"alsacard":"Audio", // ALSA card_id
"mixer":"PCM",
"modules":"",
"script":"",
"needsreboot":"yes"
Darmur
February 13, 2021, 5:29pm
30
ashthespy:
according to the indication Tim gave me, it is the part right after the card number, before the square brackets (highlighted in bold)
I did extensive testing with the TerraBerry DACs (version 2 and version 3).
Independant on the Volumio version it shows up the aplay -l command output is different on TerraBerry2 and TerraBerry3 (see below).
@Michelangelo : It seems there is a bug in the newer Volumio versions that leads to these DACs are not working with volume control “none”. The only workaround is to choose “software” mixer and set the volume to 100%.
RaspBerry 3
TerraBerry2 DAC
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 0/1
RaspBerry 3
TerraBerry3 DAC
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 0/1
I also used a quite old version of Volumio to get a Allo Piano 2.1 set to Dual Mono Mode.
RaspBerry 3
Allo Piano 2.1 (in Dual Mono mode)
Subdevices: 8/8
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: PianoDACPlus [PianoDACPlus], device 0: PianoDACPlus multicodec-0
Subdevices: 1/1
Darmur
February 14, 2021, 10:20am
32
could you please report the content of the following command, when you select TerraBerry DAC 2 and then TerraBerry DAC 3?
cat /boot/config.txt
@Darmur - give me a few minutes
In the mean time i had a look at the UNSUPPORTED Aoide DAC II.
For those who got it managed to successfully install the drivers from:
RaspBerry 3B+
AOIDE DACII (ES9018K2M)
Subdevices: 7/7
Subdevices: 1/1
Subdevices: 1/1
card 1: II [Aoide DAC II], device 0: Aoide DAC II (SLAVE) es9018k2m-i2c.1-0048-0 [Aoide DAC II (SLAVE) es9018k2m-i2c.1-0048-0]
Subdevices: 1/1
@Darmus :
TerraBerry2 DAC - config.txt:
(same at TerraBerry3 after setup SD card from scratch…)
-------------------------initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
include userconfig.txt
Volumio i2s setting below: do not alter
dtoverlay=i-sabre-q2m
RemotePi lirc setting below: do not alter
TerraBerry3 DAC -
I had to reflash the SD card because i used it for another installation.
And now (fresh install - i get the same output as on TerraBerry2)
I didn’t edit any file manually on none of these installations
config.txt:
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
I don’t know what is going on there.
Interestingly. The hardware mixer has been activated and there is sound at the output. I am able to operate the volume controls in the UI - but as expectable the volume is not changed and is always at 100%
Same after a restart. When selecting the volume mixer there is only “none” and software". Once selected “none” the “hardware” setting that has been choosen as default is gone (how it should be…)
I hope in Version 3 of Volumio the TerraBerry2/3 and Allo Piano 2.1 will get back working as expected…
BR
Josef
RaspBerry 3
Audiophonics ES9038Q2M
Subdevices: 7/7
Subdevices: 1/1
Subdevices: 1/1
card 1: DAC [I-Sabre Q2M DAC], device 0: I-Sabre Q2M DAC i-sabre-codec-i2c.1-0048-0 [I-Sabre Q2M DAC i-sabre-codec-i2c.1-0048-0]
Subdevices: 0/1
RaspBerry 3
OSA DACberry Pro
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: IQaudIODAC [IQaudIODAC], device 0: IQaudIO DAC HiFi pcm512x-hifi-0 [IQaudIO DAC HiFi pcm512x-hifi-0]
Subdevices: 1/1
RaspBerry 3
HifiBerryADC Pro
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplusadcpro], device 0: HiFiBerry DAC+ADC Pro HiFi multicodec-0 [HiFiBerry DAC+ADC Pro HiFi multicodec-0]
Subdevices: 1/1
AxLED
February 16, 2021, 5:05pm
37
@Darmur ,
here are my datas:
Raspberry Pi Zero W
Real DAC: pirate audio 3W amp hat
selected DAC Model in the Playback section: HiFiBerry DAC
Output:
volumio@volumio:~$ aplay -l
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
AxLED
RaspBerry 3
HiFiBerry ADC (not the pro version)
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplusadc], device 0: HiFiBerry DAC+ADC HiFi multicodec-0 [HiFiBerry DAC+ADC HiFi multicodec-0]
Subdevices: 1/1
Here is one fot de Loco v2 dav by dion Audio
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
card 1: LOCOV2 [Dion Audio LOCO-V2], device 0: DionAudio LOCO-V2 DAC-AMP pcm512x-hifi-0 [DionAudio LOCO-V2 DAC-AMP pcm512x-hifi-0]
Subdevices: 0/1
Darmur
December 29, 2023, 10:00am
40
what is the dt-overlay to be selected for this DAC?
