Help choosing an I2S DAC
Hi !
I’m starting a project with Volumio on an old Raspberry Pi 3B. I would like to add a I2S DAC.
I’m kinda lost with all the models. Some are a separate board, I guess you need to connect wires between the Pi and those boards ? Some are a hat, so I guess you just put them on top of the Pi.
I don’t need an amp, only RCA outputs. Can you recommend a decent model at a fair price ? I think I’d rather have the board separate and not a hat, because it would be easier to manage space inside the future case.
Also, I need at least 3 GPIO pins free for physical buttons and in the future I would like to connect a small touch screen.
Any recommendations ?
Thanks !
InnoMaker HiFi DAC Pro Hat I2S ES9038Q2M - circa 50 - 60 euro.
Audio output via 3.5 mm jack to 2 x RCA cable.
Khadas Tone 1 - only USB-C to Raspberry Pi and audio 2 x RCA - circa 70 euro.
It also has a coaxial digital input.
The coaxial digital input works when you pause music playback in Volumio.
It benefits from Volumio community support.
x2 for this @juluss . Great DAC, designed around the ES9038Q2M chip. More info on the above link. Along with stereo, it also has balanced outputs.
Hi guys, thanks for the suggestions but I think those are a bit expensive for my project. I did some research on Amazon and I found small boards like these :
PCM 5102 - Amazon.ca
OTOTEC MCU-1334 - Amazon.ca
I think those are more suited for my projects. Any recommendation in the same kind, small boards ? I’m not looking for extra quality sound. As long as it’s better than the basic audio output from the Pi, I’ll be ok. This project is not really for listening to music on a Hi-Fi system…
Then go for a HifiBerry board. They start at around €29.
The really cheap DAC boards are often a gamble. I’ve tested one and ran into poor sound quality and boot-time detection issues.
The €15 you save upfront can easily turn into hours of unnecessary troubleshooting. Sometimes it’s worth paying a little more and getting something that just works.
I have been using the Raspberry Pi DAC Pro hat for some time now. Excellent sound and easy to install. RCA phono connectors. Costs about £24. The Raspberry Pi DAC+ is also good and is available for under £20. To be honest, I can’t tell the difference in audio performance.
If quality is the objective, the reference LightSbare ES90182KM DAC by @Darmur:
You simply can not go wrong with this one. PCBWay turnover is 2-3 weeks. Worth waiting.
Thanks @Wheaten and @Newbiggen
I think I’m going with any of your suggestions.
But question : those are hat, will I be able to use the GPIO pins for my physical buttons ? And can I add a touch screen maybe ?
Thanks also @nerd
Are those schematics to build one myself ? Or to order PCBWay to make it for me, maybe ? Seems interesting, but I don’t think I have enough free time for that unfortunately…
As long as there is an exposed GPIO pins, like dac2-pro, yes.
For display choose one with DSI or HDMI connector. (not one connected to the GPIO)
You might find this guide useful for the Raspeberry Pi [formerly IQAUDIO] Hats. - Lots of information including details of which GPIO pins are available
@ juluss
In this case, two displays are connected to a Raspberry Pi 4.
A 2.42-inch OLED display connected to the I2C GPIO pins (3.3V, GND, SDA, and SCL).
Available in white, green, yellow, or blue.
A 4.3-inch DSI LCD display connected via a ribbon cable to the Raspberry Pi’s DSI port; power is integrated into the DSI cable.
This same configuration also works with the Raspberry Pi 5.
Everything works fine.
Instead of a DSI connected display, you can use an HDMI display, though this requires providing additional power ( 5V - 1 / 2A ) for the screen. There are also versions with touch support.
Some DSI or HDMI LCD displays can be mounted directly to the back of the Raspberry Pi using standoffs.
Hey @juluss,
In repo there are two complete manufacturing sets, standard and pro version of the dac. You can try do the dac yourself however you will quickly find that baking SMD requires proper stencil to layer the soldering liquid, not to mention an equally distributed heatplate or owen. It is much simpler to use any commercially available PCB and assembly manufacturer.
Please check updated readme for details.
