Hello, I installed Volumio on a mini pc and I can’t change the image from vertical to horizontal because I have a built-in monitor permanently
You are lucky
We are working on a new plugin that should help you!
We try to publish a beta today…
I keep you in touch ![]()
Thank you for the quick reply, and what will the name of the LCD plugin be?
I opted for:
eventhoughitgavebalbuzeaheadachbutstillapluginthatmakesthebootlogoandconsoletextinlinewiththedisplayrotation.
But it was not very well received ![]()
It will be “display configuration”
It will bring different settings for
- display orientation (from boot to UI)
- touchscreen orientation
- mouse cursor orientation
- brightness (hardware if available or software)
- cursor display on/off
- screensaver with xscreensaver!
- other features to come
This is beta, coming soon!
see here : Display Configuration for x86 - The plugin!
