Title: Volumio 4 – Raspberry Pi 3B HDMI audio fails because vc4hdmi is not handled by ALSA/MPD device generation
I believe I have reproduced an existing Raspberry Pi 3 HDMI audio bug in Volumio 4 and have confirmed a working fix.
Hardware
- Raspberry Pi 3B
- Volumio 4.x
- Fresh Volumio installation on microSD
- HDMI audio output
- Raspberry Pi HDMI → HDMI interface → Pro-Ject Pre Box S2 Digital
This exact hardware configuration worked correctly for approximately three years with my previous Volumio installation. HDMI audio stopped working after installing the newer Volumio 4 image.
Problem
ALSA exposes the working HDMI audio device on this Raspberry Pi as:
sysdefault:CARD=vc4hdmi
However, Volumio’s ALSA/MPD device-generation logic does not correctly handle the card name vc4hdmi.
As a result, Volumio generates a non-working audio configuration and MPD cannot correctly use the HDMI output.
This is not an HDMI cable, DAC, or Raspberry Pi hardware failure.
Confirmed working fix
We first confirmed that MPD works when its output device is explicitly configured as:
We then modified Volumio’s ALSA generator to recognize the vc4hdmi card and modified the MPD/plugin generation logic so the correct device is regenerated automatically.
After the changes:
- HDMI audio works normally.
- MPD playback works normally.
volumio vrestart does not break the configuration.
- A complete shutdown/reboot of the Raspberry Pi does not break the configuration.
- Volumio regenerates the working audio configuration automatically.
Therefore the underlying Raspberry Pi HDMI/ALSA system is working. The failure appears to be in Volumio’s handling of the vc4hdmi card name.
This appears related to an existing Volumio 4 report
I found another Raspberry Pi 3B+ report from June 2026 describing essentially the same issue. In that case the HDMI card was also named simply vc4hdmi, while Volumio’s ALSA generator handled vc4hdmi0 and vc4hdmi1.
The reported affected file was:
/volumio/app/plugins/audio_interface/alsa_controller/index.js
Adding support for vc4hdmi corrected HDMI audio in that case as well.
Expected behavior
Volumio should recognize all three applicable vc4 HDMI card names:
vc4hdmi
vc4hdmi0
vc4hdmi1
and generate the appropriate ALSA/MPD configuration automatically.
My Volumio diagnostic log
http://logs.volumio.org/volumio/sJ2dgly.html
Request
Could the Volumio developers please review the vc4hdmi handling in the ALSA and MPD configuration generators and incorporate the fix into an upcoming Volumio release?
I can also provide the exact modified index.js files/diffs from my working system if that would help.
The patched system has been tested through both volumio vrestart and a complete Raspberry Pi reboot and continues to play correctly.
