hassle with rpi 3b+ allo kali + piano 2.1 gambling any pattern price except 44.1khz
so i’ve a rpi 3b+ with an allo kali reclocker and a piano2.1 dac. works wonders with moode audio, but i like the spotify plugin that volumio provides way higher. i additionally have an outside hdd with a flac track library. pattern prices move from 16/44.1khz to 24/192khz any record that isn’t always 16/forty four.1khz simply outputs noise.
i’ve disabled resampling inside the config. however the led signs on the allo kali are constantly on the 44.1khz 16bit.
am i missing some thing. i sense like volumio isn’t detecting the kali and most effective running like theres rpi 3b+ and the piano 2.1 any customers obtainable with this stack that might point me inside the right path?
thank you!
my issue has been solved thank you
I know this thread is outdated and no longer needs a solution for Ethan, but I would like to help other users that will have a similar solution as Ethan did not share his fixed problem. I am going to ask my friend how to solve this issue and invite him to this thread as he is a junior software developer and works on projects like this one https://newslotgames.net/casinos/us.html and I am sure he will be able to solve the issue for all future users that will have the same problem and will need a proper solution, so stay tuned.
I would like to know the solution as well, any updates?
