Hardware mixer with Brutefir plugin
Greetings,
I’m using the brutefir3 plugin with PiDAC+.
I need to set a specific channel to control the volume, but if I activate the plugin, I only get “None” and “Software” as mixer options. And then I can’t control the volume anymore since it’s not mapped to that channel.
Any ideas?
Brutefir plugin uses the mixer set in volumio before the plugin is enabled. It’s just a display problem…
I suggest you to disable the plugin, set correctly in volumio test and then enable the plugin. Don’t try to change anything in volumio playback settings. It should work like that. Let me know
We are working to fix this…
It seems to be working properly now :slight_smile:
Thank you!
Sent from my Mi A1 using Tapatalk
