[GUIDE] Kodi on Volumio 2.x -> Install on a nonvolumio image
Installing the Pi elsewhere shouldn’t matter :wink:
The problem with your ldconfig line is that you should run that as sudo too.
If that doesn’t work, I’ll have to dig in more; I’m all out of idea now :stuck_out_tongue:
Please let me know how the ldconfig goes, you should still reboot afterwards I think.
Update, I’ve just generated the same error, if you start a journal trace (sudo journalctl -f) you will probably see the following if you start the service:
Sep 18 19:00:44 volumio volumio[956]: info: KODI started Sep 18 19:00:44 volumio volumio[956]: info: Done. Sep 18 19:00:45 volumio kodi-standalone[6583]: /usr/bin/kodi: 46: /usr/bin/kodi: tvservice: not found Sep 18 19:00:47 volumio kodi-standalone[6583]: Segmentation fault (core dumped) Sep 18 19:00:53 volumio kodi-standalone[6583]: Crash report available at /home/kodi/kodi_crashlog-20170918_190047.log
The crash log shows the following:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
 Date: Mon Sep 18 19:00:47 UTC 2017
 Kodi Options:
 Arch: armv7l
 Kernel: Linux 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017
 Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====>  Core file: /core (2017-09-18 19:00:47.546377661 +0000)
[New LWP 6629]
[New LWP 6610]
[New LWP 6627]
[New LWP 6618]
[New LWP 6628]
[New LWP 6619]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin --lircdev /var/run/lirc/lircd --s'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x3c666674 in ?? ()
Thread 6 (Thread 0x736ff3b0 (LWP 6619)):
#0  0x75772b80 in poll () at ../sysdeps/unix/syscall-template.S:81
#1  0x004ec6e8 in CFDEventMonitor::Process() ()
#2  0x00680a80 in CThread::Action() ()
#3  0x006812e8 in CThread::staticThread(void*) ()
#4  0x76f93e90 in start_thread (arg=0x736ff3b0) at pthread_create.c:311
#5  0x7577c598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 5 (Thread 0x723ff3b0 (LWP 6628)):
#0  0x76f98b30 in __pthread_cond_timedwait (cond=0x71a00650, mutex=0x71a00688, abstime=0x723fdb20) at pthread_cond_timedwait.c:199
#1  0x00440590 in XbmcThreads::ConditionVariable::wait(CCriticalSection&, unsigned long) ()
#2  0x00620634 in Actor::Protocol::SendOutMessageSync(int, Actor::Message**, int, void*, int) ()
#3  0x00a67604 in ActiveAE::CActiveAE::InitSink() ()
#4  0x00a69c78 in ActiveAE::CActiveAE::Configure(AEAudioFormat*) ()
#5  0x037fffcc in ?? ()
Thread 4 (Thread 0x740573b0 (LWP 6618)):
#0  0x76f987a4 in __pthread_cond_wait (cond=0x37f8a78, mutex=0x37f8ab0) at pthread_cond_wait.c:187
#1  0x009d910c in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#4  0x76f93e90 in start_thread (arg=0x740573b0) at pthread_create.c:311
Thread 3 (Thread 0x72cff3b0 (LWP 6627)):
#0  0x76f98b30 in __pthread_cond_timedwait (cond=0x15f9d00, mutex=0x15f9d38, abstime=0x72cfece0) at pthread_cond_timedwait.c:199
#2  0x00639b5c in CJobManager::GetNextJob(CJobWorker const*) ()
#3  0x0063a454 in CJobWorker::Process() ()
#4  0x00680a80 in CThread::Action() ()
#5  0x006812e8 in CThread::staticThread(void*) ()
#6  0x76f93e90 in start_thread (arg=0x72cff3b0) at pthread_create.c:311
#7  0x7577c598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 2 (Thread 0x740592a0 (LWP 6610)):
#0  0x76f98b30 in __pthread_cond_timedwait (cond=0x3899e28, mutex=0x3899e60, abstime=0x7ef398d0) at pthread_cond_timedwait.c:199
#3  0x00a68a74 in ActiveAE::CActiveAE::Initialize() ()
#4  0x00a539b4 in CAEFactory::StartEngine() ()
#5  0x007d0300 in CApplication::Create() ()
#6  0x006988e4 in XBMC_Run ()
#7  0x003b1bfc in main ()
Thread 1 (Thread 0x719ff3b0 (LWP 6629)):
#1  0x004daf94 in void std::_Destroy_aux<false>::__destroy<CMediaSource*>(CMediaSource*, CMediaSource*) ()
#2  0x0086a6b4 in std::vector<CMediaSource, std::allocator<CMediaSource> >::clear() ()
#3  0x008694e0 in CMediaSourceSettings::Clear() ()
#4  0x00845d9c in CSettingsManager::OnSettingsUnloaded() ()
#5  0x00846724 in CSettingsManager::Unload() ()
#6  0x008481a8 in CSettingsManager::Clear() ()
#7  0x0086fe3c in CSettings::Uninitialize() ()
#8  0x0087019c in CSettings::~CSettings() ()
#9  0x756dbaec in __run_exit_handlers (status=-1, listp=0x757e84ac <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true) at exit.c:82
#10 0x756dbb3c in __GI_exit (status=<optimized out>) at exit.c:104
#11 0x75cceb8c in bcm_host_init () from /opt/vc/lib/libbcm_host.so
############# END STACK TRACE ###############
################# LOG FILE ##################
19:00:46.486 T:1946522272  NOTICE: special://profile/ is mapped to: special://masterprofile/
19:00:46.487 T:1946522272  NOTICE: -----------------------------------------------------------------------
19:00:46.487 T:1946522272  NOTICE: Starting Kodi (17.4 Git:20170913-5cc491e-dirty). Platform: Linux ARM 32-bit
19:00:46.487 T:1946522272  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
19:00:46.487 T:1946522272  NOTICE: Kodi compiled Sep 13 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
19:00:46.487 T:1946522272  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.41-v7+
19:00:46.494 T:1946522272  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
19:00:46.494 T:1946522272  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
19:00:46.494 T:1946522272  NOTICE: ARM Features: Neon enabled
19:00:46.494 T:1946522272  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:00:46.494 T:1946522272  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
19:00:46.494 T:1946522272  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
19:00:46.494 T:1946522272  NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata
19:00:46.494 T:1946522272  NOTICE: special://envhome/ is mapped to: /home/kodi
19:00:46.495 T:1946522272  NOTICE: special://home/ is mapped to: /home/kodi/.kodi
19:00:46.495 T:1946522272  NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp
19:00:46.495 T:1946522272  NOTICE: special://logpath/ is mapped to: /home/kodi/.kodi/temp
19:00:46.495 T:1946522272  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
19:00:46.495 T:1946522272  NOTICE: Local hostname: volumio
19:00:46.495 T:1946522272  NOTICE: Log File is located: /home/kodi/.kodi/temp//kodi.log
19:00:46.495 T:1946522272  NOTICE: -----------------------------------------------------------------------
19:00:46.581 T:1946522272   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
19:00:46.708 T:1946522272  NOTICE: load settings...
19:00:46.982 T:1946522272  NOTICE: Found 2 Lists of Devices
19:00:46.982 T:1946522272  NOTICE: Enumerated PI devices:
19:00:46.982 T:1946522272  NOTICE:     Device 1
19:00:46.983 T:1946522272  NOTICE:         m_deviceName      : HDMI
19:00:46.983 T:1946522272  NOTICE:         m_displayName     : HDMI
19:00:46.983 T:1946522272  NOTICE:         m_displayNameExtra:
19:00:46.983 T:1946522272  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
19:00:46.983 T:1946522272  NOTICE:         m_channels        : FL,FR
19:00:46.983 T:1946522272  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
19:00:46.984 T:1946522272  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
19:00:46.984 T:1946522272  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
19:00:46.984 T:1946522272  NOTICE:     Device 2
19:00:46.984 T:1946522272  NOTICE:         m_deviceName      : Analogue
19:00:46.984 T:1946522272  NOTICE:         m_displayName     : Analogue
19:00:46.984 T:1946522272  NOTICE:         m_displayNameExtra:
19:00:46.984 T:1946522272  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
19:00:46.984 T:1946522272  NOTICE:         m_channels        : FL,FR
19:00:46.984 T:1946522272  NOTICE:         m_sampleRates     : 48000
19:00:46.984 T:1946522272  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
19:00:46.984 T:1946522272  NOTICE:         m_streamTypes     : No passthrough capabilities
19:00:46.984 T:1946522272  NOTICE:     Device 3
19:00:46.984 T:1946522272  NOTICE:         m_deviceName      : Both
19:00:46.984 T:1946522272  NOTICE:         m_displayName     : HDMI and Analogue
19:00:46.985 T:1946522272  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
19:00:46.985 T:1946522272  NOTICE:         m_channels        : FL,FR
19:00:46.985 T:1946522272  NOTICE:         m_sampleRates     : 48000
19:00:46.985 T:1946522272  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
19:00:46.985 T:1946522272  NOTICE:         m_streamTypes     : No passthrough capabilities
19:00:46.985 T:1946522272  NOTICE: Enumerated ALSA devices:
19:00:46.985 T:1946522272  NOTICE:     Device 1
19:00:46.985 T:1946522272  NOTICE:         m_deviceName      : @
19:00:46.985 T:1946522272  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
19:00:46.985 T:1946522272  NOTICE:         m_displayNameExtra:
19:00:46.985 T:1946522272  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
19:00:46.985 T:1946522272  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
19:00:47.032 T:1946522272  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
19:00:47.032 T:1946522272  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <fanartres>720</fanartres>
                                              <imageres>540</imageres>
                                              <video>
                                                <busydialogdelayms>750</busydialogdelayms>
                                              </video>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <cache>
                                                <memorysize>31457280</memorysize>
                                              </cache>
                                            </advancedsettings>
19:00:47.035 T:1946522272  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:00:47.035 T:1946522272  NOTICE: Default Video Player: VideoPlayer
19:00:47.035 T:1946522272  NOTICE: Default Audio Player: paplayer
19:00:47.035 T:1946522272  NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:00:47.036 T:1946522272  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:00:47.036 T:1946522272  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:00:47.039 T:1946522272  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:00:47.040 T:1946522272  NOTICE: Loaded playercorefactory configuration
19:00:47.041 T:1946522272  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:00:47.041 T:1946522272  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:00:47.417 T:1946522272  NOTICE: ADDONS: Using repository repository.xbmc.org
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
In other words, mapping the EGL libraries and chowning the video devices should solve your problem.
Note: I too get the vcsm error, so don’t worry about that one!
Once rebooted I get the following journal entries when I start the plugin (note that I had stopped the plugin before rebooting).
Sep 18 19:06:29 volumio volumio[937]: info: KODI started
Sep 18 19:06:29 volumio volumio[937]: info: Done.
Sep 18 19:06:29 volumio kodi-standalone[1866]: /usr/bin/kodi: 46: /usr/bin/kodi: tvservice: not found
Sep 18 19:06:32 volumio udisks-glue[633]: Device file /dev/mmcblk0p3 mounted at /media/volumio_data
I tried with sudo, same outcome …
I already have had this error (/usr/bin/kodi: tvservice: not found) message with “sudo journalctl -f”.
I will replay your script tomorrow from a fresh config and will let you know what happens, hope this will work.
Anyway, thanks Saiyato, have a nice evening !
Ken
So, i started from 2.203 Volumio version - then i downloaded the plugin, restarted before activating it, tuned it on, and this is sudo journalctl -f output :
sudo journalctl -f
-- Logs begin at Tue 2017-09-19 16:50:59 UTC. --
Sep 19 16:53:51 volumio volumio[968]: info: Reloaded the config file
Sep 19 16:53:52 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:53 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:54 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:55 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:56 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:57 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:58 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:53:58 volumio sudo[2187]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Sep 19 16:53:58 volumio sudo[2187]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Sep 19 16:53:59 volumio volumio[1158]: Wrong scontrol identifier:
Sep 19 16:54:00 volumio volumio[1158]: Wrong scontrol identifier:
Anyway … Then i take a look at kodi.log
volumio@volumio:/home/kodi/.kodi/temp$ cat kodi.log
16:53:51.354 T:1945637536  NOTICE: special://profile/ is mapped to: special://masterprofile/
16:53:51.355 T:1945637536  NOTICE: -----------------------------------------------------------------------
16:53:51.355 T:1945637536  NOTICE: Starting Kodi (17.4 Git:20170913-5cc491e-dirty). Platform: Linux ARM 32-bit
16:53:51.355 T:1945637536  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
16:53:51.355 T:1945637536  NOTICE: Kodi compiled Sep 13 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
16:53:51.355 T:1945637536  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.31-v7+
16:53:51.355 T:1945637536  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
16:53:51.355 T:1945637536  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
16:53:51.355 T:1945637536  NOTICE: ARM Features: Neon enabled
16:53:51.355 T:1945637536  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
16:53:51.355 T:1945637536  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
16:53:51.355 T:1945637536  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
16:53:51.355 T:1945637536  NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata
16:53:51.355 T:1945637536  NOTICE: special://envhome/ is mapped to: /home/kodi
16:53:51.355 T:1945637536  NOTICE: special://home/ is mapped to: /home/kodi/.kodi
16:53:51.355 T:1945637536  NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp
16:53:51.355 T:1945637536  NOTICE: special://logpath/ is mapped to: /home/kodi/.kodi/temp
16:53:51.355 T:1945637536  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
16:53:51.355 T:1945637536  NOTICE: Local hostname: volumio
16:53:51.355 T:1945637536  NOTICE: Log File is located: /home/kodi/.kodi/temp//kodi.log
16:53:51.366 T:1945637536   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
16:53:51.392 T:1945637536  NOTICE: load settings...
16:53:51.493 T:1945637536  NOTICE: Found 2 Lists of Devices
16:53:51.493 T:1945637536  NOTICE: Enumerated PI devices:
16:53:51.493 T:1945637536  NOTICE:     Device 1
16:53:51.493 T:1945637536  NOTICE:         m_deviceName      : HDMI
16:53:51.493 T:1945637536  NOTICE:         m_displayName     : HDMI
16:53:51.493 T:1945637536  NOTICE:         m_displayNameExtra:
16:53:51.493 T:1945637536  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
16:53:51.493 T:1945637536  NOTICE:         m_channels        : FL,FR
16:53:51.493 T:1945637536  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
16:53:51.493 T:1945637536  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
16:53:51.493 T:1945637536  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
16:53:51.493 T:1945637536  NOTICE:     Device 2
16:53:51.493 T:1945637536  NOTICE:         m_deviceName      : Analogue
16:53:51.493 T:1945637536  NOTICE:         m_displayName     : Analogue
16:53:51.493 T:1945637536  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
16:53:51.493 T:1945637536  NOTICE:         m_sampleRates     : 48000
16:53:51.493 T:1945637536  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
16:53:51.494 T:1945637536  NOTICE:         m_streamTypes     : No passthrough capabilities
16:53:51.494 T:1945637536  NOTICE:     Device 3
16:53:51.494 T:1945637536  NOTICE:         m_deviceName      : Both
16:53:51.494 T:1945637536  NOTICE:         m_displayName     : HDMI and Analogue
16:53:51.494 T:1945637536  NOTICE:         m_displayNameExtra:
16:53:51.494 T:1945637536  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
16:53:51.494 T:1945637536  NOTICE:         m_channels        : FL,FR
16:53:51.494 T:1945637536  NOTICE:         m_sampleRates     : 48000
16:53:51.494 T:1945637536  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
16:53:51.494 T:1945637536  NOTICE: Enumerated ALSA devices:
16:53:51.494 T:1945637536  NOTICE:     Device 1
16:53:51.494 T:1945637536  NOTICE:         m_deviceName      : @
16:53:51.494 T:1945637536  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
16:53:51.494 T:1945637536  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
16:53:51.494 T:1945637536  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
16:53:51.507 T:1945637536  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
16:53:51.507 T:1945637536  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <samba>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
16:53:51.508 T:1945637536  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:53:51.508 T:1945637536  NOTICE: Default Video Player: VideoPlayer
16:53:51.508 T:1945637536  NOTICE: Default Audio Player: paplayer
16:53:51.508 T:1945637536  NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:53:51.508 T:1945637536  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:53:51.509 T:1945637536  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
16:53:51.510 T:1945637536  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:53:51.511 T:1945637536  NOTICE: Loaded playercorefactory configuration
16:53:51.511 T:1945637536  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:53:51.511 T:1945637536  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:53:51.536 T:1945637536  NOTICE: Running database version Addons27
16:53:51.625 T:1945637536  NOTICE: ADDONS: Using repository repository.xbmc.org
16:53:51.723 T:1945637536  NOTICE: Raspberry PI firmware version: Jun  8 2017 13:29:59
                                            Copyright (c) 2012 Broadcom
                                            version 0784a9f7dfa6a45aa2524eeab1980da00cd93019 (tainted) (release)
16:53:51.723 T:1945637536  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
16:53:51.723 T:1945637536  NOTICE: cache.memorysize: 30MB libass.cache: 0MB
16:53:51.723 T:1945637536  NOTICE: Config:
                                            arm_freq=1200
                                            audio_pwm_mode=1
                                            config_hdmi_boost=5
                                            core_freq=400
                                            desired_osc_freq=0x36ee80
                                            disable_commandline_tags=2
                                            disable_l2cache=1
                                            disable_splash=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_ignore_alpha=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_force_cec_address=65535
                                            hdmi_force_hotplug=1
                                            init_uart_baud=19200
                                            init_uart_clock=0x2dc6c00
                                            lcd_framerate=60
                                            over_voltage_avs=43750
                                            over_voltage_avs_boost=50000
                                            pause_burst_frames=1
                                            program_serial_random=1
                                            ramfsaddr=-1
                                            sdram_freq=450
                                            temp_limit=85
                                            device_tree=-
                                            ramfsfile=volumio.initrd
16:53:51.723 T:1945637536  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
16:53:51.725 T:1945637536  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
16:53:51.725 T:1945637536  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
16:53:51.725 T:1945637536  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
16:53:51.725 T:1945637536  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
16:53:51.725 T:1945637536  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
16:53:51.725 T:1945637536  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
16:53:51.725 T:1945637536  NOTICE: Found (640x480@60.000000) at 16, setting to RES_DESKTOP at 16
16:53:51.725 T:1945637536  NOTICE: Checking resolution 16
16:53:51.892 T:1945637536  NOTICE: GL_VENDOR = Broadcom
16:53:51.892 T:1945637536  NOTICE: GL_RENDERER = VideoCore IV HW
16:53:51.892 T:1945637536  NOTICE: GL_VERSION = OpenGL ES 2.0
16:53:51.892 T:1945637536  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
16:53:51.892 T:1945637536  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
16:53:52.708 T:1817740208  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
16:53:52.717 T:1925182384  NOTICE: Running database version Addons27
16:53:52.719 T:1925182384  NOTICE: Running database version ViewModes6
16:53:52.721 T:1925182384  NOTICE: Running database version Textures13
16:53:52.726 T:1925182384  NOTICE: Running database version MyMusic60
16:53:52.735 T:1925182384  NOTICE: Running database version MyVideos107
16:53:52.737 T:1925182384  NOTICE: Running database version TV29
16:53:52.739 T:1925182384  NOTICE: Running database version Epg11
16:53:52.742 T:1945637536  NOTICE: start dvd mediatype detection
16:53:53.191 T:1945637536 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:53:53.515 T:1945637536  NOTICE: initialize done
16:53:53.515 T:1945637536  NOTICE: Running the application...
16:53:53.523 T:1945637536  NOTICE: starting zeroconf publishing
16:53:53.523 T:1945637536  NOTICE: starting upnp client
16:53:53.579 T:1682957232  NOTICE: ES: Starting UDP Event server on port 9777
16:53:53.580 T:1682957232  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
16:53:53.606 T:1945637536  NOTICE: VideoPlayer: Opening: :0
16:53:53.606 T:1945637536 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
16:53:53.607 T:1610609584  NOTICE: Creating InputStream
16:53:53.607 T:1610609584   ERROR: CVideoPlayer::OpenInputStream - error opening [:0]
16:53:53.607 T:1610609584  NOTICE: CVideoPlayer::OnExit()
16:53:53.608 T:1945637536   ERROR: Playlist Player: skipping unplayable item: 0, path [:0]
16:53:53.625 T:1945637536  NOTICE: CVideoPlayer::CloseFile()
16:53:53.625 T:1945637536  NOTICE: VideoPlayer: waiting for threads to exit
16:53:53.625 T:1945637536  NOTICE: VideoPlayer: finished waiting
16:53:53.625 T:1945637536  NOTICE: VideoPlayer: Opening: tcp
16:53:53.626 T:1610609584  NOTICE: Creating InputStream
16:53:53.626 T:1610609584   ERROR: CVideoPlayer::OpenInputStream - error opening [tcp]
16:53:53.626 T:1610609584  NOTICE: CVideoPlayer::OnExit()
16:53:53.626 T:1945637536   ERROR: Playlist Player: skipping unplayable item: 1, path [tcp]
16:53:53.641 T:1945637536  NOTICE: CVideoPlayer::CloseFile()
16:53:53.641 T:1945637536  NOTICE: VideoPlayer: waiting for threads to exit
16:53:53.642 T:1945637536  NOTICE: VideoPlayer: finished waiting
16:53:53.642 T:1945637536  NOTICE: VideoPlayer: Opening: vt7
16:53:53.642 T:1610609584  NOTICE: Creating InputStream
16:53:53.642 T:1610609584   ERROR: CVideoPlayer::OpenInputStream - error opening [vt7]
16:53:53.643 T:1610609584  NOTICE: CVideoPlayer::OnExit()
16:53:53.643 T:1945637536   ERROR: Playlist Player: skipping unplayable item: 2, path [vt7]
16:53:53.914 T:1945637536  NOTICE: CVideoPlayer::CloseFile()
16:53:53.914 T:1945637536  NOTICE: VideoPlayer: waiting for threads to exit
16:53:53.914 T:1945637536  NOTICE: VideoPlayer: finished waiting
16:53:53.915 T:1945637536  NOTICE: VideoPlayer: finished waiting
It’s not so clear to me so i’m not sure I will explain its content :stuck_out_tongue:
then, i tried to chowned/EGL :
^Cvolumio@volumio:~$ sudo chown root:video /dev/vchiq /dev/vcio /dev/vcsm
[sudo] password for volumio:
volumio@volumio:~$ sudo rm /etc/ld.so.conf.d/00-vmcs.conf
volumio@volumio:~$ echo "/opt/vc/lib/" | sudo tee /etc/ld.so.conf.d/00-vmcs.conf
/opt/vc/lib/
volumio@volumio:~$ sudo ldconfig
volumio@volumio:~$
Now, i’m going downstairs to test it :slight_smile:
it does not work … on top of that, i found out that i have a hdmi-cec anynet on my samsung tv set …
if you run pstree (no need for sudo), do you see the Kodi process active?
Yes …
|-kodi-standalone---kodi---kodi_v7.bin-+-{HCEC Notify}
        |                                      |-{HDispmanx Notif}
        |                                      |-{HTV Notify}
        |                                      |-{ILCS_HOST}
        |                                      |-{VCHIQ completio}
        |                                      |-25*[{kodi_v7.bin}]
        |                                      `-2*[{libmicrohttpd}]
nevertheless, when i take a look at kodi’s log :
OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_        framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_for        mat_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
19:06:03.804 T:1945719456 WARNING: CLangInfo: unable to load language "resource.        language.fr_fr". Trying to determine matching language addon...
19:06:03.806 T:1945719456 WARNING: CLangInfo: unable to find an installed langua        ge addon matching "resource.language.fr_fr". Trying to find an installable langu        age...
19:06:09.725 T:1743250352  NOTICE: Register - new cec device registered on cec->        RPI: CEC Adapter (2708:1001)
19:06:10.135 T:1793582000  NOTICE: Running database version Addons27
19:06:10.141 T:1793582000  NOTICE: Running database version ViewModes6
19:06:10.153 T:1793582000  NOTICE: Running database version Textures13
19:06:10.169 T:1793582000  NOTICE: Running database version MyMusic60
19:06:10.196 T:1793582000  NOTICE: Running database version MyVideos107
19:06:10.204 T:1793582000  NOTICE: Running database version TV29
19:06:10.212 T:1793582000  NOTICE: Running database version Epg11
19:06:10.218 T:1945719456  NOTICE: start dvd mediatype detection
19:06:10.987 T:1945719456 WARNING: JSONRPC: Could not parse type "Setting.Detail        s.SettingList"
19:06:11.611 T:1945719456  NOTICE: initialize done
19:06:11.612 T:1945719456  NOTICE: Running the application...
19:06:11.631 T:1945719456  NOTICE: starting zeroconf publishing
19:06:11.637 T:1945719456  NOTICE: CWebServer[8080]: Started
19:06:11.637 T:1945719456  NOTICE: starting upnp client
19:06:11.649 T:1629483952  NOTICE: ES: Starting UDP Event server on port 9777
19:06:11.650 T:1629483952  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
19:06:11.674 T:1945719456  NOTICE: VideoPlayer: Opening: :0
19:06:11.674 T:1945719456 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIA        LIZED
19:06:11.675 T:1582298032  NOTICE: Creating InputStream
19:06:11.678 T:1582298032   ERROR: CVideoPlayer::OpenInputStream - error opening        [:0]
19:06:11.678 T:1582298032  NOTICE: CVideoPlayer::OnExit()
19:06:11.679 T:1945719456   ERROR: Playlist Player: skipping unplayable item: 0,        path [:0]
19:06:11.691 T:1945719456  NOTICE: CVideoPlayer::CloseFile()
19:06:11.691 T:1945719456  NOTICE: VideoPlayer: waiting for threads to exit
19:06:11.691 T:1945719456  NOTICE: VideoPlayer: finished waiting
19:06:11.692 T:1945719456  NOTICE: VideoPlayer: Opening: tcp
19:06:11.692 T:1582298032  NOTICE: Creating InputStream
19:06:11.693 T:1582298032   ERROR: CVideoPlayer::OpenInputStream - error opening        [tcp]
19:06:11.693 T:1582298032  NOTICE: CVideoPlayer::OnExit()
19:06:11.693 T:1945719456   ERROR: Playlist Player: skipping unplayable item: 1,        path [tcp]
19:06:11.704 T:1945719456  NOTICE: CVideoPlayer::CloseFile()
19:06:11.704 T:1945719456  NOTICE: VideoPlayer: waiting for threads to exit
19:06:11.704 T:1945719456  NOTICE: VideoPlayer: finished waiting
19:06:11.704 T:1945719456  NOTICE: VideoPlayer: Opening: vt7
19:06:11.705 T:1582298032  NOTICE: Creating InputStream
19:06:11.705 T:1582298032   ERROR: CVideoPlayer::OpenInputStream - error opening        [vt7]
19:06:11.705 T:1582298032  NOTICE: CVideoPlayer::OnExit()
19:06:11.705 T:1945719456   ERROR: Playlist Player: skipping unplayable item: 2,        path [vt7]
19:06:12.010 T:1945719456  NOTICE: CVideoPlayer::CloseFile()
19:06:12.010 T:1945719456  NOTICE: VideoPlayer: waiting for threads to exit
19:06:12.011 T:1945719456  NOTICE: VideoPlayer: finished waiting
19:06:12.011 T:1945719456  NOTICE: CVideoPlayer::CloseFile()
19:06:12.011 T:1945719456  NOTICE: VideoPlayer: waiting for threads to exit
volumio@volumio:~$ clear
volumio@volumio:~$ cat ../kodi/.kodi/temp/kodi.log
18:41:32.465 T:1945719456  NOTICE: special://profile/ is mapped to: special://masterprofile/
18:41:32.465 T:1945719456  NOTICE: -----------------------------------------------------------------------
18:41:32.465 T:1945719456  NOTICE: Starting Kodi (17.4 Git:20170913-5cc491e-dirty). Platform: Linux ARM 32-bit
18:41:32.465 T:1945719456  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
18:41:32.465 T:1945719456  NOTICE: Kodi compiled Sep 13 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
18:41:32.465 T:1945719456  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.31-v7+
18:41:32.471 T:1945719456  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
18:41:32.471 T:1945719456  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
18:41:32.471 T:1945719456  NOTICE: ARM Features: Neon enabled
18:41:32.471 T:1945719456  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:41:32.471 T:1945719456  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
18:41:32.472 T:1945719456  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
18:41:32.472 T:1945719456  NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata
18:41:32.472 T:1945719456  NOTICE: special://envhome/ is mapped to: /home/kodi
18:41:32.472 T:1945719456  NOTICE: special://home/ is mapped to: /home/kodi/.kodi
18:41:32.472 T:1945719456  NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp
18:41:32.472 T:1945719456  NOTICE: special://logpath/ is mapped to: /home/kodi/.kodi/temp
18:41:32.472 T:1945719456  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
18:41:32.472 T:1945719456  NOTICE: Local hostname: volumio
18:41:32.472 T:1945719456  NOTICE: Log File is located: /home/kodi/.kodi/temp//kodi.log
18:41:32.472 T:1945719456  NOTICE: -----------------------------------------------------------------------
18:41:32.547 T:1945719456   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
18:41:32.607 T:1945719456  NOTICE: load settings...
18:41:32.822 T:1945719456  NOTICE: Found 1 Lists of Devices
18:41:32.822 T:1945719456  NOTICE: Enumerated PI devices:
18:41:32.822 T:1945719456  NOTICE:     Device 1
18:41:32.823 T:1945719456  NOTICE:         m_deviceName      : HDMI
18:41:32.823 T:1945719456  NOTICE:         m_displayName     : HDMI
18:41:32.823 T:1945719456  NOTICE:         m_displayNameExtra:
18:41:32.823 T:1945719456  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
18:41:32.823 T:1945719456  NOTICE:         m_channels        : FL,FR
18:41:32.823 T:1945719456  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
18:41:32.823 T:1945719456  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
18:41:32.823 T:1945719456  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
18:41:32.823 T:1945719456  NOTICE:     Device 2
18:41:32.823 T:1945719456  NOTICE:         m_deviceName      : Analogue
18:41:32.823 T:1945719456  NOTICE:         m_displayName     : Analogue
18:41:32.824 T:1945719456  NOTICE:         m_displayNameExtra:
18:41:32.824 T:1945719456  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
18:41:32.824 T:1945719456  NOTICE:         m_channels        : FL,FR
18:41:32.824 T:1945719456  NOTICE:         m_sampleRates     : 48000
18:41:32.824 T:1945719456  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
18:41:32.824 T:1945719456  NOTICE:         m_streamTypes     : No passthrough capabilities
18:41:32.824 T:1945719456  NOTICE:     Device 3
18:41:32.824 T:1945719456  NOTICE:         m_deviceName      : Both
18:41:32.824 T:1945719456  NOTICE:         m_displayName     : HDMI and Analogue
18:41:32.881 T:1945719456  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:41:32.881 T:1945719456  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <samba>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
18:41:32.884 T:1945719456  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:41:32.884 T:1945719456  NOTICE: Default Video Player: VideoPlayer
18:41:32.884 T:1945719456  NOTICE: Default Audio Player: paplayer
18:41:32.884 T:1945719456  NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:41:32.884 T:1945719456  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:41:32.885 T:1945719456  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:41:32.888 T:1945719456  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:41:32.896 T:1945719456  NOTICE: Loaded playercorefactory configuration
18:41:32.897 T:1945719456  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:41:32.897 T:1945719456  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:41:32.992 T:1945719456  NOTICE: Running database version Addons27
18:41:33.184 T:1945719456  NOTICE: ADDONS: Using repository repository.xbmc.org
18:41:33.390 T:1945719456  NOTICE: Raspberry PI firmware version: Jun  8 2017 13:29:59
18:41:33.390 T:1945719456  NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
18:41:33.390 T:1945719456  NOTICE: cache.memorysize: 30MB libass.cache: 0MB
18:41:33.390 T:1945719456  NOTICE: Config:
                                            arm_freq=1200
                                            audio_pwm_mode=1
                                            config_hdmi_boost=5
                                            core_freq=400
                                            disable_l2cache=1
                                            disable_splash=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            lcd_framerate=60
                                            over_voltage_avs_boost=43750
                                            ramfsaddr=-1
                                            sdram_freq=450
                                            temp_limit=85
                                            device_tree=-
18:41:33.390 T:1945719456  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:41:33.393 T:1945719456  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:41:33.393 T:1945719456  NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
18:41:33.393 T:1945719456  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:41:33.393 T:1945719456  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
18:41:33.393 T:1945719456  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:41:33.393 T:1945719456  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
18:41:33.393 T:1945719456  NOTICE: Found (640x480@60.000000) at 16, setting to RES_DESKTOP at 16
18:41:33.393 T:1945719456  NOTICE: Checking resolution 16
18:41:33.573 T:1945719456  NOTICE: GL_VENDOR = Broadcom
18:41:33.573 T:1945719456  NOTICE: GL_RENDERER = VideoCore IV HW
18:41:33.573 T:1945719456  NOTICE: GL_VERSION = OpenGL ES 2.0
18:41:33.573 T:1945719456  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:41:33.573 T:1945719456  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
19:06:03.804 T:1945719456 WARNING: CLangInfo: unable to load language "resource.language.fr_fr". Trying to determine matching language addon...
19:06:03.806 T:1945719456 WARNING: CLangInfo: unable to find an installed language addon matching "resource.language.fr_fr". Trying to find an installable language...
19:06:09.725 T:1743250352  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
19:06:10.987 T:1945719456 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:06:11.674 T:1945719456 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
the rpi has detected a cec device (i guess it’s my tv …) …
EDIT : byw, at this step, i haven’t run the commands to chowned/EGL …
EDIT 2: I have the kodi by default set-up(), and i can not reach the kodi web gui through my brower (rpi-ip:8081 which is the port i have configured ( only change i made …))
Aye, the webserver should be configured from within Kodi. Updating the settings unfortunately doesn’t suffice.
You only need to configure the webserver once, so you’ll need your TV
it works … don’t ask me why i did not made any change … omg …
except the fact that i haven’t the sound (i only have the choice between hdmi/analogic/hdmi&analogic within kodi’s option whereas i’m plugged using spdif cable to my amp ) even though within kodi plugin’s option, i have selected “enable dac output for kodi”) - i have a digione card btw …
EDIT : sound works fine - i still do not know why this is it … I’m gonna watch a movie now it works, i’ll see if tomorrow, after a day asleep, kodi will re-start correctly.
Thanks a bunch anyway for the time spent Saiynato !
Awesome! I just uploaded a new version, this version seems to be working, the webserver is enabled by default! :slight_smile:
I have discovered that the credentials are not always updated when saving in the plugin. Will retest tomorrow… Done for today with scripting :wink:
Thanks again for your support Saiyato !
One strange “bug” - there is a slight gap between the sound and the image (image first, less than one sec. after, the sound) - I tried to modify the setting in the kodi plugin (cannot remember the name of the setting, but default value il 0.7s), but it still does not work …
Any idea where it might come from ?
Aye, some sound cards experience this behavior. It’s not something I can fix, you’re most likely to have the same problem with open/libreelec or osmc.
The only thing you can do is find out the delay you need to configure in either the plugin or Kodi itself. If you edit the settings in the plugin you need to restart Kodi afterwards.
My bad, it is in kodi settings, it’s fine now :slight_smile:
Thanks again !
Actually the change I’ve made worked on one movie, for the rest, I still have a delay - when i try to modify the 0.7 setting in volumio (can not find it in kodi settings actually), it seems it does not apply (for instance when I turn it to 0, no more sound …)
The setting updates the audio delay, you will need to restart afterwards. It is kind of advanced configuration, so you might need to read into it a bit before applying stuff.
But as said, this is Kodi configuration, I don’t have soundcards with a delay, so I can’t help you with it :wink:
I was wondering if there is a distilled [GUIDE], and update for the process of installing KODI on VOLUMIO?
The guide is 20 pages long, and I am not sure, where to begin, and what has changed since the question was planted in May 2016. Thanks for any guidance.
Hi mate,
There is no ‘guide’ needed anymore, just install the plugin, which can be found here
Hi Saiyato. Thanks for the support and great work.
Any chance of getting the plugin with kodi 17.5 ?
Sent from my iPhone using Tapatalk
I still have to work out an update function, but if you re-install you will probably get 17.5, as it installs the latest from the pipplware repo.
