please, give the link, it could be your browser blocking
hello,
if one of you want to test, unzip the file in the link in
/data/plugins/audio_interface/fusiondsp/
camilladsp.conf.zip (443 Octets)
save something in the plugin then playâŚ
let me know
I have done a search to find if my question has been answere previously and couldnât find anything, it seems like it might be a common problem so apologies if I have missed itâŚ
Scenario:
I have a x86thin client running Volumio that I want to use to drive some DIY active monitors. The idea was I would connect my 8 channel soundcard and run my bi-amps straight from the soundcards output by implementing the crossover in Fusion/CamillaDSP.
The Problem:
When I go to create a two input, 8 output mixer in camillaDSP gui I get the error - âPipeline outputs 8 channels, playback device has 2â however when i run aplay -L via SSH i get the below which shows all 8 channels.
volumio@volu-attc:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
Playback/recording through the PulseAudio sound server
volumio
volumioDsp
fusiondsphook
fusiondspfifo
postDsp
volumioOutput
volumioHw
sysdefault:CARD=Eight
M-Track Eight, USB Audio
Default Audio Device
front:CARD=Eight,DEV=0
Front speakers
surround21:CARD=Eight,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Eight,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Eight,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Eight,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Eight,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Eight,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Eight,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Eight,DEV=0
Direct sample mixing device
dsnoop:CARD=Eight,DEV=0
Direct sample snooping device
hw:CARD=Eight,DEV=0
Direct hardware device without any conversions
plughw:CARD=Eight,DEV=0
Hardware device with all software conversions
usbstream:CARD=Eight
M-Track Eight
USB Stream Output
volumio@volu-attc:~$ volumio@volu-attc:~$
Also:
volumio@volu-attc:~$ alsacap
*** Scanning for playback devices ***
Card 5, ID `Eight', name `M-Track Eight'
Device 0, ID `USB Audio', name `USB Audio', 1 subdevices (1 available)
8 channels, sampling rate 44100..96000 Hz
Sample formats: S32_LE
Buffer size range from 12 to 32768
Period size range from 6 to 16384
Subdevice 0, name `subdevice #0'
Is there a way to get all channels recognised so I can run this config?
Many thanks in advance!
Alex
hello,
I found whyâŚ
Output device is hidden in camilla Gui to make it simpleâŚ
But in your case you need it.
Workaround : edit
/data/plugins/audio_interface/fusiondsp/cgui/config/gui-config.yml
and set
hide_playback_device: false
save and reload camilla gui
now you can set number of channels, but do not change anything else
of course, change pipeline and mixer setting
let me know
http://logs.volumio.org/volumio/UC8Q1H6.html
Music library also doesnât load. PEQ enabled.
Was it working in the past?
Have you changed something in your system?
Does it work with webradio?
First time I have used it
Have not tested internet radio
Very strange Volumio also stops working, canât browse media library, Volumio becomes unresponsive
FusionDSP 1.0.32
Volumio 3.396
In fact, mpd probably fails to start because something not compatible in the Alsa stack, and then everything stop to work in Volumio.
You are not alone, but still no clueâŚ
Thanks for reporting
What would you suggest me try? Install an earlier version of FusionDSP?
No interest for a previous version because last changes are not related to this part.
You can try to change sample rate, but not sure it helpsâŚ
Iâm very annoyed with that
FusionDsp v1.0.33 beta.
- Internal : chunksize size for better hw compatibility
This update may fix some issues, like no library, no sound, volumio freezeâŚ
This is a beta for testing and please feedback!
Remove previous version, reboot, install
It fixed it for (non exhaustive)
Dell wyse 3040
Virtual BOX (no official support)
Enjoy.and let me know
Hi Balbuze,
Amazing! Thank you⌠This solved the problem and I am now getting stuck into the implementation. Thank you so much for your solution and also all the hard work you put into this project. Volumio and FusionDSP together is a match made in heaven.
All the best,
Alex
Great, I will try it, but I canât find this version on the Volumio plug in search.
As this is a beta, you have to enable "plugin testâ in IP/dev.
But Warning, in this mode youâll access to all plugin in beta state, meaning potentially unstable.
Donât forget to reverse it after you installed FusionDsp
Thanks. Itâs working now.
I wish I could turn EQ on/off in an instance to listen to differences. The on/off button for DSP in Volumio quick access meny doesnât seem to work. Lower right corner, a speaker symbol.
You have to click here
It takes 2-3 seconds.
And please, confirm the version you use, if it works, and HW.
FusionDsp v1.0.33 stable
This update may fix some issues, like no library, no sound, volumio freeze with some HWâŚ
If you experience such problem, update to this version and let me know
Enjoy
I decided to try 1.0.33 but within minutes the old problem was back
log: http://logs.volumio.org/volumio/0s3K2XP.html
So, it plays then stop after a while?
Is it possible for you to share the contents of
/tmp/camilladsp.log
when it happens?
Yes
Is it possible for you to share the contents of /tmp/camilladsp.log
There is a tmp directory on my RPi, at the root level, but there is no such log file inside.
