This plugin seems pretty cool, nice work
Well I see mpd is having troublesā¦
Donāt know why, even if I already saw this on my systemā¦
Investigatingā¦
TY
Thanks. I noticed the mpd errors when I looked at the log. Wish I knew more about the internals.
The test tracks by the plugin is not tagged at all, when browsing into for example āAlbumsā the first item is album without a name or art and inside it is all the test tracks.
Perhaps those could be tagged to contain some information. ie āFusionDsp test tracksā or so as album name, because currently this will look like a bug to end user.
I donāt understand. There is no track with the pluginā¦
Can you explain?
Yes, of course.
From the plugin settings, you can download test tracks.(Sweepās and PN tracks)
i tried to screenshot it, but it wont open the settings now it seems.(i just updated to 3.139 and 0.1.1 FusionDSP)
http://logs.volumio.org/volumiobuster/eKllhvO.html (Live Log got stuck on loading uiconfig for plugin, without further messages, when trying to navigate in there)
E: the plugin shows as enabled, but inactive in the plugin screen and there is no way to activate it, ill restart the PI if you dont need any further logs?
Very weird.
Is it a fresh install or an update?
I canāt see line about the plugin in your log.
Please reboot, try to reproduce the issue and right after send log.
But files provided are generated directly by REW. The may be not tagged. But you have to use the play button in the plugin to play them.
Did you installed from the store?
Delete the plugin and reinstall.
If not better, then restore Volumio to factoryā¦
Btw, I see for the unnamed folder for tools files. Iāll see if something is possible
Volumio was updated from the version which was before the current, for the plugin i think the update did jump couple of versions.
Restart did seem to cure things, now the plugin is active again.
i only install plugins from the store, and do not tweak anything with SSH.(i really need the āout of boxā volumio experience for my app developement.)
In fact, max value for eq = Frequency/2 -1
Eq 5 is 22149Hzā¦
So CamillaDsp canāt compute it.
Values are checked in the plugin when you type them (1-20000Hz), but not with imported eq.
So, if you want to stay very close, change value in imported file to 22049 or set a value <20000Hz in UI.
In any case, you canāt hear the differenceā¦
Do you mean with Qobuz?
I pushed a version 0.1.5 where frequency is limited at 22049Hz when you type in es. When imported from a file, a value superior to 22049 is converted to 22049⦠So now it should work with your files
It can be cool to add a small switch button to the playing screen (the main screen) to quickly change the profile who is loaded in fusion dsp.
For exemple, i listen music sometime with headphones, sometime on speakers, for both i made 2 differents profiles, and i have to go each times in settings-plugin-load profileā¦Before listening music, and i canāt remember whish profile is already loaded !
I just came to the forum to ask for the same thing
hi! yes this is something we are working onā¦But nothing to share yet
Custom preset and enable/disable effect would be enough?
Apart this point, can you give more details of your use, hw, sources and type of Eq please.
Hi Balbuze,
Same as David_S, I use Speakers and Headphone, itās the also the name of my Presets.
I use ParamEQ, Headphone settings are imported from AutoEQ, I use crossfeed and gain. Speakers have no setting for ParamEQ for now, no crossfeed, gain back to 0.
Use RPi 3 B+ with Hifiberry DAC+Pro, V3.111 (not RC1).
Ok.
Why do you use gain? You need a different level L/R?
In my Raspberry Pi setup (a very old raspberry), I get an alsa error when trying to play a file after enabling the FusionDsp plugin. I have Volumio 3.150 and a NuForce uDAC-2 USB DAC. With the FusionDsp disabled, playback works fine.
Here is the log: http://logs.volumio.org/volumiobuster/O5OsjXr.html
@balbuze can you advice him in this?
