It costs nothing to dream
I want you to have a nice weekend . But without the updateā¦
We are sorry but there is some more complicated things than expected
So, it remains a dream
No Problem maybe next weekend.
But thanks for your effort!
Wish all a nice weekend!
Hi to everybody,
will this thread be only for the Fusion Beta Programm itself, or is someone intresting in āhow toā here?
Or.will there be a new thread on the stable Version (when it comes), to discussion about DSPš¤·āāļø.
Or is this the wrong Forum to talk about?
As an example,
at the moment i try to measure with Windows and REW about TuneBlade to Volumio (for the Testsignal).
hello!
Good suggestion. Iām going to create a new thread āHow-to FusionDspā
It remains a dream this weekend?
I think so
I donāt dare to confirmā¦
Sorry
But, new version (without the fix)
Version 0.1.26
Fix
- Loudness was not applied after save if no volume change
- Variable samplerate with conv filter
New
- CamillaDsp gui! For advanced user only. You can manage more than two channelsā¦In this mode, you are on your own ⦠And I provide no support for CamillaDsp GUIā¦
Warning : installation may take several minutes due to new libraries and python3 required
Please test and feeback
I installed the new version (0.1.26) but it was unusable for me, unfortunately. Dropouts were happening 1-3 times per second.
For me much better than previous version, hardly any dropouts
New version is without the fix for dropouts.
hi!
If your main use is local files, or spotify, spotify connect or Tidal, you can try the following to avoid dropout ONLY on RPI
- edit:
/data/plugins/audio_interface/fusiondsp/asound/volumioDsp.postDsp.10.conf
- then change
pcm.volumioDsp {
type plug
slave.pcm "volumioDspww"
- to
pcm.volumioDsp {
type plug
slave.pcm "volumioDspfx"
- disable the plugin, renable it.
It should be ok, but mpd hang with Qobuz or webradio
This only for RPI, on x86 or Thinkerboard it will result with no sound with all mpd play
Version 0.1.27
Fix
Pure CamillDsp GUi settings were not saved
Peaking Range-> bandwidth
Still no dropout fix
I see under settings a section āpurecamillaguiā but there is no button or something else to open a gui? Or is it not available for x86?
It is. But maybe you need to remove previous version, reboot and install the new.
And donāt forget to apply when selected
Yes you see it every time,
but to use it you have to select Camilladsp in the first dropdown menue and press apply
gave it a try anyway⦠a lot less dropouts(!) even though the fix hasnāt been implemented yet
After updating Volumio to v3.198 and FusionDSP to v0.1.27 webradios are working stable now on RPi 3B+ and ZeroW. I can not say if this change is a result of the Volumio update or the FusionDSP update because I updated both simultaneously. Thanks!
Good! But Iām afraid it is just because today the moonā¦
Seriously, sometimes it works for hours and suddenly start to dropout⦠But anyway, enjoy it!
