Hi there,
So Roon are intent on fleecing their customers as much as possible and I’ve had enough!
If I subscribe to Volumio and install it on my Raspberry Pi will it have the feature of being able to be “headless” i.e I can quit my browser or turn off the iPad remote and the music will continue playing? i.e it’s running on the Pi not my laptop?
Then… I can open the browser or iPad later and they will update and I can easily reconnect them and the playback position gets updated?
Can Volumio do that? If yes I’m subscribing to the full version!
The whole intention of Volumio is being a headless device/
You can quit your browser or app and music continuous to play.
You can reopen and select a new album or what ever you want.
There is a free trail, so give it a go.
Understood.
So if I have the Volumio OS on my RPi and that same RPi has a USB DAC… then I can only group other RPi’s with Volumio on them in the same group…is that correct?
Or if I want to use AirPlay can I run Volumio as an OS only i.e Server and use multiple Airplay devices in a group?
yes, with premium features you can group up to 6 volumio devices to play the same audio content (1 master, up to 5 slaves)
You can use Airplay to one Volumio master device, and play the very same music content on several slave Volumio devices (up to 5)
Besides that, Raspberry Pi is not the only platform where you can run Volumio, it works fine also on a PC/laptop/netbook with an Intel or AMD 64-bit processor, it works fine on the ASUS ThinkerBoard too
The only thing I’m missing is the ability to do any editing of albums…in particular making albums that are showing as two individual albums in to the double album they actually are. It’s not a huge issue anyhow.
Also Playlists don’t seem to work on an Album level when I add to them from my local NAS but do work on an album level when adding to them from Qobuz…it means the Playlists are not really useable as I have a mix of tracks and albums.
But overall I’m liking it.
Unfortunately the adding to the Playlist like this is the problem: it’s not at an Album playlist it’s tracks. Which is normally how Playlists operate I know.
However, how do I organise Volumio so that I can say, group all my Radiohead albums together -as Albums, not a long list of constituent tracks in each album?
